| door speaker size | |
RhinoFLA Aficionado
Name : Ryan Age : 35 Location : Port Richey, FL Joined : 2007-02-27 Post Count : 1029 Merit : 4
 | Subject: door speaker size Fri Nov 23, 2007 5:33 pm | |
| What size are the speakers in our doors? mine are blown.. time to replace em.. | |
palermocorey90 Expert
 | Subject: Re: door speaker size Fri Nov 23, 2007 5:54 pm | |
RhinoFLA Aficionado
 | Subject: Re: door speaker size Fri Nov 23, 2007 5:59 pm | |
RhinoFLA Aficionado
 | Subject: Re: door speaker size Fri Nov 23, 2007 6:12 pm | |
| also, what depth will fit? | |
 | Subject: Re: door speaker size Fri Nov 23, 2007 6:25 pm | |
| cant help you there but im sure most 51/4 speakers will fit no problem | |
RhinoFLA Aficionado
 | Subject: Re: door speaker size Fri Nov 23, 2007 6:28 pm | |
nebstewart07 Fanatic
Name : Ben Stewart Age : 33 Location : Schofiel Barracks, HI Joined : 2010-12-12 Post Count : 390 Merit : 6
 | Subject: Re: door speaker size Tue Dec 21, 2010 4:59 pm | |
| what size are the tweeters in the front door. | |
Name : Aaron Age : 46 Location : C-bus, Ohio Joined : 2007-01-13 Post Count : 18438 Merit : 248
 | Subject: Re: door speaker size Tue Dec 21, 2010 7:13 pm | |
| 1" domes, but they are mounted to a larger plate. _________________ '05 GTO 6.0L • 6-spd • 95k miles • 0-60: 4.8s • 16.9 avg MPG • Nelson Ledges Lap: 1:26'95 Celica GT 2.2L • 5-spd • 165k miles • 0-60: yes'98 SC Riviera • 281k miles • 298 HP/370 TQ • 0-60: 5.79s • ET: 13.97 @ 99.28 • 4087 lb • 20.1 avg MPG • Nelson Ledges Lap: 1:30 3.4" pulley • AL104 plugs • 180º t-stat • FWI w/K&N • 1.9:1 rockers • OR pushrods • LS6 valve springs • SLP headers • ZZP fuel rails KYB GR2 struts • MaxAir shocks • Addco sway bars • UMI bushings • GM STB • Enkei 18" EV5s w/ Dunlop DZ101s • F-body calipers EBC bluestuff/Hawk HP plus • SS lines • Brembo slotted discs • DHP tuned • Aeroforce • Hidden Hitch^^^ SOLD ^^^ '70 Ninety-Eight Holiday Coupe 455cid • 116k miles^^^ SOLD ^^^  | |
 | Subject: Re: door speaker size Wed Dec 22, 2010 12:23 am | |
| If i get 1 inch tweaters will they fit in that spot? | |
 | Subject: Re: door speaker size Wed Dec 22, 2010 8:27 am | |
| You'll probably need to use a custom mounting plate, or you may need to modify the hole - but yes, they'll fit. You can also surface mount most tweeters somewhere else behind the grill. The OEM tweeter location isn't ideal by any means. I created a bridge and mounted them over the midrange, like a coaxial speaker. _________________ '05 GTO 6.0L • 6-spd • 95k miles • 0-60: 4.8s • 16.9 avg MPG • Nelson Ledges Lap: 1:26'95 Celica GT 2.2L • 5-spd • 165k miles • 0-60: yes'98 SC Riviera • 281k miles • 298 HP/370 TQ • 0-60: 5.79s • ET: 13.97 @ 99.28 • 4087 lb • 20.1 avg MPG • Nelson Ledges Lap: 1:30 3.4" pulley • AL104 plugs • 180º t-stat • FWI w/K&N • 1.9:1 rockers • OR pushrods • LS6 valve springs • SLP headers • ZZP fuel rails KYB GR2 struts • MaxAir shocks • Addco sway bars • UMI bushings • GM STB • Enkei 18" EV5s w/ Dunlop DZ101s • F-body calipers EBC bluestuff/Hawk HP plus • SS lines • Brembo slotted discs • DHP tuned • Aeroforce • Hidden Hitch^^^ SOLD ^^^ '70 Ninety-Eight Holiday Coupe 455cid • 116k miles^^^ SOLD ^^^  | |
charlieRobinson Expert
Name : Charlie Age : 37 Location : Toledo, OH Joined : 2011-05-17 Post Count : 3922 Merit : 30
 | Subject: Re: door speaker size Wed Oct 26, 2011 2:32 pm | |
| my speakers are blown in my door so I have been using only the rears since I got the car in May.
Can anyone recommend a good set of 51/4 and tweeters? I just need decent not pro. ~$150 for everything would be nice.
The local shops are crooks so im looking at bestbuy or some place like that.
rk0ehn Enthusiast
Name : Christian Rolf Köhn Age : 33 Location : CD Juarez, MX Joined : 2011-08-11 Post Count : 148 Merit : 14
 | Subject: Re: door speaker size Wed Oct 26, 2011 6:23 pm | |
 | Subject: Re: door speaker size  | |
