 Supercharger Belt Moving
4 posters
Merit : 20
Supercharger Belt Moving Empty
PostSubject: Supercharger Belt Moving   Supercharger Belt Moving EmptyFri May 18, 2012 10:23 pm
I replaced my supercharger belt about 2 months ago and ever since it likes to walk about 1/3 the way off the idler pulley. Before it move towards the drivers side and I wouldn't have a problem with it. Now when I put the belt on the inner ribs of the pulley, it'll jump to the outer ribs and part of it will be off of the idler pulley. It worries me as I don't want it to slip off while I'm going down the road. Also, when I move it to the inner ribs the belt will squeak until it fixes itself. Anybody got any ideas?
PostSubject: Re: Supercharger Belt Moving   Supercharger Belt Moving EmptySat May 19, 2012 12:25 am
From the front, look under the car and verify the belt is correctly seated on the crank pulley:
Supercharger Belt Moving Belts
Merit : 180
PostSubject: Re: Supercharger Belt Moving   Supercharger Belt Moving EmptySat May 19, 2012 12:33 am
The idler or tensioner pulley, maybe both, need replaced. Easy way to do that is get a replacement tensioner from rockauto.com.
If you tap the pulley along the axis it probably moves in and out. Bearing is shot.
Merit : 20
PostSubject: Re: Supercharger Belt Moving   Supercharger Belt Moving EmptySat May 19, 2012 3:15 pm
It's on the crank pulley correctly. That was the first thing I checked. I'll check the other pulleys.
PostSubject: Re: Supercharger Belt Moving   Supercharger Belt Moving EmptySat May 19, 2012 4:12 pm
I do know if you're running an INTENSE hub with INTENSE pulley, the belt should use the innermost grooves for best alignment. Did you change anythjng else when you did the belts? How did the old belt look?
PostSubject: Re: Supercharger Belt Moving   Supercharger Belt Moving EmptySat May 19, 2012 4:42 pm
yup check those pulleys
Merit : 180
PostSubject: Re: Supercharger Belt Moving   Supercharger Belt Moving EmptySun May 27, 2012 6:44 pm
BUMP what was it?
» Supercharger belt
» FAQ: Chirp Chirp Chirp - Belt Squeal, Pulley & Tensioner Squeak
» Any danger on driving without SC belt on?
» Write-Up: Replacing Supercharger Belt Tensioner
» What kind of belt does a 1997 Buick Riviera none supercharger?
