| turn signal lense removal | |
+7AA Rivi Man 1998 Riv T Riley ZEP 99Rivman turtleman 11 posters |
| Subject: turn signal lense removal Sat Apr 28, 2007 2:51 pm | |
| Has anyone removed their front turn signal lens? I'm having some trouble with it. I can't really see what's actually holding it in | |
99Rivman Aficionado
| Subject: Re: turn signal lense removal Sun Apr 29, 2007 2:30 pm | |
| There are three clips that hold each one in from the back. I use two small screwdrivers and pry the clips apart and slide them off of the plastic tab. | |
ZEP Fanatic
| Subject: Turn Signal Lamp Removal Wed Feb 27, 2008 10:37 pm | |
| Anyone happen to know how to remove the orange turn signal lamps? I'm thinking of having them smoked soon. I just hate having a multitude of colors on my car (green, chrome, black, orange, red...).
I'm assuming I'd go through the fender cover. But I'm not totally sure. Anyone have experience? | |
T Riley Guru
| Subject: Re: turn signal lense removal Wed Feb 27, 2008 11:26 pm | |
| - ZEP wrote:
- Anyone happen to know how to remove the orange turn signal lamps? I'm thinking of having them smoked soon. I just hate having a multitude of colors on my car (green, chrome, black, orange, red...).
I'm assuming I'd go through the fender cover. But I'm not totally sure. Anyone have experience? go to your cornering lamp get on your knee's push down on the level part of the bumper underneath the corner light remove that bolt............... dunno what size it is... | |
| Subject: Re: turn signal lense removal Wed Feb 27, 2008 11:29 pm | |
| You're telling him to go thru the cornering lamp, to get to the orange turn signal lens? Don't know about that, but haven't done it myself.
I'd have to go look, but seems to me you'd get at it from underneath. Have you taken a close look under/behind the bumper to look for access? | |
T Riley Guru
| Subject: Re: turn signal lense removal Wed Feb 27, 2008 11:46 pm | |
| - 1998 Riv wrote:
- You're telling him to go thru the cornering lamp, to get to the orange turn signal lens? Don't know about that, but haven't done it myself.
I'd have to go look, but seems to me you'd get at it from underneath. Have you taken a close look under/behind the bumper to look for access? AH SHOOOOOOT................. i was talking about the CLEAR CORNER light RIGHT by the headlight MY MISTAKE IM SORRY | |
99Rivman Aficionado
| Subject: Re: turn signal lense removal Thu Feb 28, 2008 9:07 pm | |
| They are held on with spring clips from the back side of the light housing. There are three tabs on the inside of the bumper cover that they are attached to. I'm sure there is a special tool to remove the clips but I just used two small screw drivers to pry the clips apart and removed them from the tab, then the assembly slides off. Be very careful though the tabs are made of the same material as the bumper cover and the clips are made of steel, guess which one will win in a tug of war! I can get pictures if that would help, would probably be tomorrow though. | |
Rivi Man Special
| Subject: Re: turn signal lense removal Wed Apr 09, 2008 2:42 am | |
| I wish they had the turn signal lens in clear...I think it would really compliment the riviara more....if theres anyone out there that know where i can find them please notify me...Thanks! | |
99Rivman Aficionado
| Subject: Re: turn signal lense removal Wed Jul 02, 2008 4:45 pm | |
| Nice photos, thanks! _________________ '05 GTO 6.0L • 6-spd • 95k miles • 0-60: 4.8s • 16.9 avg MPG • Nelson Ledges Lap: 1:26'95 Celica GT 2.2L • 5-spd • 165k miles • 0-60: yes'98 SC Riviera • 281k miles • 298 HP/370 TQ • 0-60: 5.79s • ET: 13.97 @ 99.28 • 4087 lb • 20.1 avg MPG • Nelson Ledges Lap: 1:30 3.4" pulley • AL104 plugs • 180º t-stat • FWI w/K&N • 1.9:1 rockers • OR pushrods • LS6 valve springs • SLP headers • ZZP fuel rails KYB GR2 struts • MaxAir shocks • Addco sway bars • UMI bushings • GM STB • Enkei 18" EV5s w/ Dunlop DZ101s • F-body calipers EBC bluestuff/Hawk HP plus • SS lines • Brembo slotted discs • DHP tuned • Aeroforce • Hidden Hitch^^^ SOLD ^^^ '70 Ninety-Eight Holiday Coupe 455cid • 116k miles^^^ SOLD ^^^ | |
duster_do_little Enthusiast
Name : Dustin Age : 37 Location : Midland, MI Joined : 2008-11-15 Post Count : 171 Merit : 4
| Subject: Re: turn signal lense removal Sun Feb 22, 2009 4:30 pm | |
| Okay, so I'm a bit lost. My front driver turn signal burnt out. I opened the hood and no dice from in there. Then I got on my back and undid one of the pop rivets and pulled the bottom piece back and still can't really figure out how I'm supposed to reach up in there and get the old bulb out and the new one in.
Any help would be great. I've been putting off replacing it until decent weather and today was our first above freezing day in a couple weeks, but now I can't figure out how to do it :/ | |
| Subject: Re: turn signal lense removal Sun Feb 22, 2009 5:45 pm | |
| After you get the inner fender out of the way, just grasp teh bulb socket and twist it 1/4 turn. It's all plastic so it wiil turn without too much hassle. Bulb is a 168 or 194 IIRC. There is enough wire to the socket that once you get it out of the housing it will hang down pretty far, making it easy enough to replace the bulb.
99Rivman Aficionado
| Subject: Re: turn signal lense removal Sun Feb 22, 2009 8:55 pm | |
| Albert is right about pulling the inner fender out of the way, actually the "two" push pins that hold the very front lower part of it anyway. The “marker” light is a 194 bulb but if the problem is the “running/turn signal bulb”, it is either an 1157 or a 3057; I can't remember exactly which right this minute. That info is in the owners’ manual though. | |
| Subject: Re: turn signal lense removal Sun Feb 22, 2009 10:50 pm | |
| Thanks you are right, Randall - pretty sure the turn signal is 3057 - double-check in the bulb book at the parts store/Wal-Mart/Target/KMart/what have you.
| Subject: Re: turn signal lense removal Mon Feb 23, 2009 10:31 pm | |
| Well, it's the turn signal bulb, but I have a feeling that replacing it will only be a temp fix, because I have a hole in my lens cover and there's some snow in it. I would assume that's why it failed in the first place. Is it much harder to take the lens cover off to put a new one on?
I know this right up shows how to do it, but the pictures are with the bumper off, and I can't see myself getting in there to pry those metal clips off with the bumper on. | |
| Subject: Re: turn signal lense removal Mon Feb 23, 2009 11:13 pm | |
| try getting used t/s from Ed Morad.
99Rivman Aficionado
| Subject: Re: turn signal lense removal Wed Feb 25, 2009 7:25 pm | |
| If you pull the pins that hold the inner wheel well in and remove it, there is actually a fair amount of room. It can be done with the bumper on the car. You just have to use a tool that will get you in there and also be able to pry the clips apart. | |
| Subject: Re: turn signal lense removal Thu Feb 26, 2009 8:12 am | |
| - 99Rivman wrote:
- If you pull the pins that hold the inner wheel well in and remove it, there is actually a fair amount of room. It can be done with the bumper on the car. You just have to use a tool that will get you in there and also be able to pry the clips apart.
Okay, thanks. I'll embark on it this weekend, weather permitting. | |
texasfan010 Enthusiast
| Subject: HELP Thu Apr 23, 2009 1:33 am | |
| My front marker light is out on the passenger side of my car, I dont know how to get to the bulb, do i have to go in through the fender or what? Anybody have pictures or instructions to help me out? | |
| Subject: Re: turn signal lense removal Thu Apr 23, 2009 6:15 am | |
| jack up the right side of the car , partially remove the dust cover at the underneath of the car at the front or remove completly,it makes the job easier,reach up and remove bulb ,instal new one ,replace cover....... | |
| Subject: Re: turn signal lense removal | |
