| Subject: Tiny Tuner Editor Thu Feb 03, 2011 10:47 am | |
| This has been around for a little while, but I haven't used it yet. However, a friend of mine has. He showed it to me and so far I'm amazed at what it can do! Much, much, much more parameter coverage than HPT, and you can use it with DHP PowrTuner. http://theblattners.com/Projects/TinyTuner/default.html If this can be shown to work with a Riviera BIN (it should), owners of DHP can feel more comfortable knowing those who spent more on HPT software really didn't get any more tuning parameters - you actually get the same capability when you use TTEditor + DHP or TTEditor + HPT. I plan to try it out sometime in the future, but not much time for it right now - so if anyone wants to give it a run, good luck! _________________ '05 GTO 6.0L • 6-spd • 95k miles • 0-60: 4.8s • 16.9 avg MPG • Nelson Ledges Lap: 1:26'95 Celica GT 2.2L • 5-spd • 165k miles • 0-60: yes'98 SC Riviera • 281k miles • 298 HP/370 TQ • 0-60: 5.79s • ET: 13.97 @ 99.28 • 4087 lb • 20.1 avg MPG • Nelson Ledges Lap: 1:30 3.4" pulley • AL104 plugs • 180º t-stat • FWI w/K&N • 1.9:1 rockers • OR pushrods • LS6 valve springs • SLP headers • ZZP fuel rails KYB GR2 struts • MaxAir shocks • Addco sway bars • UMI bushings • GM STB • Enkei 18" EV5s w/ Dunlop DZ101s • F-body calipers EBC bluestuff/Hawk HP plus • SS lines • Brembo slotted discs • DHP tuned • Aeroforce • Hidden Hitch^^^ SOLD ^^^ '70 Ninety-Eight Holiday Coupe 455cid • 116k miles^^^ SOLD ^^^ | |
| Subject: Re: Tiny Tuner Editor Fri Feb 04, 2011 12:35 am | |
| I used this software a little bit on my car. It definitely has more editables than the DHP and HPT software does. AFAIK you cannot use HPtuners to upload bin files created by tinytuner though. It has problems resolving the license keys and stuff from bin files sometimes. You can look at exported txt tables from hpt with it but basically if you have HPT, you're stuck with HPT software. I'd be happier than a fag in jail if someone shows me that I'm wrong about that though. | |
