brmcm15 Member
Name : Brandon Age : 33 Location : Macomb, Michigan Joined : 2008-12-02 Post Count : 84 Merit : 0
| Subject: replacing the shifter solenoid (NA Series II) Thu Feb 26, 2009 1:04 pm | |
| has anyone had to do this???
i have a 97 rviy with almost 97,000 miles on it and after i told my friends dad what just happend to my car he said i need to replace this part so that my key does not keep getting stuck in the ignigtion.......he also said he knos this because he has worked on alot of gtp's with this problem and it keeps getting worse as it happens | |
| Subject: Re: replacing the shifter solenoid (NA Series II) Thu Feb 26, 2009 2:17 pm | |
| Hi, A few of ours have needed ignition switches, but I haven't heard of any needing the shifter solenoid. What just happened to your car? | |
1wickedninja Addict
Name : Josh Age : 36 Location : port saint lucie, Fl Joined : 2008-07-30 Post Count : 647 Merit : 5
| Subject: Re: replacing the shifter solenoid (NA Series II) Thu Jan 07, 2010 8:06 pm | |
| Today my key got stuck in the ignition. After sevral times puting it in park and moving the shifter and the key I got it out. Could this be the shifter solenoid or the ignition switch? Or somthing else?[/b] | |
| Subject: Re: replacing the shifter solenoid (NA Series II) Thu Jan 07, 2010 11:38 pm | |
| It's not the solenoid, that's only to keep the shifter button from working with the key on & the brake off.
It's either the ignition cylinder or the cable that runs between the ignition & the shifter. This is the usual connection that keeps the shifter locked in Park when the key is off (turned to Lock), and in turn keeps the key from locking the wheel while the shifter is not in Park. | |
| Subject: Re: replacing the shifter solenoid (NA Series II) | |
