Name : scott Location : madison, al Joined : 2008-03-15Post Count : 375 Merit : 52
Subject: side mirror turn signal Sat May 16, 2009 7:05 pm
I have been wanting to add turn signals to my side mirrors. I finally started today. I got some mirrors with turn signals from ebay and started to hack them up. I cut the section out with the led light. Then cut a matching section in the rivi mirror housing. I then bonded the two pieces together with epoxy then smoothed with plastic filler. They are just roughed in, as you can see in the pictures it started to rain so this is as far as I got with the project. I have to get this done before I get the car painted. I will post more pics as the project progresses.
Subject: Re: side mirror turn signal Sat May 16, 2009 11:59 pm
I wonder if a Hella repeater or a clearance light would work?
sqrivi Fanatic
Subject: Re: side mirror turn signal Sun May 17, 2009 12:05 am
There is a decent amount of room in the housing. I will try to get a picture of the cavity behind the motor when it stops raining.
sburch23 Addict
Name : Scott Location : Roswell, GA Joined : 2007-04-02Post Count : 547 Merit : 14
Subject: Re: side mirror turn signal Sun May 17, 2009 1:36 pm
Very Cool!!!
What about a pointer behind the mirror. I have seen these on some cars. I would not want to give up the dimmer or heated feature that I have now.
Also, could you post a close up of the wheels?
Subject: Re: side mirror turn signal Sun May 17, 2009 4:35 pm
That looks like a good fit. What are the mirrors from?
sqrivi Fanatic
Subject: Re: side mirror turn signal Sun May 17, 2009 6:46 pm
I didn't lose any function of the mirror. Here is the mirror I bought.
Man I envy you every thing about your car is what I have in images in my brain of mines but I can't get right for nothing
Subject: Re: side mirror turn signal Tue Jan 07, 2014 2:26 am
I love the mirror turn signal ...but how do u connect it...(where)
matt270avian Expert
Name : Matt Age : 28 Location : Frederick, MD Joined : 2012-01-15Post Count : 2681 Merit : 54
Subject: Re: side mirror turn signal Tue Jan 07, 2014 11:42 am
You run the wires to the turn signal circuit. The simplest way would be to tie them into the lights themselves, but there has to be a point that you could tie into between them and the stalk on the steering column.
sall Member
Name : sall Location : WBGV Joined : 2013-08-04Post Count : 55 Merit : 0
Subject: Re: side mirror turn signal Mon Mar 31, 2014 9:07 am
Did you ever get these painted and get some pictures?
matt270avian Expert
Subject: Re: side mirror turn signal Mon Mar 31, 2014 9:40 am
sqrivi hasn't been active for awhile now unfortunately.
ZEP Fanatic
Name : Zach Joined : 2007-12-24Post Count : 498 Merit : 11
Subject: Re: side mirror turn signal Tue Apr 01, 2014 8:33 pm
Subject: Re: side mirror turn signal Wed Apr 02, 2014 1:38 pm
Hey, thanks! One of the few remaining things I would like to do to my Aurora.
Subject: Re: side mirror turn signal Wed Apr 02, 2014 3:54 pm
Park Ave. has them turn signal mirrors....I also want'em on my Riv...... but don't know how/where to connect them byaha...
al_roethlisberger Junkie
Name : Al Roethlisberger Age : 55 Location : Sanford, NC Joined : 2013-03-12Post Count : 960 Merit : 24
Subject: Re: side mirror turn signal Wed Apr 02, 2014 5:33 pm
What year(s) PA have the integrated turn signals in the mirrors? I assume you mean in the glass?
sall Member
Subject: Re: side mirror turn signal Wed Apr 02, 2014 5:45 pm
Integrating the LEDs behind the glass is simple like video posted on the first page. Except those kits will have low daylight visibility and questionable build quality.
It's as simple asrouting to the turn signl stalk and have 12v hot at all times or simply tap in after LCM or at the sidemarker/front turn signal wiring.
Subject: Re: side mirror turn signal Wed Apr 02, 2014 5:59 pm
