 Need Passenger Door Climate Controls
2 posters
Yardley
Need Passenger Door Climate Controls Empty
PostSubject: Need Passenger Door Climate Controls   Need Passenger Door Climate Controls EmptyFri Sep 25, 2020 10:45 am
Does anyone have a set of these? My lower dial no longer illuminates and I would like it to.
Need Passenger Door Climate Controls Pass_c10
http://www.1badriv.com
Yardley
PostSubject: Re: Need Passenger Door Climate Controls   Need Passenger Door Climate Controls EmptyFri Sep 25, 2020 11:02 am
Jeezis. There's a thousand of them on ebay. Thanks.
PostSubject: Re: Need Passenger Door Climate Controls   Need Passenger Door Climate Controls EmptyFri Sep 25, 2020 7:34 pm
Actually, it's pretty easy to simply replace the bulb(s) once you remove the control from the door panel. They are very similar to the bulbs in the main climate control - the climate control write up tells you what color and where to get the lacquer to paint the bulbs with as well as the bulbs, and how to replace them on a printed circuit board.  When you take the door controller apart (it's obvious) you'll easily access the board.   I did it to mine last year. I was embarrassed to learn I had a bulb in there that never did work for the time I owned the car - fixed! I just replaced them all I think there were two or three. Once you have the controller off the door panel it might take you the same or less time to replace a bulb than it did to read this post.
