| Last minute suggestions for buildup | |
+4Mr.Riviera TonySmooth89 Supercharged oldsman105 8 posters |
oldsman105 Junkie
| Subject: Last minute suggestions for buildup Mon Feb 09, 2009 2:11 pm | |
| Currently My SSEi is parked because the Transmission needs to be replaced. I have decided since I am replacing the transmission I might as well do some upgrades . And a few other things here is my list.
Engine:
MPS Ported and Polished SC LS1 TB S1X Cam with 105 springs Power Log and Rear ported Manifold 3" downpipe
Transmission:
DIY shift kit 3.29 gears ( I am cheating I am using a N/A trans with HD Diff.) ATI 2750 Stall torque converter.
Anyone have any last minute suggestions or anything else I should do while I'm in there? No I am not doing headers or pulling the heads off are not in the time frame as I have to do all this during the weekend at the shop I work at.
Thanks in advance. | |
Supercharged Addict
Name : Blake Age : 34 Location : Akron, Ohio Joined : 2008-03-12 Post Count : 611 Merit : 0
| Subject: Re: Last minute suggestions for buildup Mon Feb 09, 2009 4:03 pm | |
| id throw rockers for sure on there, it might be the equivelent of having headers...rockers and a cam would move enough air to drop pulleys. and if you P&P the supercharger, then buy a ported LIM aswell....that is if you have the desire to go that far. | |
TonySmooth89 Aficionado
| Subject: Re: Last minute suggestions for buildup Mon Feb 09, 2009 7:17 pm | |
| Why not throw some GXP drive chains in there? They're supposedly good to low 12s and theres a guy on regalgs.org selling a set for 40 bucks+shipping.
Otherwise sounds like a good build. | |
| Subject: Re: Last minute suggestions for buildup Mon Feb 09, 2009 7:20 pm | |
| Blake, rockers + cam = valve to piston clearance issues.
i dont see a way to tune in your list, but provided you have a plan, it should run nice!
cant wait to see time slips _________________ 1996 with 254k miles, L32 4" FWI -> ported N* -> Ported Gen V w/3.0" Pulley, Stage 3 Phenolic I/C, ZZP FMHE, 1.84 RR, Headers and 3" pipe to mufflers, F-body brakes, and lowered on Eibachs. -RIP AMG C400 White on black. Stage 2 w/E30 - 11.9@117 -daily | |
99prixgt Member
Name : Erik Age : 37 Location : NJ Joined : 2009-01-27 Post Count : 90 Merit : 2
| Subject: Re: Last minute suggestions for buildup Mon Feb 09, 2009 11:25 pm | |
| S1x cam over rockers anyday, with those upgrades you should get headers. Imo rear plogs are a waste of money, there not that restrictive. | |
| Subject: Re: Last minute suggestions for buildup Tue Feb 10, 2009 12:05 am | |
| really don't think the stall is necessary with that build but I guess why not.. | |
oldsman105 Junkie
| Subject: Re: Last minute suggestions for buildup Tue Feb 10, 2009 8:40 am | |
| I already have the Higher stall torque converter from my last build. The Plog and Rear manifold are because I want a more OEM look. At least till I get the turbo kit. Then I will need the manifolds anyway. | |
dreww Junkie
| Subject: Re: Last minute suggestions for buildup Wed Feb 11, 2009 12:25 am | |
| - Mr.Riviera wrote:
- Blake, rockers + cam = valve to piston clearance issues.
cant wait to see time slips not if he puts on 1.6 rr's - oldsman105 wrote:
- I already have the Higher stall torque converter from my last build. The Plog and Rear manifold are because I want a more OEM look. At least till I get the turbo kit. Then I will need the manifolds anyway.
then why spend all that money on the ported SC, TB and MPS? It just money you could put toward your turbo build. | |
Buickman104 Enthusiast
Age : 38 Location : New York City Joined : 2007-11-29 Post Count : 156 Merit : 0
| Subject: Re: Last minute suggestions for buildup Wed Feb 11, 2009 9:47 am | |
| He had all those as carry overs from his old 1996 buick Riviera. Ported Super charger- free MPS- christmas present from me like 3 years ago TB he got a good deal on and already had the MAF and other needed accessories. | |
oldsman105 Junkie
| Subject: Re: Last minute suggestions for buildup Wed Feb 11, 2009 10:15 am | |
| The only thing I purchased extra was the LS1 TB and adapter, The rest I had. Once I have enough for the turbo kit I will resell the other stuff. | |
| Subject: Re: Last minute suggestions for buildup Wed Feb 11, 2009 12:56 pm | |
| Just to throw some stuff out there...
remove heat shields and wrap exhaust parts with header wrap get the aluminum LIM gaskets (no brainier I'm sure) blower inlet opened up to 75.5 right? valve cover breather or other modification to use the TB (if the adapter blocks off that inlet like mine did) dex6 for the transaxle or other synthetic egr delete | |
| Subject: Re: Last minute suggestions for buildup Wed Feb 11, 2009 1:13 pm | |
| i thought it was bad to wrap plog's? _________________ 1996 with 254k miles, L32 4" FWI -> ported N* -> Ported Gen V w/3.0" Pulley, Stage 3 Phenolic I/C, ZZP FMHE, 1.84 RR, Headers and 3" pipe to mufflers, F-body brakes, and lowered on Eibachs. -RIP AMG C400 White on black. Stage 2 w/E30 - 11.9@117 -daily | |
oldsman105 Junkie
| Subject: Re: Last minute suggestions for buildup Wed Feb 11, 2009 3:18 pm | |
| - turtleman wrote:
- Just to throw some stuff out there...
remove heat shields and wrap exhaust parts with header wrap get the aluminum LIM gaskets (no brainier I'm sure) blower inlet opened up to 75.5 right? valve cover breather or other modification to use the TB (if the adapter blocks off that inlet like mine did) dex6 for the transaxle or other synthetic egr delete Going to use paint on ceramic coating for the manifolds AL. LIM gaskets checkblower inlet opened up to 75.5 right checkvalve cover breather or other modification to use the TB (if the adapter blocks off that inlet like mine did) checkdex6 for the transaxle or other synthetic after the first flush egr delete check | |
99prixgt Member
| Subject: Re: Last minute suggestions for buildup Wed Feb 11, 2009 4:56 pm | |
| - Mr.Riviera wrote:
- i thought it was bad to wrap plog's?
agreed. They like to crack from not having breathing room because, the metal used on plogs is pretty thin. | |
| Subject: Re: Last minute suggestions for buildup | |
