| FAQ: High Mile Club - Wear/Repair Reports | |
+11496_Juggernaut IFallsRon bmcd9179 MrWood88 charlieRobinson darulerrick Jamax cbames themanwithsauce setsuna57 97buickriviera lo619 ghpcnm 95 rivieramn bigdave adam14212 J. Chris Davis Derek RidzRiv flyineagle96 Riv95SC brian10962001 DecoyGSX jenkkijussi Abaddon Buapo Eldo ZEP Tank florence_x Hometown Hero eumilea Rickw curious riv GMFreak8 ibmoses Roberta BMD woggy robotennis61 Anoswal rivboy rivparadise dscott2000 hotrod58 #1BearsFan Sweepspear duster_do_little vendetta SuperRiv07 Shintsu manofmany patillac captshiner TonySmooth89 jamie 54_nailhead sburch23 blackbart95 Karma 97chargedriv ewolfe0050 IBx1 BKRIV deekster_caddy SLPR 6.0L palermocorey90 etosino2009 96RIVMANN Designated SC95Riv coop dadeboy305 Miss Beth turtleman Ridin-Rivi albertj duffy dreww CMan okiedrifter jonly oldsman105 96riv ender467 Jason SpaceBar urbsnspices SilverArrow102 NO 4 EVR gosloriv dan ¤DoughBoy¤ HirohataMerc robertwolf86 CeeKay Jake95Riv SoCal Riv xxsupergman25xx Orca 99Rivman Blowin95 1998 Riv Andysdorm lionfish Brad95Riv T Riley nothincame2mind racinfan jax95riv 98riv pwmin Mr.Riviera AA 118 posters |
How many Miles On Your Riviera? | <25,000 | | 1% | [ 3 ] | 25,000-50,000 | | 3% | [ 9 ] | 50,000-75,000 | | 8% | [ 27 ] | 75,000-100,000 | | 13% | [ 44 ] | 100,000-125,000 | | 19% | [ 66 ] | 125,000-150,000 | | 22% | [ 75 ] | 150,000-175,000 | | 13% | [ 44 ] | 175,000-200,000 | | 11% | [ 38 ] | 200,000-225,000 | | 6% | [ 20 ] | 225,000-250,000 | | 2% | [ 8 ] | 250,000-275,000 | | 2% | [ 10 ] | 275,000-300,000 | | 0% | [ 1 ] | >300,000 | | 1% | [ 2 ] |
| Total Votes : 347 | | |
palermocorey90 Expert
| Subject: Re: FAQ: High Mile Club - Wear/Repair Reports Tue Jun 17, 2008 9:22 pm | |
| i have owned my car since october since then i have done a motor swap, tranny swap pcm swap, full harness swap, fuel pump swap. still need to do a windshield swap to many swaps LOL | |
jamie Fanatic
Name : Jamie Age : 36 Location : Truro, NS Joined : 2008-06-17 Post Count : 283 Merit : 1
| Subject: Re: FAQ: High Mile Club - Wear/Repair Reports Wed Jun 18, 2008 9:34 am | |
| I should also add, we got the Riviera with 170k km's on it so the bulk of it's initial repairs were likely already done. I know we've replaced the water pump and an air spring. Oh, and since it was nailed on the passenger side when we got it, we also put a door and quarter panel on it. | |
| Subject: Re: FAQ: High Mile Club - Wear/Repair Reports Wed Jun 18, 2008 1:35 pm | |
| - Quote :
- we got the Riviera with 170k km's on it so the bulk of it's initial repairs were likely already done.
I don't know. The only thing I'd needed to replace by 105k miles was belts, ignition wires, shocks/struts, and cat converter. It seems these cars run fine until at least 150k miles (240k km). _________________ '05 GTO 6.0L • 6-spd • 95k miles • 0-60: 4.8s • 16.9 avg MPG • Nelson Ledges Lap: 1:26'95 Celica GT 2.2L • 5-spd • 165k miles • 0-60: yes'98 SC Riviera • 281k miles • 298 HP/370 TQ • 0-60: 5.79s • ET: 13.97 @ 99.28 • 4087 lb • 20.1 avg MPG • Nelson Ledges Lap: 1:30 3.4" pulley • AL104 plugs • 180º t-stat • FWI w/K&N • 1.9:1 rockers • OR pushrods • LS6 valve springs • SLP headers • ZZP fuel rails KYB GR2 struts • MaxAir shocks • Addco sway bars • UMI bushings • GM STB • Enkei 18" EV5s w/ Dunlop DZ101s • F-body calipers EBC bluestuff/Hawk HP plus • SS lines • Brembo slotted discs • DHP tuned • Aeroforce • Hidden Hitch^^^ SOLD ^^^ '70 Ninety-Eight Holiday Coupe 455cid • 116k miles^^^ SOLD ^^^ | |
jamie Fanatic
| Subject: Re: FAQ: High Mile Club - Wear/Repair Reports Wed Jun 18, 2008 1:53 pm | |
- Quote :
I don't know. The only thing I'd needed to replace by 105k miles was belts, ignition wires, shocks/struts, and cat converter. It seems these cars run fine until at least 150k miles (240k km). That is true, I suppose I was misreading a lot of things as km's. At the present mileage, 221km, what things should I be looking at getting serviced right away - not fully knowing if things that needed to be done to it have been or not.? | |
| Subject: Re: FAQ: High Mile Club - Wear/Repair Reports Wed Jun 18, 2008 2:28 pm | |
| Jamie, please check in your profile that "always display signature" is checked "yes". Thanks!
If you have a Series II SC engine, I'd check the serp belts and have the trans fluid changed (not flushed) as a starting point. Ignition wires are probably also on their last leg. Changing plugs would be next as good insurance. _________________ '05 GTO 6.0L • 6-spd • 95k miles • 0-60: 4.8s • 16.9 avg MPG • Nelson Ledges Lap: 1:26'95 Celica GT 2.2L • 5-spd • 165k miles • 0-60: yes'98 SC Riviera • 281k miles • 298 HP/370 TQ • 0-60: 5.79s • ET: 13.97 @ 99.28 • 4087 lb • 20.1 avg MPG • Nelson Ledges Lap: 1:30 3.4" pulley • AL104 plugs • 180º t-stat • FWI w/K&N • 1.9:1 rockers • OR pushrods • LS6 valve springs • SLP headers • ZZP fuel rails KYB GR2 struts • MaxAir shocks • Addco sway bars • UMI bushings • GM STB • Enkei 18" EV5s w/ Dunlop DZ101s • F-body calipers EBC bluestuff/Hawk HP plus • SS lines • Brembo slotted discs • DHP tuned • Aeroforce • Hidden Hitch^^^ SOLD ^^^ '70 Ninety-Eight Holiday Coupe 455cid • 116k miles^^^ SOLD ^^^ | |
sburch23 Addict
| Subject: Re: FAQ: High Mile Club - Wear/Repair Reports Fri Jun 20, 2008 11:28 am | |
| If you are having the belts changed, inspect all idlers carefully. If in doubt (and your mileage qualifies you)---replace. I had one for the SC fail. Then 6 months later another failed. This time it caused both belts to be lost. Luckily I was only 1/4 mile from home and did not get stranded.
The idlers are relatively cheap but if they go and you have to replace belts it is time consuming or expensive. | |
sburch23 Addict
| Subject: Re: FAQ: High Mile Club - Wear/Repair Reports Fri Jun 20, 2008 11:32 am | |
IBx1 Expert
| Subject: Re: FAQ: High Mile Club - Wear/Repair Reports Fri Jun 20, 2008 11:37 am | |
| - sburch23 wrote:
- No but I am starting to feel funny shifts at about 45 mph like it is hunting for the right gear at that speed. It doesn't happen much or very severe but after driving this baby for 170,000 miles it is different.
My car does this too. The thing is, with my Riviera, it likes to go into overdrive as soon as it can, which is at just over 45 mph, since I'm very easy with the gas pedal. The steering wheel will vibrate a little since it's such a low speed, but other than that there's no serious problems. | |
captshiner Junkie
Name : Andrew Age : 37 Location : Cincinnati, OH Joined : 2008-07-23 Post Count : 756 Merit : -1
| Subject: Re: FAQ: High Mile Club - Wear/Repair Reports Wed Jul 30, 2008 5:37 pm | |
patillac Member
Name : Pat Age : 36 Location : Mentor ohio Joined : 2008-07-13 Post Count : 69 Merit : 1
| Subject: Re: FAQ: High Mile Club - Wear/Repair Reports Wed Jul 30, 2008 6:25 pm | |
| Mileage 113885
"Major" repairs needed (outside of wear items) no
Original engine/transmission?no/yes
Any other relevant information no | |
manofmany Addict
| Subject: Re: FAQ: High Mile Club - Wear/Repair Reports Wed Jul 30, 2008 6:30 pm | |
| 181k
Not sure what has or hasnt been done.
Needs valve cover gasket, sending unit, and a new hub I believe. Otherwise car is PERFECT. Runs and shifts like a dream. | |
Shintsu Expert
| Subject: Re: FAQ: High Mile Club - Wear/Repair Reports Wed Jul 30, 2008 8:30 pm | |
| Mileage - 144k
"Major" repairs needed (outside of wear items) - None
Original engine/transmission? - Yes/Yes
Still shifts perfectly. Coupler might be due for replacing but too much of a PITA to do so I'll live with the chatter. | |
SuperRiv07 Addict
Name : Nick Age : 39 Location : Brookfield, And If everything goes right A Nice big house in Bolingbrook with a big GARAGE Joined : 2008-07-20 Post Count : 706 Merit : 0
| Subject: Re: FAQ: High Mile Club - Wear/Repair Reports Wed Jul 30, 2008 10:22 pm | |
| Im At 151000, and running strong as the day I got it which wasnt that long ago lol but an old lady had it before me so I know she didnt beat it up | |
manofmany Addict
| Subject: Re: FAQ: High Mile Club - Wear/Repair Reports Wed Jul 30, 2008 10:52 pm | |
| Seems like Rivieras have had alot of miles put on them. I've talked to lots of people who buy them for travel. Thats sorta why I bought mine. Goes to show they are a complete package. | |
captshiner Junkie
| Subject: Re: FAQ: High Mile Club - Wear/Repair Reports Thu Jul 31, 2008 1:37 pm | |
| 253k Miles Nothing too major needs repaired, SC Coupler, a couple of gaskets, (this is new) either a battery or alternator Original engine and transmission
I think I'm winning so far....I'm so .....HAPPY!!! | |
sburch23 Addict
| Subject: Re: FAQ: High Mile Club - Wear/Repair Reports Mon Aug 11, 2008 9:43 pm | |
| OK just turned 200,000 a couple of weeks ago and interior pieces are starting to go.
a) The fake woodgrain on the center console has cracked and I pulled the pieces up. I want to put a Sherwood Dash kit in.
b) The underdash piece that fits under the steering wheel is loose on the right side.
c) The drivers side door interior piece is loose. Anybody know how to fix this.
d) Not sure if it is the 95degree plus weather is messing with me but it seems that the AC is not blowing as hard.
Still runs great. | |
vendetta Enthusiast
Name : Nick Age : 114 Location : Shakopee, MN Joined : 2008-09-26 Post Count : 219 Merit : 0
| Subject: Re: FAQ: High Mile Club - Wear/Repair Reports Sat Sep 27, 2008 5:38 pm | |
| 1. 168k-170k I cant recall....
2. Idler pulley and belt by me
3. Original Engine, Rebuilt Transmission proffesionally
4. Bought the car from my brother for 750$, he bought it 1.5 years prior for like 4-5k$ and had nothing but problems...
New fuel pump and new Transmission.... and other stuff.... but he put alot of money into it,
I drove it for 4-5 months last year (only winter driven) and it was perfect except that idler issue, changed that at -5degrees in the windy snow (no garage when it happened) | |
| Subject: Re: FAQ: High Mile Club - Wear/Repair Reports Sat Sep 27, 2008 5:51 pm | |
| The poll has been modified. If you voted previously but moved into a higher mileage bracket, you may cancel your vote and resubmit. _________________ '05 GTO 6.0L • 6-spd • 95k miles • 0-60: 4.8s • 16.9 avg MPG • Nelson Ledges Lap: 1:26'95 Celica GT 2.2L • 5-spd • 165k miles • 0-60: yes'98 SC Riviera • 281k miles • 298 HP/370 TQ • 0-60: 5.79s • ET: 13.97 @ 99.28 • 4087 lb • 20.1 avg MPG • Nelson Ledges Lap: 1:30 3.4" pulley • AL104 plugs • 180º t-stat • FWI w/K&N • 1.9:1 rockers • OR pushrods • LS6 valve springs • SLP headers • ZZP fuel rails KYB GR2 struts • MaxAir shocks • Addco sway bars • UMI bushings • GM STB • Enkei 18" EV5s w/ Dunlop DZ101s • F-body calipers EBC bluestuff/Hawk HP plus • SS lines • Brembo slotted discs • DHP tuned • Aeroforce • Hidden Hitch^^^ SOLD ^^^ '70 Ninety-Eight Holiday Coupe 455cid • 116k miles^^^ SOLD ^^^ | |
captshiner Junkie
| Subject: Re: FAQ: High Mile Club - Wear/Repair Reports Sat Sep 27, 2008 11:24 pm | |
| 253k, I think I'm still winning... | |
sburch23 Addict
| Subject: Re: FAQ: High Mile Club - Wear/Repair Reports Mon Sep 29, 2008 8:06 pm | |
duster_do_little Enthusiast
Name : Dustin Age : 37 Location : Midland, MI Joined : 2008-11-15 Post Count : 171 Merit : 4
| Subject: Re: FAQ: High Mile Club - Wear/Repair Reports Mon Dec 08, 2008 1:08 pm | |
| 1. 153k miles
2. had very light accident before i bought (according to carfax). I think driver's side as paint is faded and side mirror glass isn't original. I also think cruise stalk was replaced (it's grey, interior is tan, and leaving cruise on causes security system to kick in when trying to start)
3. Original engine and transmission. Runs like a top (very quiet and shifts smoothly)
4. Just replaced the oem radiator, bearings and fuel lines a couple weeks ago after buying the car, and I need to d oa little work on the sunroof as it opens smooth but skips when closing. | |
Sweepspear Fanatic
Name : Dale Age : 63 Location : Minneapolis, MN Joined : 2008-11-04 Post Count : 386 Merit : 11
| Subject: Re: FAQ: High Mile Club - Wear/Repair Reports Mon Dec 08, 2008 1:35 pm | |
| My '96 has 192,500 on it. Original engine and tranny. Runs smooth and quiet without even the slightest tick. I am still having a hard time getting used to the fact that a car these days can have this kind of mileage and still have lots of life left in it. It was unheard of with a few exceptions even 20 years ago. Maybe Volvos.
#1BearsFan Enthusiast
Name : Bill Location : North Carolina Joined : 2008-07-28 Post Count : 231 Merit : 4
| Subject: Re: FAQ: High Mile Club - Wear/Repair Reports Mon Dec 08, 2008 3:19 pm | |
| at 124Kmi looks like I am in the middle of the pack. I bought the car w/full documentation: Tranny at 81,000 Water pump at 113,000 thats it.... | |
hotrod58 Amateur
Name : Josh Age : 35 Location : McPherson Kansas Joined : 2008-12-11 Post Count : 22 Merit : 0
| Subject: Re: FAQ: High Mile Club - Wear/Repair Reports Fri Dec 19, 2008 12:26 am | |
| 191,764 miles. Bought the car earlier this month and up to this point I know the front tires were replaced recently, newer supercharger, original paint and interior. Motor may have been rebuilt because it runs like new. Needs new motor mounts and mabe alternator? | |
dscott2000 Enthusiast
Name : Scott Age : 42 Location : Kansas City, MO Joined : 2008-07-27 Post Count : 160 Merit : 0
| Subject: Re: FAQ: High Mile Club - Wear/Repair Reports Fri Dec 19, 2008 3:19 pm | |
| - racinfan wrote:
- So who are the high mileage owners we have here? It would be nice to get an idea of the longevity that our cars are capable of and what kind of repairs were necessary throughout the lifetime of the vehicle.
So basically:
- Mileage
- "Major" repairs needed (outside of wear items)
- Original engine/transmission?
- Any other relevant information
I've seen a couple of cars around here near 200k but has anyone actually eclipsed that number yet?
If you voted previously but moved into a higher mileage bracket, you may cancel your vote and resubmit. I have 194,685 miles I just got my Riv in April so, I do believe the transmission has been replaced. I do know that it does have the original engine. Other than the normal wear items, My Riv runs like it was brand new. I had 2 cars that peaked 200,000 plus miles. One of them was a 1992 Oldsmobile 88 that I purchased for 400 bucks. When I sold the car it had over 270,000 on the original engine. The other car was a 1994 Corsica 3.1L that had 250,000 miles.
| Subject: Re: FAQ: High Mile Club - Wear/Repair Reports | |
