 1991 Riv Dash
tomc
PostSubject: 1991 Riv Dash   Sun May 31, 2009 11:57 am
Help ,my dash is going crazy. EVERY light lights up ,then flickers, then goes totally dark , then OK, then flickers. It 's like a ballroom light show. Could there be a bad ground? Or this a telltale sign to try and get a new dash? Can you still get them? Thank you
Ship
PostSubject: Re: 1991 Riv Dash   Sun May 31, 2009 12:50 pm
I'm assuming you're talking about your IPC (instrument panel cluster). Sounds like you might only have a loose/dirty wire harness connection at the back of the IPC. Remove the trim plate, then the cluster and clean/reattach the harness connection and see if it eliminates the problem.
tomc
PostSubject: Re: 1991 Riv Dash   Sat Jun 20, 2009 4:56 pm
I checked out the plug and all looked well. Got a rebuilt dash cluster and all is well again . Thanks for your advice
Tom
Merit : 239
PostSubject: Re: 1991 Riv Dash   Fri Oct 16, 2009 10:12 am
MOVED TO: INTERIOR TECH
^^^ RIV IS FOR SALE! ^^^
PostSubject: Re: 1991 Riv Dash   Sun Oct 18, 2009 7:29 pm
How's your alternator looking? That or a failing battery can make odd symptoms where your dash has intermittent xmas light issues... Worth a look.
Good luck.
ironclyde
PostSubject: Re: 1991 Riv Dash   Wed Mar 05, 2014 11:34 pm
Mine has symptoms like this. It comes on intermittently works great (all gauges functioning) for a while then goes off. When it's blacked out the speedo reads "00", odo reads "error" and there is a warning light for "electrical problem." (Duh!) Anyway, on mine I've noticed the tachometer drops from the operating engine speed to zero before the dash quits. Everything else seems to be fine.
helpscratch
Ship
PostSubject: Re: 1991 Riv Dash   Thu Mar 06, 2014 1:45 pm
Ironclyde,
As mentioned in my previous post "00" and "error" can be an indication of:
"you might only have a loose/dirty wire harness connection at the back of the IPC. Remove the trim plate, then the cluster and clean/reattach the harness connection and see if it eliminates the problem".
Also, a rebuilt IPC is an alternative. 1990-1993 Riviera and 1990-1991 Reatta IPC's are interchangeable. They are a common item for sale on EBay ranging from $100 to $199 depending on guarantees offered.
ironclyde
PostSubject: Re: 1991 Riv Dash   Thu Mar 06, 2014 10:35 pm
Thanks Ship. I did all of the wire harness shaking and connector cleaning. So, I'm with you on the IPC. Fortunately, I have a friend who can repair it. He's the kinda guy that might be inclined to trade silver coins or ammo or you know... He's a good guy but he's out of town on vacation in Virginia. I didn't want to wait until he got back. I'm wondering if it's not a loose soldered connection.
beer
1991 Riv Dash
