| Squeaky Door | |
+4ibmoses clazzicradiorepair TonySmooth89 IBx1 8 posters |
IBx1 Expert
 | Subject: Squeaky Door Wed Mar 12, 2008 6:35 pm | |
| Got a bit of a recurring problem here.
My passenger door is fine, but when I open my driver's side door it creaks and squeaks, making the car sound cheap in the parking lots. Should I lube up the spring, hinge, or what? If you want, I'll go take a quick video clip to show you guys what I mean, if you don't know what I'm talking about.
It opens smoothly, but the sound is annoying. It also will be silent one out of 50 times I open and close the door. What should I lube up, and what should I use? | |
TonySmooth89 Aficionado
Name : Anthony Age : 34 Location : Florida Joined : 2007-11-14 Post Count : 2410 Merit : 16
 | Subject: Re: Squeaky Door Wed Mar 12, 2008 6:38 pm | |
| PB blaster , WD-40 , or silicone sprayed around the hinge will provide a temporary fix , might have to respray every couple of months. My last car did that and i had to respray every couple months. Maybe some lithium grease or something would be a little more permanent. Or perhaps taking a scotch brite and cleaning up some of the surface rust might help too. | |
IBx1 Expert
 | Subject: Re: Squeaky Door Wed Mar 12, 2008 6:41 pm | |
| Alright. I'll get a pic up in a few minutes to show you guys the hinge and spring. | |
clazzicradiorepair Amateur
Name : Nicholas Age : 37 Location : Chicago, IL Joined : 2007-03-27 Post Count : 30 Merit : 0
 | Subject: Re: Squeaky Door Wed Mar 12, 2008 8:05 pm | |
| - IBx1 wrote:
- My passenger door is fine, but when I open my driver's side door it creaks and squeaks...
I know exactly what you mean. I've tried oiling EVERYTHING to little avail - my dad even tried an "old school" trick of heating up the runner with a torch but that didn't change a thing. Like others have said, lube regularly for best results - either lithium or graphite or the like. Mine will return every 3 or so months unless I lube regularly. With our cars I have a feeling this has little to do with a stuck roller or a rusty pin but more to do with the weight of the door on an aging bearing surface. But I still love my Riviera! | |
IBx1 Expert
 | Subject: Re: Squeaky Door Wed Mar 12, 2008 8:45 pm | |
| It's either the chunky hinge with a lot of surface area:  or the dry, rusty hinge and spring:  and I can't really tell which one is making the sound, unless it's both. My dad says it may be a job for axle grease instead of WD-40. Any suggestions with that? Here's a vid: | |
 | Subject: Re: Squeaky Door Wed Mar 12, 2008 9:25 pm | |
| Yeah i'd try grease if you have it available. WD-40 always did the trick on my old car , but grease would probably last longer. i'd also try taking a scotch brite pad on the hinge by the spring. a smoother surface should make less noises theoretically. | |
ibmoses Aficionado
 | Subject: Re: Squeaky Door Wed Mar 12, 2008 9:53 pm | |
| - TonySmooth89 wrote:
- PB blaster , WD-40 , or silicone sprayed around the hinge will provide a temporary fix , might have to respray every couple of months. My last car did that and i had to respray every couple months. Maybe some lithium grease or something would be a little more permanent. Or perhaps taking a scotch brite and cleaning up some of the surface rust might help too.
Any of the sprays will solve the problem short term, lithium grease might be the best choice if you have some. If not just do as dad says and put any grease you can find on it, just not much. Perhaps apply with a Q tip or something. Bert  | |
T Riley Guru
 | Subject: Re: Squeaky Door Wed Mar 12, 2008 10:02 pm | |
| liquid graphite i believe its called....... its stopps squeakin in a hurry | |
 | Subject: Re: Squeaky Door Wed Mar 12, 2008 10:24 pm | |
| use spray lithium grease, it'll penetrate further then rubbing on axle grease, and last longer than WD40. Spray it on the roller, also on the large hinge into the flat parts... | |
 | Subject: Re: Squeaky Door Thu Mar 13, 2008 8:34 am | |
| _________________ '05 GTO 6.0L • 6-spd • 95k miles • 0-60: 4.8s • 16.9 avg MPG • Nelson Ledges Lap: 1:26'95 Celica GT 2.2L • 5-spd • 165k miles • 0-60: yes'98 SC Riviera • 281k miles • 298 HP/370 TQ • 0-60: 5.79s • ET: 13.97 @ 99.28 • 4087 lb • 20.1 avg MPG • Nelson Ledges Lap: 1:30 3.4" pulley • AL104 plugs • 180º t-stat • FWI w/K&N • 1.9:1 rockers • OR pushrods • LS6 valve springs • SLP headers • ZZP fuel rails KYB GR2 struts • MaxAir shocks • Addco sway bars • UMI bushings • GM STB • Enkei 18" EV5s w/ Dunlop DZ101s • F-body calipers EBC bluestuff/Hawk HP plus • SS lines • Brembo slotted discs • DHP tuned • Aeroforce • Hidden Hitch^^^ SOLD ^^^ '70 Ninety-Eight Holiday Coupe 455cid • 116k miles^^^ SOLD ^^^  | |
99Rivman Aficionado
 | Subject: Re: Squeaky Door Thu Mar 13, 2008 4:21 pm | |
| That is a lot of corrosion on there, I would get rid of some of that before I lubricated it. A wire brush at least, some primer or rust converter, and some paint, then a good coat of silicone or lithium grease. | |
 | Subject: Re: Squeaky Door  | |
| Squeaky Door | |
