jax95riv Aficionado
| Subject: What's the stock exhaust consist of? Sat Jan 20, 2007 10:30 am | |
| quote AA: "Here's a shot of the Riviera from below:"OK. Here's the Series I guy chiming in again. Is my exhaust the same...as far as headers and other aftermarket goodies? | |
| Subject: Re: What's the stock exhaust consist of? Sat Jan 20, 2007 10:36 am | |
| i think from DP back yours is the same, but iirc your crossover is different. i have never seen a 95's engine bay so i cant say for sure. also since the series 1 cant be heavily moded like the series 2 you may want to only do light exhaust mods (like a DP and T split to a Y) to avoid losing torque. as Aaron will tell you the manifolds and DP are most restrictive, but overall our exhaust can handle more than stock applications. (maybe up to about 270hp but thats just a WAG) _________________ 1996 with 254k miles, L32 4" FWI -> ported N* -> Ported Gen V w/3.0" Pulley, Stage 3 Phenolic I/C, ZZP FMHE, 1.84 RR, Headers and 3" pipe to mufflers, F-body brakes, and lowered on Eibachs. -RIP AMG C400 White on black. Stage 2 w/E30 - 11.9@117 -daily | |
jax95riv Aficionado
| Subject: Re: What's the stock exhaust consist of? Sat Jan 20, 2007 2:25 pm | |
| Thanks. I'm a little behind the learning curve...just trying to catch up. Did you install the headers yourself? The firewall side has got to be a nightmare! I guess it's impossible to run true duals. Ground clearance is probably a big issue... | |
| Subject: Re: What's the stock exhaust consist of? Sun Jan 21, 2007 12:11 am | |
| I think the exhaust is the same, and I would think the manifolds are also the same, but would need to research this. Imo, the stock exhaust is good for most minor to medium mods. I still use my stock exhaust from the headers back. I think it's good for well over 300 hp.
I wouldn't worry about loosing torque for a few reasons. For one, we have such a good bottom end, it takes quite a change to loose the torque. Also, you can make up for a big exhaust by dropping pulley size and opening up the engine (cam or rockers). Opening the exaust causes boost to go down. Once you build your boost back up, the torque should return. But even if you lost some low end torque, it's okay. We are already fighting for traction, and the Series one builds peak twist at even lower rpms than the Series II.
I installed the headers myself with the help of a friend and his garage. It was surprisingly easy to do. No nightmares! The SLPs I used lined up perfectly with the stock exhaust... no ground clearance issues. And no, true duals aren't an option, lol... _________________ '05 GTO 6.0L • 6-spd • 95k miles • 0-60: 4.8s • 16.9 avg MPG • Nelson Ledges Lap: 1:26'95 Celica GT 2.2L • 5-spd • 165k miles • 0-60: yes'98 SC Riviera • 281k miles • 298 HP/370 TQ • 0-60: 5.79s • ET: 13.97 @ 99.28 • 4087 lb • 20.1 avg MPG • Nelson Ledges Lap: 1:30 3.4" pulley • AL104 plugs • 180º t-stat • FWI w/K&N • 1.9:1 rockers • OR pushrods • LS6 valve springs • SLP headers • ZZP fuel rails KYB GR2 struts • MaxAir shocks • Addco sway bars • UMI bushings • GM STB • Enkei 18" EV5s w/ Dunlop DZ101s • F-body calipers EBC bluestuff/Hawk HP plus • SS lines • Brembo slotted discs • DHP tuned • Aeroforce • Hidden Hitch^^^ SOLD ^^^ '70 Ninety-Eight Holiday Coupe 455cid • 116k miles^^^ SOLD ^^^ | |
oldsman105 Junkie
| Subject: Re: What's the stock exhaust consist of? Wed Jan 31, 2007 5:34 pm | |
| The series 1 supercharged has uneven spacing on the exhaust manifolds. No series 2 headers will work with your application. You can port the EM's here is a link http://www.bonnevilleclub.com/forum/viewtopic.php?t=36232&highlight=porting | |
| Subject: Re: What's the stock exhaust consist of? Wed Jan 31, 2007 7:10 pm | |
| Good info! Thanks!!! _________________ '05 GTO 6.0L • 6-spd • 95k miles • 0-60: 4.8s • 16.9 avg MPG • Nelson Ledges Lap: 1:26'95 Celica GT 2.2L • 5-spd • 165k miles • 0-60: yes'98 SC Riviera • 281k miles • 298 HP/370 TQ • 0-60: 5.79s • ET: 13.97 @ 99.28 • 4087 lb • 20.1 avg MPG • Nelson Ledges Lap: 1:30 3.4" pulley • AL104 plugs • 180º t-stat • FWI w/K&N • 1.9:1 rockers • OR pushrods • LS6 valve springs • SLP headers • ZZP fuel rails KYB GR2 struts • MaxAir shocks • Addco sway bars • UMI bushings • GM STB • Enkei 18" EV5s w/ Dunlop DZ101s • F-body calipers EBC bluestuff/Hawk HP plus • SS lines • Brembo slotted discs • DHP tuned • Aeroforce • Hidden Hitch^^^ SOLD ^^^ '70 Ninety-Eight Holiday Coupe 455cid • 116k miles^^^ SOLD ^^^ | |
| Subject: Re: What's the stock exhaust consist of? | |
