| Valve Covers - Clean - Decals... | |
xxsupergman25xx Aficionado
Name : Scotty Age : 37 Location : Pittsburgh, PA Joined : 2007-03-03 Post Count : 1251 Merit : 13
| Subject: Valve Covers - Clean - Decals... Wed Jun 10, 2009 7:12 pm | |
| Its me again my front valve cover is very dirty. i would like to take it off and really give it a good clean. from what i see theres a few bolts holdin it on? i tried to look it up a little on here..but theres corey removed like half the engine when he painted it lol is there a risk or is it a harder of a job then a realize? looks like itll be an 15 min job right?
Last edited by xxsupergman25xx on Wed Jun 10, 2009 9:57 pm; edited 1 time in total | |
| Subject: Re: Valve Covers - Clean - Decals... Wed Jun 10, 2009 9:04 pm | |
Ash Enthusiast
Name : Marty Age : 46 Location : S. Central Indiana Joined : 2008-05-21 Post Count : 115 Merit : 4
| Subject: Re: Valve Covers - Clean - Decals... Wed Jun 10, 2009 9:10 pm | |
| It's not a difficult job at all to remove and re-install the front cyl. bank valve cover. (Held on with 6 capscrew/rubber seal with metal washer assemblies) Get your plug wire hold out of the way of course, and I'm sure you can figure the rest out. The service manual says to re-install with GM 12345493 (or blue Loctite), and torque screws to 10 N-m (or 89 lb-in).
Be careful that you reinstall the capscrew seals and valve cover perimeter seal correctly. Don't let the valve cover seal fall out of place when reinstalling the cover.
Cheers.
Last edited by Ash on Wed Jun 10, 2009 9:13 pm; edited 2 times in total (Reason for editing : more) | |
| Subject: Re: Valve Covers - Clean - Decals... Wed Jun 10, 2009 9:58 pm | |
| http://www.reflectiveconcepts.com/product_info.php?products_id=325
anyone ever see these before? | |
97rivsc Fanatic
Name : mike Age : 34 Location : appleton wisconsin Joined : 2008-09-28 Post Count : 437 Merit : 0
| Subject: Re: Valve Covers - Clean - Decals... Wed Jun 10, 2009 10:37 pm | |
| I think a black painted cover with silver stripes looks badass | |
| Subject: Re: Valve Covers - Clean - Decals... Wed Jun 10, 2009 10:54 pm | |
| you can clean them up pretty well on the car. get a can of engine cleaner and hose it off. zzp sells them pre painted or in aluminum($$) the inserts look pretty cool, but i wonder how well they would hold up. one thing to note, you are supposed to replace the valve gasket when you take the cover off, hopefully it wont leak if you reuse the old one. _________________ 1996 with 254k miles, L32 4" FWI -> ported N* -> Ported Gen V w/3.0" Pulley, Stage 3 Phenolic I/C, ZZP FMHE, 1.84 RR, Headers and 3" pipe to mufflers, F-body brakes, and lowered on Eibachs. -RIP AMG C400 White on black. Stage 2 w/E30 - 11.9@117 -daily | |
| Subject: Re: Valve Covers - Clean - Decals... Wed Jun 10, 2009 11:35 pm | |
| hmmm. gaskets confuse me lol ill have to scratch that for now lol | |
| Subject: Re: Valve Covers - Clean - Decals... Thu Jun 11, 2009 6:25 am | |
| - Ash wrote:
- It's not a difficult job at all to remove and re-install the front cyl. bank valve cover. (Held on with 6 capscrew/rubber seal with metal washer assemblies)
Cheers. Be sure not to overtighten the V/C bolts. 89 in-lb is not very tight at all. Consistent tightening makes for a no-leak finish. I highly recommend an inch-lb torque wrench, although I know a lot of people have done it by hand. It's the consistency that matters. - xxsupergman25xx wrote:
- hmmm. gaskets confuse me lol
ill have to scratch that for now lol The gasket is very simple. Remove, clean valve cover, replace with new gasket. It's a rubber gasket that uses NO RTV, and slides into a channel in the valve cover, so when you put the new gasket in, a couple of dabs of grease to hold it in place and run some oil around the whole thing with your finger, kind of like an oil filter, is all you need. If gaskets are confusing to you, maybe you should have somebody with experience show you how to do it. It's really not that difficult. | |
| Subject: Re: Valve Covers - Clean - Decals... | |
