Subject: Re: SilverStars, EuroLights, X-treme Power & other Halogen Bulbs Wed Jan 13, 2010 8:52 am
GMFreak8 wrote:
As far as clearness and whatnot go, what are your opinions?
I am overall very impressed with the improved light from both the SilverStars and the Eurolights. The whiter, crisper light output is a massive improvement over stock. When I got the car, the first rainy night I was out I realized I couldn't see any of the lines on the road, and it was like I barely had any lights on. With the SS or Eurolights, it's like having headlights on in the rain. I know that's a crappy description, but the difference is striking.
Name : Dave Age : 64 Location : In The AZ Oven Joined : 2007-01-17Post Count : 4502 Merit : 44
Subject: Re: SilverStars, EuroLights, X-treme Power & other Halogen Bulbs Wed Jan 13, 2010 10:09 am
I'm really looking forward to getting these PIAA's swapped, just haven't taken the time yet. I want to take before/after pics of the lights on the garage door too, for comparison.
GMFreak8 Addict
Name : Kyle Age : 36 Location : Malone, New York Joined : 2009-03-15Post Count : 638 Merit : 15
Subject: Re: SilverStars, EuroLights, X-treme Power & other Halogen Bulbs Thu Jan 14, 2010 5:09 pm
Looks like I'll try the eurolights considering I've had the silverstars before. I might as well compare.. If they lasted for two years or so that's a nice bonus. Thanks for the opinions.
Name : Aaron Age : 47 Location : C-bus, Ohio Joined : 2007-01-13Post Count : 18452 Merit : 252
Subject: Re: SilverStars, EuroLights, X-treme Power & other Halogen Bulbs Fri Jan 22, 2010 8:38 am
Speaking of EuroLights, mine should be ready to fail soon. First pair burned out Dec 17th, 2007. Next pair lasted until Dec 18th, 2008. It's been warmer lately, so maybe I'll get more out of them this time.
On the 399th day, my driver side Eurolight finally expired last night. I think that's a new record; will be reordering today. Hope the other one lasts through the weekend.
Name : Rick Location : Lancaster, MA Joined : 2008-09-13Post Count : 6282 Merit : 119
Subject: Re: SilverStars, EuroLights, X-treme Power & other Halogen Bulbs Fri Jan 22, 2010 10:14 am
GMFreak8 wrote:
I found the 9006 intense white series PIAA bulbs on Amazon for 42.99, which is cheaper than the Silverstars and only a few dollars more than the eurolights. Plus I have prime so I can get them here overnight if my bulbs burn out before I get these.
Kyle, Did you end up getting the PIAA's or the Eurolights.? And how do you like whichever ones you bought.?
Hometown Hero Junkie
Name : Klix Age : 46 Location : Barrhead, Alberta Canada Joined : 2009-11-18Post Count : 807 Merit : 16
Subject: Re: SilverStars, EuroLights, X-treme Power & other Halogen Bulbs Fri Jan 22, 2010 11:04 am
I really don't understand the hype behind the Sylvania Siver stars? We started carrying them a little over a month ago and I gotta say their nothing special. Piaa is far best of our high end bulb line and we have 7 different lines from, Wagner True view, Sylvania Siverstar, Phillips Nightguide, Phillips Crystal Vision, GE Nighthawks, PIAA, Hella as well as all your standard OE equivalents.
From what I have seen, what I have sold , and what I have seen returned... spend the extra $, buy the Piaa's you would'nt ever be sorry you did.
Subject: Re: SilverStars, EuroLights, X-treme Power & other Halogen Bulbs Fri Jan 22, 2010 1:57 pm
I would imagine that the reference to Halogens in the above chart and how many Lumens they can put out based on Kelvin rating would also be dependent on the manufacturer of bulb. Do you agree? Unfortunately not all Mfg's will report the Lumen output. At least that's been my evaluation. A for instance is the PIAA 4,000k Halogen bulbs i have. I have been unable to find the output rating in Lumens. But based on the above chart they should be about 3,000 Lm. Is that correct or am i reading the chart incorrectly.?
Subject: Re: SilverStars, EuroLights, X-treme Power & other Halogen Bulbs Fri Jan 22, 2010 2:03 pm
Different halogen bulb manufacturers use different wattage ratings, and their bulbs emit light of slightly different Kelvin temp (color). So we could assume that a higher wattage bulb or a higher Kelvin (above 3200ºK) bulb could yield more Lumens output. If they don't state the Lumen output, you take a chance. I think I read a review where the PIAA had less luminous output than Silverstars.
Understand the above chart is comparing HID bulbs to a 3200ºK halogen of unknown wattage. The 35W HID bulbs are more efficient, and so produce more Lumens, regardless of Kelvin temp (but have less advantage at higher Kelvin). So you can't assume a 4000ºK halogen will put out as much light as a 4000ºK HID. But you can assume a 4000ºK halogen will be brighter than a 3200ºK halogen. FYI, I've not seen a halogen bulb advertise more than 2000 Lumens output.
EDIT: some info on PIAAs from: http://www.gm-trucks.com/forums/index.php?showtopic=17639
Subject: Re: SilverStars, EuroLights, X-treme Power & other Halogen Bulbs Fri Jan 22, 2010 3:43 pm
The chart makes more sense now. The bottom only said Halogen, so it wasn't all that clear.
Subject: Re: SilverStars, EuroLights, X-treme Power & other Halogen Bulbs Sun Jan 24, 2010 11:13 pm
Yeah, I see what you mean. As far as I know, there are very few halogen bulbs spec'd much over 4000ºK. The Eurolights are 4100ºK according to the spec.
I've been looking into alternatives to the Eurolights. $35 per year is okay, and they are bright, but there are some newer bulbs on the market. I checked into the HID route, but the only ones I feel comfortable buying are Philips ($350) or McCulloch ($250). All of the $50-80 options are basically the same Chinese product, imo. And based on some of the problems I've seen people having in the HID thread, I'm not convinced it's worth doing.
After some searching for better halogens, I found these:
Lots of good reviews from other forums, and some good photos of the beams. Since the X-Tremes are legal 55W bulbs, I'm curious to see how they stack up next to the Eurolights. Bulbs are on the way, so if they get here before my other bulb fails, I'll try to get a photo of the new & old for comparison.
Subject: Re: SilverStars, EuroLights, X-treme Power & other Halogen Bulbs Mon Jan 25, 2010 1:45 pm
Phillips makes a good bulb I have the Crystal Visions in my Bush Buggy. Pretty bright even through my bush gaurd.
Subject: Re: SilverStars, EuroLights, X-treme Power & other Halogen Bulbs Mon Jan 25, 2010 1:52 pm
Aaron can you provide a link to where you purchased them and possibly any links to peoples reviews of them. Thanks
Subject: Re: SilverStars, EuroLights, X-treme Power & other Halogen Bulbs Mon Jan 25, 2010 2:41 pm
I ordered from http://www.suvlights.com
At this time, I can't recommend the seller, as I've not received the bulbs yet, and have never dealt with them before. These bulbs have only been available in the US for a year, and still are hard to find. Supposedly Meijer and K-Mart dept stores carry, but I could not find them locally.
Subject: Re: SilverStars, EuroLights, X-treme Power & other Halogen Bulbs Tue Feb 02, 2010 3:12 am
I received the new Philips X-treme Power (55W halogen) bulbs, and luckily my other EuroLights bulb was still working, so decided to take some pics and show a comparison. I also found a working SilverStar bulb from a few years ago - might as well include it in the experiment.
First, the X-treme Power bulbs:
Very nice packaging, almost too nice:
Information/specs for whomever is interested:
Okay, first a shot of the car with both a EuroLights bulb and a SilverStar. The EuroLights are rated somewhere between 65-80 watts, depending on who you ask. The SilverStars are 55W bulbs. Sorry this shot is further away than the rest, and color is a bit warm. Still you can see the difference between them:
Note: all pics are direct from digital camera card, absolutely NO changes in Photoshop - levels, color, and brightness are all exactly as the camera recorded them. Only thing changed was image size.
Here are a couple shots of SilverStar and EuroLights bulbs projected on the garage door from about 20 ft away. These were taken with a manual camera. First shot uses a high (bright) exposure, followed by one with a slightly lower (dim) exposure. The difference is one half shutter speed, so if the first was 1/4 sec, the second is 1/8 sec. Exact same image, different exposures:
Here are the SilverStar and EuroLights bulbs with lenses photographed at the exact same exposure setting, at approximately the same angle on different sides of car:
In conclusion, the EuroLights bulb was clearly a bluer white than the SilverStar. However, the SilverStar seems to have a slight edge in brightness level. Subjectively, I felt the EuroLights were brighter in person, but the camera told a different story.
____________________________________
Next up, I switched out the EuroLights bulb for the new Philips X-treme Power. Here's a shot of the car with an X-treme Power and a SilverStar:
A couple shots of SilverStar and X-treme bulbs projected on the garage door, using the same high/low exposure system as before (same image, different exposures):
Here are the SilverStar and X-treme lenses photographed at the exact same exposure setting, at approximately the same angle on different sides of car:
Notice the warmer color of the X-treme Power's light. I wasn't expecting this, and immediately assumed the SilverStar was brighter, but in examining the pictures it appears almost a tie, with the X-treme producing a bright white at the very center, but warmer around. Almost too close to call.
Last part of the test was to replace the SilverStar with the EuroLights bulb and compare with the X-treme Power. Here's a shot of the two on the car:
EuroLights and X-treme bulbs projected on the garage door, using same high/low exposures (same image, different exposures):
EuroLights and X-treme lenses photographed at the exact same exposure setting, at approximately the same angle on different sides of car:
Once again, very close, with a clearly bluer white light from the EuroLights bulb, and a warmer light from the X-treme Power. Both bulbs are bright, but again I felt the EuroLights was brighter in person. The blueish light plays a trick on your mind - you want to believe the blue is whiter and brighter. I used my camera as a light meter to get a rough measure of output from both beams - both measured about the same. Looking at the photos, I think the X-tremes have a slight edge, keeping in mind the EuroLights bulb is more than a year old. The SilverStar bulb probably saw 6-9 months use. If not for their short life span, I would have more respect for SilverStars.
Here are some more shots of EuroLights vs. X-treme Power with the car backed up about 60 ft:
Same from closer up, right and left:
So were the Phillips X-treme Power halogens worth $50? I haven't yet driven with them installed, so I'm not 100% sure, but initial tests suggest the answer will be "No". They are very bright, and they do use less power, but this is not enough to justify the extra cost, imo. They may project 80% more light than the worst halogen bulb, but they only gave me a 5-10% improvement at best. The only way the X-tremes could win my heart is if they were somehow able to project their light further down the road than the EuroLights (as Philips claims they will). The last few photos do show the X-tremes working well at longer range.
Additionally, I think it will come down to color preference, bulb longevity, and price. If the Philips bulbs last significantly longer than a year, I may buy them again. Otherwise, I really liked the cool white glow of the EuroLights, and for $35 they were almost worth replacing every ~365 days. I don't know, will need to drive on it a few nights and then will post back with a verdict.
Subject: Re: SilverStars, EuroLights, X-treme Power & other Halogen Bulbs Tue Feb 02, 2010 12:32 pm
Nice photographic comparison. Thanks for taking the plunge for the greater good. I think I'll order my next set of Eurolights!
-Derek
Subject: Re: SilverStars, EuroLights, X-treme Power & other Halogen Bulbs Tue Feb 02, 2010 1:09 pm
Nice comparison on the bulbs AA. Can't say I would have taken the time myself so bravo . I'm not at all surprised the Silverstars didn't top the charts, like I had said in the regards to the PIAA comparison awhile back. "I really don't see what all the hype is about" over the Silverstars they just aren't a top quality light. I can't comment on the Eurolights they're the only brand I don't stock and sell. Thanks again though for the effort this will even act as a good demo to show my customers the difference.
Subject: Re: SilverStars, EuroLights, X-treme Power & other Halogen Bulbs Tue Feb 02, 2010 1:29 pm
Hey now, I'd say Riviera Performance is due some kind of donation if you're going to use our photos to sell head lamps!
Subject: Re: SilverStars, EuroLights, X-treme Power & other Halogen Bulbs Tue Feb 02, 2010 2:44 pm
I'll tell you what... I will sell you guys parts for your Rivs at my cost if your close by(like in Canada) you'll save a bundle even with shipping. I don't know if it would be beneficial to you southerners in the U.S. tho. Shipping would gobble up the difference pretty fast. But if your ever curious on my cost for a part just ask, I will be more than happy to look it up for you to compare. Rember tho my Price wil be in CAD so there may be a lil math involved.
Karma Aficionado
Name : Andrew Age : 40 Location : Ontario, Canada Joined : 2008-01-14Post Count : 1949 Merit : 123
Subject: Re: SilverStars, EuroLights, X-treme Power & other Halogen Bulbs Tue Feb 02, 2010 3:36 pm
WOOT! ...I'm so going to take you up on this sometime!
Subject: Re: SilverStars, EuroLights, X-treme Power & other Halogen Bulbs Tue Feb 02, 2010 4:47 pm
Where in Ontario are you. I used to live in Burlington, where my mom and some other relatives are. My step brother Terry actually owns National4wd down there and the head office in Calgary. So it would be easy to get you stuff for sure, plus you can avoid the extra PST if I remember right you guys are still paying PST, our sales tax is only 5% GST in AB. Just PM me if your ever curious about a part and price. I can look up whatever you want, but if we are shipping stuff that kinda distance give me your OEM #'s to cross reference to ensure you get the right part the 1st time. Fair enough?
Allstyle Special
Name : Paul H Age : 60 Location : Windsor Ont. Canada Joined : 2010-01-15Post Count : 3 Merit : 0
Subject: Re: SilverStars, EuroLights, X-treme Power & other Halogen Bulbs Tue Feb 02, 2010 5:22 pm
Good job with the light survey I know what lights Im buying when my Silverstars burn up Thanks Rickw
Name : Mark Age : 59 Location : West Salem, Oregon... FINALLY Joined : 2009-04-09Post Count : 3176 Merit : 104
Subject: Re: SilverStars, EuroLights, X-treme Power & other Halogen Bulbs Tue Feb 02, 2010 5:45 pm
In these pics, it looks like the X-treme Power bulbs are putting out more usable light than the EuroLights.
That's one of the things that bothered me when I started doing my own research. We have a whole industry that is convincing people that blue is better, even though the human eye sees the red end of the spectrum better than the blue end...
Add to that the fact that the blue glass is reducing both the warmer wavelengths AND the total output, and you've got fewer lumens on the road. Mainly though, to make up for the lost light, these nominal 55W bulbs are running the maximum allowed power, which is why their life is so atrocious!
A standard halogen has a rated life of 850 - 1000 hours... The Silverstars, X-treme Powers, GE NightHawks, etc. are only rated at about 150 - 300 hours - and it's not easy to find that info on the 'net, either. That's a hell of a short life for a premium price bulb, and especially annoying in a car where the headlamps are such a pain to change.
I'm trying to test a bulb that claims to truly be the brightest halogen you can buy, 1800 lumens in a 55W low beam, 3700K with an 800 hour rated life. Unfortunately, the first pair arrived defective...
Subject: Re: SilverStars, EuroLights, X-treme Power & other Halogen Bulbs Tue Feb 02, 2010 5:54 pm
Eldo wrote:
I'm trying to test a bulb that claims to truly be the brightest halogen you can buy, 1800 lumens in a 55W low beam, with an 800 hour rated life. Unfortunately, the first pair arrived defective...
Which bulb is it.????
Subject: Re: SilverStars, EuroLights, X-treme Power & other Halogen Bulbs Tue Feb 02, 2010 8:08 pm
I'm not saying, unless and until I get this pair replaced with proper bulbs, and I can take before & after pictures...
Subject: Re: SilverStars, EuroLights, X-treme Power & other Halogen Bulbs Tue Feb 02, 2010 8:12 pm
Na, Na, NA-NA- NA. I'm not sharing.!!!! J/k
