Pipes Member
Name : Pipes Age : 40 Location : Pa Joined : 2011-12-11 Post Count : 80 Merit : 0
| Subject: rear exhaust manifold gasket Tue Jul 17, 2012 10:18 am | |
| Os there a way to chamge rear mani without pillong the motor?[list=1][*] | |
RidzRiv Addict
| Subject: Re: rear exhaust manifold gasket Tue Jul 17, 2012 11:24 am | |
| You would probably have to move the wiring harness and all of the other things that get in the way of the rear valve cover to pull it up from the engine bay. | |
| Subject: Re: rear exhaust manifold gasket Tue Jul 17, 2012 1:26 pm | |
| Absolutely, you can remove it, but you may need to remove the crossover pipe and front manifold as well. Those aren't really that bad. Use lots of PB Blaster, the nuts will break loose. _________________ '05 GTO 6.0L • 6-spd • 95k miles • 0-60: 4.8s • 16.9 avg MPG • Nelson Ledges Lap: 1:26'95 Celica GT 2.2L • 5-spd • 165k miles • 0-60: yes'98 SC Riviera • 281k miles • 298 HP/370 TQ • 0-60: 5.79s • ET: 13.97 @ 99.28 • 4087 lb • 20.1 avg MPG • Nelson Ledges Lap: 1:30 3.4" pulley • AL104 plugs • 180º t-stat • FWI w/K&N • 1.9:1 rockers • OR pushrods • LS6 valve springs • SLP headers • ZZP fuel rails KYB GR2 struts • MaxAir shocks • Addco sway bars • UMI bushings • GM STB • Enkei 18" EV5s w/ Dunlop DZ101s • F-body calipers EBC bluestuff/Hawk HP plus • SS lines • Brembo slotted discs • DHP tuned • Aeroforce • Hidden Hitch^^^ SOLD ^^^ '70 Ninety-Eight Holiday Coupe 455cid • 116k miles^^^ SOLD ^^^ | |
RidzRiv Addict
| Subject: Re: rear exhaust manifold gasket Tue Jul 17, 2012 1:28 pm | |
| In order to remove the crossover you will need to remove the nuts that hold the heat shield and power steering to the engine. It may help to remove the throttle body as well. | |
RidzRiv Addict
| Subject: Re: rear exhaust manifold gasket Tue Jul 17, 2012 1:34 pm | |
| This picture may help. This is with the throttle body removed on my series 1. | |
| Subject: Re: rear exhaust manifold gasket Tue Jul 17, 2012 1:54 pm | |
| removing the rear manifold on a 95 is a snap.all you have to do is remove the rectangular vacum box that is in the center of the engine bay attached to the firewall.once you remove that you can loosen the bolts to the crossover pipe then the manifold bolts and wiggle the mani out from the top.Ive done it a hundred times. | |
RidzRiv Addict
| Subject: Re: rear exhaust manifold gasket Tue Jul 17, 2012 2:22 pm | |
| So it must be much easier to remove than the rear valve cover. | |
Pipes Member
| Subject: Re: rear exhaust manifold gasket Tue Jul 17, 2012 2:53 pm | |
| Thank everyone going to get it done when i get off work | |
| Subject: Re: rear exhaust manifold gasket | |
