| 95 Riviera, new to board.... | |
captain12pk Special
Name : Dave Joined : 2010-02-22 Post Count : 9 Merit : 0
| Subject: 95 Riviera, new to board.... Mon Feb 22, 2010 7:34 pm | |
| First of all, hello to all. I am new to this board, and I have a 95 Riviera SC. I would like to know any, or all, source options for a donor engine . My block has three cracks in it and I need a new one. What other vehicles could I use with all my engine hardware without needing to reprogram a computer or having to alter under the hood? I am trying to do this on the cheap, since funds are tight and the cheapest aftermarket I could find was about $1,200. I am going to try salvage yards, but I would like to know what i need to look for.Thanks for your help. | |
captain12pk Special
| Subject: Re: 95 Riviera, new to board.... Mon Feb 22, 2010 8:20 pm | |
| Okay, let me modify this some. Outside the aforementioned, is the Series I only in the 95 SC? May seem like a dumb question, but I am tryingto be a quick study and take a crash course in Riv power plants and understanding what is compatable with mine. Again a 1995 Riviera supercharged. Thanx.... | |
xxsupergman25xx Aficionado
Name : Scotty Age : 37 Location : Pittsburgh, PA Joined : 2007-03-03 Post Count : 1251 Merit : 13
| Subject: Re: 95 Riviera, new to board.... Mon Feb 22, 2010 8:24 pm | |
| 95 is a series 1 only SC. they had the option for a series 2 N/A | |
captain12pk Special
| Subject: Re: 95 Riviera, new to board.... Mon Feb 22, 2010 8:32 pm | |
| Is the 95 my SC my only option for an engine then? | |
| Subject: Re: 95 Riviera, new to board.... Mon Feb 22, 2010 8:57 pm | |
| yes. ud have to do a lot of work. lot of programming to put a series 2 in there. cars with series 1 SC is park avenue bonnevilles im drawin a blank on the others but other series one NA bonnevilles regals park aves lesabres grand prix there may be a few other. anyone from the peanut gallery? | |
captain12pk Special
| Subject: Re: 95 Riviera, new to board.... Mon Feb 22, 2010 9:06 pm | |
| Will those series ones that are NA work without mods? If so great and thanks for your help. | |
| Subject: Re: 95 Riviera, new to board.... Mon Feb 22, 2010 9:09 pm | |
| I don't think the '95 Riviera got the Series I NA (L27). Can someone confirm? I believe there were two options for Riviera in 1995:
• Series I SC 3800 (L67)
• Series II NA 3800 (L36)
(Series II SC 3800 and Series II NA was used in '96-97 Riviera, '98-99 had Series II SC standard)
Series I SC was also offered as an option for the Buick Park Avenue, Oldsmobile 88 LS/LSS, Oldsmobile 98, and Pontiac Bonneville SLE/SSE. It was standard for the Bonneville SSEi.
For cheapest replacement, I'd look for a used Series I SC. That should be plug & play. Series II NA, although less expensive engine, would involve some work to adapt (mainly & wire harness PCM). I believe transmissions are also different between the SC & NA, but not sure.
If you're up for a swap, might as well go Series II SC, as they are abundant and offer a little more power. _________________ '05 GTO 6.0L • 6-spd • 95k miles • 0-60: 4.8s • 16.9 avg MPG • Nelson Ledges Lap: 1:26'95 Celica GT 2.2L • 5-spd • 165k miles • 0-60: yes'98 SC Riviera • 281k miles • 298 HP/370 TQ • 0-60: 5.79s • ET: 13.97 @ 99.28 • 4087 lb • 20.1 avg MPG • Nelson Ledges Lap: 1:30 3.4" pulley • AL104 plugs • 180º t-stat • FWI w/K&N • 1.9:1 rockers • OR pushrods • LS6 valve springs • SLP headers • ZZP fuel rails KYB GR2 struts • MaxAir shocks • Addco sway bars • UMI bushings • GM STB • Enkei 18" EV5s w/ Dunlop DZ101s • F-body calipers EBC bluestuff/Hawk HP plus • SS lines • Brembo slotted discs • DHP tuned • Aeroforce • Hidden Hitch^^^ SOLD ^^^ '70 Ninety-Eight Holiday Coupe 455cid • 116k miles^^^ SOLD ^^^ | |
captain12pk Special
| Subject: Re: 95 Riviera, new to board.... Mon Feb 22, 2010 9:17 pm | |
| Is there a year range they can be found or is there a possible VIN code to look for, or something on the engine if it is in car and I have to pull it, I would know what I am looking for? | |
captain12pk Special
| Subject: Re: 95 Riviera, new to board.... Mon Feb 22, 2010 9:20 pm | |
| thanks for you patience with me BTW. Just wanted to say that even if someof this seems redundant, I just want to make sure so I do not make a wrong move, and it would seem that Rivieras are in short in the Nashville area, let alone 95's. | |
| I don't blame you one bit. Series I SC looks like this: Used in: 1991-1995 Buick Park Avenue Ultra 1992-1995 Oldsmobile Eighty-Eight LS (opt) 1992-1995 LSS (opt) 1992-1995 Oldsmobile Ninety-Eight (opt) 1992-1995 Pontiac Bonneville SLE (opt. SC package), SSE (opt) & SSEi 1995 Buick Riviera (Opt) _________________ '05 GTO 6.0L • 6-spd • 95k miles • 0-60: 4.8s • 16.9 avg MPG • Nelson Ledges Lap: 1:26'95 Celica GT 2.2L • 5-spd • 165k miles • 0-60: yes'98 SC Riviera • 281k miles • 298 HP/370 TQ • 0-60: 5.79s • ET: 13.97 @ 99.28 • 4087 lb • 20.1 avg MPG • Nelson Ledges Lap: 1:30 3.4" pulley • AL104 plugs • 180º t-stat • FWI w/K&N • 1.9:1 rockers • OR pushrods • LS6 valve springs • SLP headers • ZZP fuel rails KYB GR2 struts • MaxAir shocks • Addco sway bars • UMI bushings • GM STB • Enkei 18" EV5s w/ Dunlop DZ101s • F-body calipers EBC bluestuff/Hawk HP plus • SS lines • Brembo slotted discs • DHP tuned • Aeroforce • Hidden Hitch^^^ SOLD ^^^ '70 Ninety-Eight Holiday Coupe 455cid • 116k miles^^^ SOLD ^^^ | |
| Subject: Re: 95 Riviera, new to board.... Mon Feb 22, 2010 9:36 pm | |
| AA, to my knowledge only '96 and newer (SII) S/C motors were designated L67. I am not sure what the '95 was called but it is a totally different engine than the later S/C motors. Otherwise you are on the right track, that list of Series I S/C cars is about right. I can't think of any to add. | |
captain12pk Special
| Subject: Re: 95 Riviera, new to board.... Mon Feb 22, 2010 9:39 pm | |
| That is what I have. Am familiar with it. Does the Series II look different? Can you or someone post a pic if it looks different? From what I understand the 95 Series I is an L67 as well. | |
| Subject: Re: 95 Riviera, new to board.... Mon Feb 22, 2010 9:52 pm | |
| Subject: Re: 95 Riviera, new to board.... Mon Feb 22, 2010 9:57 pm | |
| Found a pic of the Series II but it has the engine cover off: | |
| Subject: Re: 95 Riviera, new to board.... Mon Feb 22, 2010 10:00 pm | |
| Series I SC (L67): Series II NA (L36): Series II SC (L67): _________________ '05 GTO 6.0L • 6-spd • 95k miles • 0-60: 4.8s • 16.9 avg MPG • Nelson Ledges Lap: 1:26'95 Celica GT 2.2L • 5-spd • 165k miles • 0-60: yes'98 SC Riviera • 281k miles • 298 HP/370 TQ • 0-60: 5.79s • ET: 13.97 @ 99.28 • 4087 lb • 20.1 avg MPG • Nelson Ledges Lap: 1:30 3.4" pulley • AL104 plugs • 180º t-stat • FWI w/K&N • 1.9:1 rockers • OR pushrods • LS6 valve springs • SLP headers • ZZP fuel rails KYB GR2 struts • MaxAir shocks • Addco sway bars • UMI bushings • GM STB • Enkei 18" EV5s w/ Dunlop DZ101s • F-body calipers EBC bluestuff/Hawk HP plus • SS lines • Brembo slotted discs • DHP tuned • Aeroforce • Hidden Hitch^^^ SOLD ^^^ '70 Ninety-Eight Holiday Coupe 455cid • 116k miles^^^ SOLD ^^^ | |
captain12pk Special
| Subject: Re: 95 Riviera, new to board.... Mon Feb 22, 2010 10:19 pm | |
| Thankyou all, you have been very helpful. I hope I can resolve my engine issues soon. Thanks again | |
98riv Moderator
| Subject: Re: 95 Riviera, new to board.... Mon Feb 22, 2010 11:18 pm | |
| Welcome to the forum! _________________ 1998 Supercharged Riviera - Custom CAI, Alpine spx-13ref, Infinity 6x9's, Alpine 4 Channel Amp, Kicker KX3, Silverstars, STB, Hawk Brake Pads, Monroe Air Shocks, KYB GR2
| Subject: Re: 95 Riviera, new to board.... | |
