| Tensioner question (Series I SC) | |
adri Amateur
Name : adri(95S1SC) Location : Athens, OH Joined : 2011-10-26 Post Count : 37 Merit : 1
| Subject: Tensioner question (Series I SC) Wed Oct 26, 2011 12:35 am | |
| hi yall. im new here so im nervous..anyway im just gonna cut to the chase. the bolt on my tensioner broke while trying to change the pulley, but now i think ill have to replace the whole assembly (i prefer to), but seeing that im new all round to this i dont even know what assembly to purchase. i pulled it out from the car. its the assembly directly under the alternator. what is that tensioner assembly called? I have a 1995 Riv Supercharged. i also looked on amazon but cant figure out what to purchase. i saw one that said 'Serpentine-Exc w/supercharger. is it this what i should get? please help!! | |
| Subject: Re: Tensioner question (Series I SC) Wed Oct 26, 2011 12:43 pm | |
| Hi, You are correctly looking for the part called a tensioner or belt tensioner. Try rockauto.com, they have an excellent parts lookup guide and list specifically for each engine. Amazon's part finder is not that useful.
adri Amateur
| Subject: Re: Tensioner question (Series I SC) Wed Oct 26, 2011 8:00 pm | |
| Ok. im making a bit of progress cause i got the broken bolt drilled out and the hole rethreaded, so now its to find the bolt to hold the pulley. i will still check out the site though to see what they got. thanks much!! i hope i get the bolt tomorrow so i can put this part back on asap. | |
adri Amateur
| Subject: Re: Tensioner question (Series I SC) Sun Oct 30, 2011 9:01 pm | |
| well we got the tentioner put on and everything, but now the elbow, or the place where the elbow goes ino is leaking the antifreeze out. i think i may need an o ring or something. | |
| Subject: Re: Tensioner question (Series I SC) Sun Oct 30, 2011 9:38 pm | |
adri Amateur
| Subject: Re: Tensioner question (Series I SC) Mon Oct 31, 2011 8:11 am | |
| yes robotennis(funny name) , the eblow is plastic. i dont think that the elbow is busted, even though i did hear that they do that from time to time, but i dnt know. me and my father in law are thinking that we didnt put enough/the correct sealing around the elbow before fitting it in. we used some gasket sealer..but we plan on using something that would be alot more suitable for that holding purpose. so sometime this wee we will take out the pulley assembly again and get some better stuff for that elbow. PS: after changing my pulley and got the belt back on and such it keeps making squeaking sounds. does anyone know why? because everything seems fine. i feel like a dork asking all kinds of questions | |
| Subject: Re: Tensioner question (Series I SC) Mon Oct 31, 2011 11:20 am | |
| could be the water pump is going,or the alternator bearing is failing....my 95s alternator bearing is shot.but still works. | |
adri Amateur
| Subject: Re: Tensioner question (Series I SC) Mon Oct 31, 2011 6:09 pm | |
| i dont think the water pump is going cause the coolant is leaking from the bottom side of the elbow. we even seen it spray from there. we probably need to look at that alternator bearing to make sure. hopefully we can look at it tomorrow if its as nice as today. | |
| Subject: Re: Tensioner question (Series I SC) Mon Oct 31, 2011 6:22 pm | |
| get rid of the plastic elbow while yer there.they do and will fail.i
f you pop off the belts and spin each pully,if yer lucky you'll find the squeek. but it ant allways so evident | |
adri Amateur
| Subject: Re: Tensioner question (Series I SC) Mon Oct 31, 2011 6:42 pm | |
| i guess they have metal elbows? i wonder if advanced auto has any? ill have to check. the squeak sounds like its coming from the tentioner bu it spins perfect. im wondering if i should spray some doube D forty on them pulleys to u know, get em lubricated. what do you think? | |
| Subject: Re: Tensioner question (Series I SC) Mon Oct 31, 2011 7:01 pm | |
| - Quote :
- PS: after changing my pulley and got the belt back on and such it keeps making squeaking sounds. does anyone know why? because everything seems fine. i feel like a dork asking all kinds of questions
If the sound is a "chirp-chirp-chirp", it could be the tensioner itself, not a pulley. Try applying force to the tensioner with a ratchet while the engine is running. If the squeak goes away, it's the tensioner. _________________ '05 GTO 6.0L • 6-spd • 95k miles • 0-60: 4.8s • 16.9 avg MPG • Nelson Ledges Lap: 1:26'95 Celica GT 2.2L • 5-spd • 165k miles • 0-60: yes'98 SC Riviera • 281k miles • 298 HP/370 TQ • 0-60: 5.79s • ET: 13.97 @ 99.28 • 4087 lb • 20.1 avg MPG • Nelson Ledges Lap: 1:30 3.4" pulley • AL104 plugs • 180º t-stat • FWI w/K&N • 1.9:1 rockers • OR pushrods • LS6 valve springs • SLP headers • ZZP fuel rails KYB GR2 struts • MaxAir shocks • Addco sway bars • UMI bushings • GM STB • Enkei 18" EV5s w/ Dunlop DZ101s • F-body calipers EBC bluestuff/Hawk HP plus • SS lines • Brembo slotted discs • DHP tuned • Aeroforce • Hidden Hitch^^^ SOLD ^^^ '70 Ninety-Eight Holiday Coupe 455cid • 116k miles^^^ SOLD ^^^ | |
adri Amateur
| Subject: Re: Tensioner question (Series I SC) Mon Oct 31, 2011 7:16 pm | |
| yeah it is an occasional chirp...ok im going to try that, because i already got a replacement pulley because the previous one have a dreadful squeak to it, so we thought that it may have had bad bearing in it. | |
| Subject: Re: Tensioner question (Series I SC) Mon Oct 31, 2011 9:10 pm | |
- Quote :
If the sound is a "chirp-chirp-chirp", it could be the tensioner itself, not a pulley. Try applying force to the tensioner with a ratchet while the engine is running. If the squeak goes away, it's the tensioner. Great tip! I never thought of that? why dont I ever think of these things? sometimes I dont think I can think at all! | |
| Subject: Re: Tensioner question (Series I SC) Mon Oct 31, 2011 9:12 pm | |
| Just watch those knuckles!!! _________________ '05 GTO 6.0L • 6-spd • 95k miles • 0-60: 4.8s • 16.9 avg MPG • Nelson Ledges Lap: 1:26'95 Celica GT 2.2L • 5-spd • 165k miles • 0-60: yes'98 SC Riviera • 281k miles • 298 HP/370 TQ • 0-60: 5.79s • ET: 13.97 @ 99.28 • 4087 lb • 20.1 avg MPG • Nelson Ledges Lap: 1:30 3.4" pulley • AL104 plugs • 180º t-stat • FWI w/K&N • 1.9:1 rockers • OR pushrods • LS6 valve springs • SLP headers • ZZP fuel rails KYB GR2 struts • MaxAir shocks • Addco sway bars • UMI bushings • GM STB • Enkei 18" EV5s w/ Dunlop DZ101s • F-body calipers EBC bluestuff/Hawk HP plus • SS lines • Brembo slotted discs • DHP tuned • Aeroforce • Hidden Hitch^^^ SOLD ^^^ '70 Ninety-Eight Holiday Coupe 455cid • 116k miles^^^ SOLD ^^^ | |
adri Amateur
pbrktrt Enthusiast
| Subject: Re: Tensioner question (Series I SC) Tue Nov 01, 2011 7:40 am | |
| adri, just do it right and do it once. NAPA part # 6601745 and it's $5.00. | |
| Subject: Re: Tensioner question (Series I SC) Tue Nov 01, 2011 8:51 am | |
| magic potions only work in fairy land. in the real world busted knuckles and sore backs get things done | |
pbrktrt Enthusiast
| Subject: Re: Tensioner question (Series I SC) Tue Nov 01, 2011 8:10 pm | |
| So true Robo, so true. Excepting Seafoam, that is. | |
| Subject: Re: Tensioner question (Series I SC) Tue Nov 01, 2011 9:31 pm | |
| Seafoam? if u got a clogged cat,the only clearing youll get is a blown head gasket | |
adri Amateur
| Subject: Re: Tensioner question (Series I SC) Fri Dec 02, 2011 3:41 pm | |
| I have to say thanks for all the people who put in their time and tid bits on helping me with this problem. | |
| Subject: Re: Tensioner question (Series I SC) | |
