| FAQ: P0171 Lean Condition | |
+7Abaddon Johnny5 deekster_caddy AA h20man robotennis61 manofmany 11 posters |
Johnny5 Fanatic
Name : Going Nowhere Fast Age : 37 Location : Louisiana Joined : 2013-09-11 Post Count : 459 Merit : 1
 | Subject: Re: FAQ: P0171 Lean Condition Tue Nov 05, 2013 10:48 pm | |
| I have done all my own work im just at the point where im fighting to keep gas in the car its getting sickening when im putting in 65 dollars before next payday ... I took it to the guy to see if he had a fuel pressure tester and he came up with that idea... im not much of a mechanical kind of person but I do what I have too...but I did just check the egr and the issue lies between there im guessing I spike at egr and at the manifold where the egr hose goes too so im stuck | |
Johnny5 Fanatic
 | Subject: Re: FAQ: P0171 Lean Condition Wed Nov 06, 2013 2:46 am | |
| I just sprayed the bottom of the egr, and the car damn near wanted to cut off. so the egr is sucking in plenty of air. thus this shows me shows me I still have leaks in the system thanks guys | |
h20man Enthusiast
Name : Aaron W. Age : 29 Location : CT Joined : 2013-10-04 Post Count : 242 Merit : -2
 | Subject: Re: FAQ: P0171 Lean Condition Wed Nov 06, 2013 11:32 pm | |
| well my egr pipe should be here soon, im using that gasket idea for sure when it arrives ,i also picked up a maf sensor for a good price if this doesnt clear the code then im stumped | |
Johnny5 Fanatic
 | Subject: Re: FAQ: P0171 Lean Condition Thu Nov 07, 2013 2:41 am | |
| - h20man wrote:
- well my egr pipe should be here soon, im using that gasket idea for sure when it arrives ,i also picked up a maf sensor for a good price if this doesnt clear the code then im stumped
what site did you order the egr pipe from | |
h20man Enthusiast
 | Subject: Re: FAQ: P0171 Lean Condition Thu Nov 07, 2013 7:23 am | |
h20man Enthusiast
 | Subject: Re: FAQ: P0171 Lean Condition Sun Nov 10, 2013 5:31 pm | |
| Alright guys I'm really stumped, I changed my egr pipe and mass air flow sensor and the p0171 set, I even changed my intake back to the stock airbox and it set... So any ideas would be very much appreciated or if anyone knows how to fool the obd emissions test before I pay a shop to diagnose the problem .... | |
96_Juggernaut Fanatic
Name : Todd Balestrini Age : 40 Location : Beaufort S.C. Joined : 2013-07-08 Post Count : 293 Merit : 5
 | Subject: Re: FAQ: P0171 Lean Condition Sun Nov 10, 2013 7:03 pm | |
| I assume you cleared the code after changing the erg and mass sensor? | |
 | Subject: Re: FAQ: P0171 Lean Condition Sun Nov 10, 2013 7:07 pm | |
h20man Enthusiast
 | Subject: Re: FAQ: P0171 Lean Condition Sun Nov 10, 2013 7:54 pm | |
| - 96_Juggernaut wrote:
- I assume you cleared the code after changing the erg and mass sensor?
yup cleared them before starting it and deekster yes I sprayed starting fluid on the vacumn lines and found a leak in the egr pipe, replaced that still getting a code | |
h20man Enthusiast
 | Subject: Re: FAQ: P0171 Lean Condition Mon Dec 02, 2013 10:29 pm | |
| i havent updated this in a while but yes i still have the code. i went through and replaced my intake gaskets and blower gaskets again and it still set the light. Whats funny is the code only sets at a stop or when im braking, today going back to work after lunch my brakes let go, the pedal went to the floor but i was still able to stop thankfully. long story short we decided i need a master cylinder, maybe im going nuts but im making some sort of connection to failing brakes which obviously operate on vacuum and my p0171 code | |
 | Subject: Re: FAQ: P0171 Lean Condition Mon Dec 02, 2013 10:32 pm | |
| the brakes will still function without vacuum, the vacuum just "assists" with making the pedal easier to push. | |
h20man Enthusiast
 | Subject: Re: FAQ: P0171 Lean Condition Mon Dec 02, 2013 11:43 pm | |
| But do you think a leak coming from the brake system is triggering a lean code? | |
 | Subject: Re: FAQ: P0171 Lean Condition Mon Dec 02, 2013 11:54 pm | |
| - h20man wrote:
- But do you think a leak coming from the brake system is triggering a lean code?
now that on the other hand could, I would imagine if the brake booster itself had a leak it could pull in the extra air. | |
 | Subject: Re: FAQ: P0171 Lean Condition Tue Dec 03, 2013 3:28 pm | |
| The brake booster is vacuum actuated. If the booster diaphragm had a leak that would be your vacuum leak. Try disconnecting the brake booster and capping the opening, see if your code goes away. (your brakes will be non-power assist, watch out! Actually I can't recommend this, but it would answer the question)
Instead, try spraying a little carb/brake cleaner around the booster and see if it affects the way your engine runs. | |
h20man Enthusiast
 | Subject: Re: FAQ: P0171 Lean Condition Tue Dec 03, 2013 9:36 pm | |
| Ill have to try that thanks guys, I did plug the booster hose in hopes of driving it around trying to see if the code will set but my master cylinder is bad so I really didn't have any brakes at all :/ | |
Name : Larry Age : 66 Location : Oakland Gardens, NY Joined : 2007-01-23 Post Count : 2170 Merit : 149
 | Subject: Re: FAQ: P0171 Lean Condition Wed Dec 04, 2013 8:09 pm | |
| Without the booster, the brake pedal will be hard as a rock, and you will have very little braking. That is normal _________________ 98 Riviera SC3800 Â All stock except gutted air box. 1970 Buick GS455 Stage1, TSP built 470BBB, 602HP/589TQ Best MPH, 116.06 MPH, Best ET, 11.54 https://www.youtube.com/watch?v=UHCda-t_Jls https://www.youtube.com/watch?v=sfT2tEO4XcU
h20man Enthusiast
 | Subject: Re: FAQ: P0171 Lean Condition Thu Dec 05, 2013 9:20 am | |
| I replaced my master cylinder so I just need to bleed all four brakes and the car will be back on the road, I'm talking to a guy from sinister performance who is kindly helping me diagnose this problem, he said check for exhaust leaks and he thinks I got the wrong maf sensor. Any way to check for exhaust leaks besides listening? | |
 | Subject: Re: FAQ: P0171 Lean Condition Thu Dec 05, 2013 9:28 am | |
| Ummm...the only kind of exhaust leak that can possibly cause a P0171 code is if the leak is before the control O2 sensor (manifold, crossover pipe). You would most definitely hear a leak like that if it were big enough to actually cause a code to be tossed.... | |
h20man Enthusiast
 | Subject: Re: FAQ: P0171 Lean Condition Thu Dec 05, 2013 9:58 am | |
| oh ok, than exhaust is ruled out ive never heard any leaks in my system, i asked to send my pcm to sinister so he can remove this code permenantly and do a standard tune, could that force my car to run lean even if he adds more fuel my tune? car seems to run great as is until the code sets, then the idle gets choppy | |
 | Subject: Re: FAQ: P0171 Lean Condition Thu Dec 05, 2013 10:01 am | |
| That, is a terrible idea. P0171 is there to protect the car. The circumstances for a lean condition can potentially grenade your engine. If it runs lean enough, say bye bye to the tops of the pistons. Lean, along with heat, is exactly what creates spark knock. You seriously need to figure out why it's running lean before you go modding anything.
There is obviously a problem, somewhere. Just because it isn't obvious doesn't mean it doesn't exist. P0171 code can be a bitch to diagnose sometimes. It's like trying to hunt down a ghost. But, you need to find this ghost and get rid of it for your engines sake. | |
Johnny5 Fanatic
 | Subject: Re: FAQ: P0171 Lean Condition Thu Dec 05, 2013 11:28 am | |
| Ahhh the infamous p0171 tricky bs little thing makes headaches worth while... | |
h20man Enthusiast
 | Subject: Re: FAQ: P0171 Lean Condition Thu Dec 05, 2013 12:24 pm | |
| I've literally spent about a grand diagnosing this problem, I really have no clue what It can be anymore | |
 | Subject: Re: FAQ: P0171 Lean Condition Thu Dec 05, 2013 12:52 pm | |
| Well, it appears you're at your limits. If I were you, I would take the vehicle in to a trusted shop, maybe even the dealer, and tell them what's going on, and what you've done/replaced. At this point, I really don't think you have any other options. It needs to be right before you start modding. | |
Johnny5 Fanatic
 | Subject: Re: FAQ: P0171 Lean Condition Thu Dec 05, 2013 1:57 pm | |
| Aww nah a grand thats almost impossible ... not unless you bought a new motor damn. Its time for some automotive maintenance help dude | |
 | Subject: Re: FAQ: P0171 Lean Condition Fri Dec 06, 2013 9:22 am | |
| - Abaddon wrote:
- That, is a terrible idea. P0171 is there to protect the car. The circumstances for a lean condition can potentially grenade your engine. If it runs lean enough, say bye bye to the tops of the pistons. Lean, along with heat, is exactly what creates spark knock. You seriously need to figure out why it's running lean before you go modding anything.
This is the most important paragraph in this entire discussion. DO NOT disable the P0171. Find it and fix it. | |
 | Subject: Re: FAQ: P0171 Lean Condition  | |
