 Can you hear the recirc door open and close?
carguy8888
6 posters
carguy8888
carguy8888
Can you hear the recirc door open and close? Empty
PostSubject: Can you hear the recirc door open and close?   Can you hear the recirc door open and close? EmptyFri Jul 24, 2020 5:10 pm
I'm wondering if my recirc door is not moving? When I hit the recirc button it lights up and I hear the chime but I don't hear a door closing under the dash. Should I hear anything to know when it switches to recirculate mode?
PostSubject: Re: Can you hear the recirc door open and close?   Can you hear the recirc door open and close? EmptySat Jul 25, 2020 1:42 am
It's a Buick.  You shouldn't be hearing that stuff unless the modules are worn out.
Mine doesn't chime though - must have been added after 97.
DeepFrozen
PostSubject: Re: Can you hear the recirc door open and close?   Can you hear the recirc door open and close? EmptySat Jul 25, 2020 9:03 am
When I hit the RECIRC button, I can hear how the quiet "whoosh" of the air gradually changes (it takes 2-3 seconds), so I know for sure the door is moving. Although I can't hear the door or actuator itself.
And yes, any button does chime.
carguy8888
carguy8888
PostSubject: Re: Can you hear the recirc door open and close?   Can you hear the recirc door open and close? EmptySat Jul 25, 2020 9:05 am
I did try and listen to the change in air noise. I will listen again today because it's supposed to be blistering. The chyme is a setting I believe in the personal choice features.
PostSubject: Re: Can you hear the recirc door open and close?   Can you hear the recirc door open and close? EmptySat Jul 25, 2020 4:45 pm
I'd kinda like to hear the chime now.
edit - now that I think about it, mine chimes too. It's been a while since I've used it.
carguy8888
carguy8888
PostSubject: Re: Can you hear the recirc door open and close?   Can you hear the recirc door open and close? EmptySun Jul 26, 2020 2:50 pm
I keep my chime on as well.
Rivieraz
Rivieraz
PostSubject: Re: Can you hear the recirc door open and close?   Can you hear the recirc door open and close? EmptyMon Jul 27, 2020 12:38 am
should my 95 chime?
urbanski_m
PostSubject: Re: Can you hear the recirc door open and close?   Can you hear the recirc door open and close? EmptySat Aug 01, 2020 8:14 pm
The other day I tried the RECIRC feature for the first time in 7 years on my 97, I did hear a chime but I did not hear an actuator or change in fan speed. Also the temp coming out of the vents did not change either as is the case in my other cars. I have been using a temp gauge in my vents this summer as it has been unusually hot with a number of "heat waves" and am checking the performance of AC in all my cars at various settings. My Riv is blowing around a consistent 35 degrees which is great!
carguy8888
carguy8888
PostSubject: Re: Can you hear the recirc door open and close?   Can you hear the recirc door open and close? EmptySun Aug 02, 2020 1:21 pm
That is colllld. Good to know you did not hear any noise or change which is the same for me.
PostSubject: Re: Can you hear the recirc door open and close?   Can you hear the recirc door open and close? EmptySun Aug 02, 2020 9:29 pm
IIRC the air conditioner automatically goes into recirc mode if it's hotter than a certain temperature, when you first turn it on. Details in the service manual.
carguy8888
carguy8888
PostSubject: Re: Can you hear the recirc door open and close?   Can you hear the recirc door open and close? EmptyMon Aug 03, 2020 5:47 pm
Had no idea, what a smart car. Thanks Albert.
» hello there I need help finding the name of the close door part
» So my asshole buddy cant close a door properly.
» FAQ: Power Door Lock Problems
» open door switch
» Write-Up: Fixing Outside Door Handle
