| tortuga | |
+52Rivit 98riv rivparadise ironclyde th3fr4nchi5e Birdawgxx 96_Juggernaut 69GSColorado chitown_riv98 Sir Psycho Sexy matt270avian albertj joshuadalegrimes sniperdude LARRY70GS llamalor2112 denim RidzRiv setsuna57 J. Chris Davis Hometown Hero Z-type pbrktrt Dragnet charlieRobinson Turbocharged400sbc gmann3001 95rivy 97 park ave 97buickriviera ghpcnm nothincame2mind deekster_caddy nebstewart07 bigdave Eldo Abaddon sburch23 BMD DEMonte1997 flyineagle96 Karma ibmoses Rickw robotennis61 T Riley IBx1 AA Snowdog L67 stan turtleman 56 posters |
| Subject: Re: tortuga Fri Mar 04, 2011 5:37 pm | |
| Finally got the new cradle sprayed. Good thing because mine right now is definitely getting more noisy during turns with any speed. It's a very uncomfortable sound. 1k primer already done laying the jet black - went through two quarts of paint I wasn't sure what to do about clear. I just decided against it. I have a virtually unlimited supply of undercoating I also considered but paint is definitely not my expertise. Any Ideas? | |
| Subject: Re: tortuga Sun Mar 06, 2011 9:54 pm | |
| I would probably throw some UC on there if you have such easy access to it. I have a feeling it's one of those 'throw everything in the book at it' things where the more you get on it, the more it might help. But they rot from the inside out, so if you haven't been able to spray the insides with something, all you spray on the outside may make no difference in the long run... | |
| Subject: Re: tortuga Sat Mar 19, 2011 2:24 pm | |
| The block-off plate's totally done. Thanks to Andrew, Terry, and myself. It's the smallest things that need the most attention sometimes. I hope that today, I'll get the plate glued in and the vent cavities filled and smoothed against the case rotor bores. Then I'll probably wait for the JB weld to cure and reassemble the blower. I have some extra eaton bearing grease, the GM anaerobic sealer, and new oil ready to go. EDIT: all done! Only problem is the f**king tube of GM anaerobic sealer busted shortly after I started using it so I had to go run and find some scrap wood and a clamp to hold the end seam of the tube shut. I'm also done with the lower intake other than cutting out the one coolant passage. I need to come up with some efficient way of doing that now.
| Subject: Re: tortuga Fri Apr 01, 2011 10:25 pm | |
| Check out my totally kick ass undercoating spray booth! | |
nothincame2mind Aficionado
Name : Ryan Age : 38 Location : Columbia, Missouri Joined : 2007-01-19 Post Count : 1182 Merit : 20
| Subject: Re: tortuga Sat Apr 02, 2011 4:20 am | |
BMD Aficionado
| Subject: Re: tortuga Sat Apr 02, 2011 7:56 am | |
| Great stuff Codith, The blower and LIM look sweet, so I'm guessin' that the plate funnels the air in more efficiently, creating more power, but what is the HP gain? Also, where did you get the cradle, looks fantastic, any chance of you taking some pics of the installation? | |
| Subject: Re: tortuga Sat Apr 02, 2011 2:14 pm | |
| - BMD wrote:
- Great stuff Codith, The blower and LIM look sweet, so I'm guessin' that the plate funnels the air in more efficiently, creating more power, but what is the HP gain? Also, where did you get the cradle, looks fantastic, any chance of you taking some pics of the installation?
The plate is just something to hold the JBweld fillings for the silencing vents secure. You'd think by eliminating an intentional boost leak between the blower and intake manifold which is kinda what the vents are, you'd gain efficiency but not really. Doesn't hurt though. Cradle came out of a low mile '98 Aurora in TX and I then stripped, primered, painted, and undercoated it. I promised to take pics of the install which, by the way, is going to be very interesting now that my buddy with the shop got laid off and I'll be doing it all in my garage, possibly between tomorrow and Tuesday. | |
| Subject: Re: tortuga Wed May 18, 2011 11:59 am | |
| GM racing torsen limited slip differential with all the upgrades Single largest purchase yet for this car. This should be a great enhancement to the overall driving experience and performance - no more one-tire b.s. It should be getting installed in the next month or so. | |
ghpcnm Aficionado
| Subject: Re: tortuga Wed May 18, 2011 12:10 pm | |
| Hey turtleman: I'm a litttle cornfused here...Is this the same car you have in your signature line and if so, where are the stripes on your front fenders? I always admired them as a nice touch...much better than the fake portholes so often seen on these cars.
| Subject: Re: tortuga Wed May 18, 2011 12:27 pm | |
| The older pictures were from before I added the poison stripes and maybe some of the newer ones may be without stripes. I know I removed them and re-applied them later in a slightly different position. Anyway yeah, only one car. | |
Karma Aficionado
| Subject: Re: tortuga Wed May 18, 2011 12:45 pm | |
| what did the diff set you back? _________________ | |
| Subject: Re: tortuga Wed May 18, 2011 12:52 pm | |
| Wow. Hope you found a good deal on it! _________________ '05 GTO 6.0L • 6-spd • 95k miles • 0-60: 4.8s • 16.9 avg MPG • Nelson Ledges Lap: 1:26'95 Celica GT 2.2L • 5-spd • 165k miles • 0-60: yes'98 SC Riviera • 281k miles • 298 HP/370 TQ • 0-60: 5.79s • ET: 13.97 @ 99.28 • 4087 lb • 20.1 avg MPG • Nelson Ledges Lap: 1:30 3.4" pulley • AL104 plugs • 180º t-stat • FWI w/K&N • 1.9:1 rockers • OR pushrods • LS6 valve springs • SLP headers • ZZP fuel rails KYB GR2 struts • MaxAir shocks • Addco sway bars • UMI bushings • GM STB • Enkei 18" EV5s w/ Dunlop DZ101s • F-body calipers EBC bluestuff/Hawk HP plus • SS lines • Brembo slotted discs • DHP tuned • Aeroforce • Hidden Hitch^^^ SOLD ^^^ '70 Ninety-Eight Holiday Coupe 455cid • 116k miles^^^ SOLD ^^^ | |
| Subject: Re: tortuga Wed May 18, 2011 1:04 pm | |
| $1400 - Not terrible considering it's a priceless part at this point and the last bill for it was $1850 from dynotech. One of my favorite things about this one is I don't have to do anything with it but put it in. I didn't really want to buy it right now but I can't really count on one of these coming along later. | |
| Subject: Re: tortuga Wed May 18, 2011 1:23 pm | |
| If I had the money, that's the one to get. Info: http://www.torsen.com/files/Torsen%20T-2%20Technical%20Sheet.pdf _________________ '05 GTO 6.0L • 6-spd • 95k miles • 0-60: 4.8s • 16.9 avg MPG • Nelson Ledges Lap: 1:26'95 Celica GT 2.2L • 5-spd • 165k miles • 0-60: yes'98 SC Riviera • 281k miles • 298 HP/370 TQ • 0-60: 5.79s • ET: 13.97 @ 99.28 • 4087 lb • 20.1 avg MPG • Nelson Ledges Lap: 1:30 3.4" pulley • AL104 plugs • 180º t-stat • FWI w/K&N • 1.9:1 rockers • OR pushrods • LS6 valve springs • SLP headers • ZZP fuel rails KYB GR2 struts • MaxAir shocks • Addco sway bars • UMI bushings • GM STB • Enkei 18" EV5s w/ Dunlop DZ101s • F-body calipers EBC bluestuff/Hawk HP plus • SS lines • Brembo slotted discs • DHP tuned • Aeroforce • Hidden Hitch^^^ SOLD ^^^ '70 Ninety-Eight Holiday Coupe 455cid • 116k miles^^^ SOLD ^^^ | |
| Subject: Re: tortuga Wed May 18, 2011 2:11 pm | |
| Are these units available for the series 1?? | |
| Subject: Re: tortuga Wed May 18, 2011 3:24 pm | |
| Can you install these without dropping the transmission? _________________ '05 GTO 6.0L • 6-spd • 95k miles • 0-60: 4.8s • 16.9 avg MPG • Nelson Ledges Lap: 1:26'95 Celica GT 2.2L • 5-spd • 165k miles • 0-60: yes'98 SC Riviera • 281k miles • 298 HP/370 TQ • 0-60: 5.79s • ET: 13.97 @ 99.28 • 4087 lb • 20.1 avg MPG • Nelson Ledges Lap: 1:30 3.4" pulley • AL104 plugs • 180º t-stat • FWI w/K&N • 1.9:1 rockers • OR pushrods • LS6 valve springs • SLP headers • ZZP fuel rails KYB GR2 struts • MaxAir shocks • Addco sway bars • UMI bushings • GM STB • Enkei 18" EV5s w/ Dunlop DZ101s • F-body calipers EBC bluestuff/Hawk HP plus • SS lines • Brembo slotted discs • DHP tuned • Aeroforce • Hidden Hitch^^^ SOLD ^^^ '70 Ninety-Eight Holiday Coupe 455cid • 116k miles^^^ SOLD ^^^ | |
| Subject: Re: tortuga Wed May 18, 2011 3:31 pm | |
| - robotennis61 wrote:
- Are these units available for the series 1??
The 4T60 and 65E-HD have the same carriers so I think it could be fitted. I wanna say the axle splines and the spider gears need to be switched along with HD axles. It can be done but consult someone who knows their shit because I haven't researched much on that. | |
| Subject: Re: tortuga Wed May 18, 2011 3:34 pm | |
- Can you install these without dropping the transmission?
It's supposed to be like a 1-2 hour job so I wanna say yes, at least on a w-body. I assume the install would be the same deal on a riv. I'm not doing it though. I'd prefer not to learn how to do this for the first time right now seeing as the stakes in cost are pretty high. I'm going to bring it to Paul. | |
97buickriviera Amateur
Name : Ian Age : 54 Location : Cumming, Georgia Joined : 2011-05-28 Post Count : 34 Merit : 0
| Subject: Re: tortuga Tue Jun 14, 2011 7:56 pm | |
| this car is no turtle with the supercharger! | |
| Subject: Re: tortuga Mon Jun 20, 2011 6:21 pm | |
| I've decided the smart thing to do with the perpetually rising gas prices is to convert the car to N/A. So I drove down to Danville, IL and picked up this beauty out of a 2006 Lacrosse with 79,330 mi on it for a very reasonable price. | |
97 park ave Addict
| Subject: Re: tortuga Tue Jun 21, 2011 5:40 pm | |
| ^i call BS lol. Hear comes the turbo turtle | |
IBx1 Expert
95rivy Enthusiast
Name : curt Location : upstate ny Joined : 2009-04-04 Post Count : 189 Merit : 3
| Subject: Re: tortuga Tue Jun 21, 2011 8:19 pm | |
| - 97 park ave wrote:
- ^i call BS lol. Hear comes the turbo turtle
I agree i cant believe you would put all that time and efforts in and then drop in a na motor??? i call BS dude. So what car is that motor going in? If that is going in your car what are you going to do with it? | |
T Riley Guru
| Subject: Re: tortuga Wed Jun 22, 2011 9:55 pm | |
| Oh HOW NEAT... Would you look at this?!?! a L26 motor! LOLOLOLOLOL its 9.4:1 compression... vs. L67/L32 8.5:1 .. BRB codiths gonna be the new king.. L8R beta FGTS | |
Karma Aficionado
| Subject: Re: tortuga Wed Jun 22, 2011 10:26 pm | |
| yup. top swapped high compression goodness. Gonna be sick. _________________ | |
| Subject: Re: tortuga | |
| tortuga | |
