 Fix your HVAC door modules for $7?
3 posters
Fix your HVAC door modules for $7? Empty
PostSubject: Fix your HVAC door modules for $7?   Fix your HVAC door modules for $7? EmptyTue Dec 15, 2009 9:12 pm
Fix your HVAC door modules for $7? Gears
This is an idea I had when mine went out, but didn't follow up on. Having gotten back into R/C and monkeyed around with electric motors a bit it's come back to me - why not just replace the motor? Unfortunately I can't find my old module to see what size motor was in it, but looking at the above pic, it appears to be a 370, which you can get for less than $7 - Link
The brass gears that come on these things can be crushed off with pliers. The trick is going to be prying the worm gear off the old motor and pressing it on the new one. Then you just have to wire the new motor in.
These modules aren't going to get any cheaper or easier to come by, so I thought I'd throw this out as an alternative to replacement. The can-type brushed motors will always be available.
PostSubject: Re: Fix your HVAC door modules for $7?   Fix your HVAC door modules for $7? EmptyTue Dec 15, 2009 10:07 pm
Jr, What voltage do these run on.
You know the ones in our modules run on 5 volts.!
PostSubject: Re: Fix your HVAC door modules for $7?   Fix your HVAC door modules for $7? EmptyTue Dec 15, 2009 11:17 pm
That one I know will run a range of at least 7.4 - 11.1 volts.
Merit : 104
PostSubject: Re: Fix your HVAC door modules for $7?   Fix your HVAC door modules for $7? EmptyWed Dec 16, 2009 12:47 am
Interesting... I always thought they used stepper motors, but I guess they just use a feedback rheostat on one of the gears, like the memory seat does.
» Polished SS door handle cover to hide door panel seam separation
» HVAC
» FAQ: HVAC Blower motor only works part time, or stays on
» HVAC outside air temp.
» HVAC Schmetatics
