 Write-Up: Replacing Alternator
goldiemike
Write-Up: Replacing Alternator Empty
PostSubject: Write-Up: Replacing Alternator   Write-Up: Replacing Alternator EmptyThu Apr 19, 2007 10:24 pm
I would like to know if anyone can give me a step by step to replace just the belts and the alternator on my 1998 Supercharged Riviera. I have seen the post with replacing the pulleys and everything but i just need a guide for replacing the belts and alternator.
PostSubject: Re: Write-Up: Replacing Alternator   Write-Up: Replacing Alternator EmptyFri Apr 20, 2007 8:11 am
Has anyone done a write-up for changing belts on Series II?
Merit : 64
PostSubject: Re: Write-Up: Replacing Alternator   Write-Up: Replacing Alternator EmptyFri Apr 20, 2007 9:31 am
from the riviera FAQ website:
Jack the R's Write-up: Replacing Belts and Tensioner Pulleys
You can find the link to the FAQ website in the 1st sticky in the FAQ section of this very forum.
PostSubject: Re: Write-Up: Replacing Alternator   Write-Up: Replacing Alternator EmptyFri Apr 20, 2007 9:55 am
Oh... RegalGS.org has a critical error message this morning. I'm moving that write-up over to our site asap - if Jack doesn't. We don't want to lose that kind of info!
urbsnspices
urbsnspices
PostSubject: Re: Write-Up: Replacing Alternator   Write-Up: Replacing Alternator EmptyFri Apr 20, 2007 10:19 am
The alt is pretty easy.
Remove Belt: Find the tensioner, it is the smooth pulley just under the alt pulley. Use a wrench on the tensioner, counter clock wise will compress the spring so you can remove the belt.
Remove tensioner idler pulley: This is a reverse threaded bolt, turn the bolt clock wise to loosen the bolt and remove the pulley. This will give you more acess to the lower alt bolt.
Unhook the battery: It is a good idea to remove the negative side of the battery. Most of the alt is grounded and zap in the wrong place could damage it.
Remove bolts: The back of the alt is attached to the SC, with an elaborate looking bracket. You may be able to get away with just removing the rear bolt attached to the alt. You may have to loosen this bracket up to get the new alt in place. There are three large bolts on the pulley side, remove these. Remove the pwr cable from the Alt.
While the battey is unhooked, clean the electrical contact on the alt cable. Wire brush usually works, just make sure it isnt corroded.
Reverse to install.
Dont forget, the tensioner pulley bolt is reverse threaded, turn it counter clockwise to tighten.
This was written from memory, but It really isnt that difficult. Swaping in new belts is much more involved.
PostSubject: Re: Write-Up: Replacing Alternator   Write-Up: Replacing Alternator EmptyFri Apr 20, 2007 10:39 am
urbsnspices wrote:
Unhook the battery: It is a good idea to remove the positive side of the battery. Most of the alt is grounded and zap in the wrong place could damage it.
frown You should ALWAYS disc the NEG side of the battery
PostSubject: Re: Write-Up: Replacing Alternator   Write-Up: Replacing Alternator EmptyFri Apr 20, 2007 10:42 am
I was thinking the same. I always do the neg side. Seems like I get less sparking?
urbsnspices
urbsnspices
PostSubject: Re: Write-Up: Replacing Alternator   Write-Up: Replacing Alternator EmptyFri Apr 20, 2007 10:58 am
fixed wink
PostSubject: Re: Write-Up: Replacing Alternator   Write-Up: Replacing Alternator EmptyFri Apr 20, 2007 10:59 am
PostSubject: Re: Write-Up: Replacing Alternator   Write-Up: Replacing Alternator EmptyWed Jun 20, 2018 11:46 pm
See any problems here? The fan has a visible wobble but AFAIK that isn't necessarily an issue.
PostSubject: Re: Write-Up: Replacing Alternator   Write-Up: Replacing Alternator EmptyFri Jul 06, 2018 11:52 pm
What made you remove it from the car? Did it make a wining sound? One way to diagnose a bad alternator bearing is to check operating temp of the unit with the car running. You should be able to touch a healthy alternator with your hand on a warm engine. A bad bearing will heat up the unit - it will be too hot to touch.
PostSubject: Re: Write-Up: Replacing Alternator   Write-Up: Replacing Alternator EmptySat Jul 07, 2018 12:25 am
Had it off to remove the SC snout.
Here's a vid from October 2016 where you can hear the months-old alternator chirruping - (@:55)
The alternator has since stopped chirruping (and I replaced the bad tensioner).
» Weber alternator problems
» Mutiny Kites....replacing the depower rope!
» Adding a Mitsubishi 3 wire alternator
» North Rebel 10m 2008 Kite only
