Translation of title above headers & rocker install.
$h!† do I need this
this can't be good
Next day
coming together
Temporarily together for an exhaust shop to weld in the missing pieces that are on order
[img]https://2img.net/h/i20.photobucket.com/albums/b246/billboost37/Mini%20Meet/IMG_2341.jpg
all done (sort of)
Next up....better oil pan
first start up
The pulley that is making noise in the video was replaced
Rockers were straight forward no pics were taken I installed ZZP reworked 1.9 rockers and 105 springs.
Notes on headers
One: The header crossover pipe comes dangerously close to the transmission harness conntector. I will be wrapping that area with header wrap to protect the connector.
Two: The o2 harness connector on the 96 is diffrent from the 97 + series 2 I had to cut the connector of the car and put a newer square connector so I could use the extension harness. I will take pics later to show you.
Three: They are leaking from the famous Y-pipe, I am still solving that problem.
