 Oil Level Sensor Orientation ?
Natesriv
Natesriv
Oil Level Sensor Orientation ? Empty
PostSubject: Oil Level Sensor Orientation ?   Oil Level Sensor Orientation ? EmptyFri Feb 24, 2012 1:09 pm
Hey, I'm puting in a new oil pan. The oil level sensor is in that yellowish cone, but there appears to be two optical sensors on the end of the flat circuit board in there...on both sides...
But is there a definate up position? Should the sensor be "up" or does it even matter?
Thanks!
N
Natesriv
Natesriv
PostSubject: Re: Oil Level Sensor Orientation ?   Oil Level Sensor Orientation ? EmptyFri Feb 24, 2012 5:46 pm
it's also possible, that once it's tight, it's in the right orientation...if they put the pattern of the screw on the part...
guess I'll find out smile
UPDATE:
Yup it just scews in and gets tight where it gets tight...period. Mine is now sideways, but no lights so all good.
Oil Level Sensor Orientation ? Standard
» Check Oil Level Light/Sensor
» coolant level sensor removal??
» FAQ: P0341 Camshaft Position Sensor (Cam Sensor / Timing Chain)
» MAF sensor and crankshaft sensor
