 FAQ: Aftermarket Lowering Springs
Richouser
bmcd9179
reboot13
97 park ave
Tank
BKRIV
VJD2
abaucom
Sweepspear
SToP
97rivsc
parrot5254
joe's riv
EatDirtFartDust
mak3
No-Lift
mountainrider
97rivman
HirohataMerc
Riv in Reno
pwmin
60 posters
Go to page : Previous  1 ... 12 ... 20, 21, 22
ADDvanced
FAQ: Aftermarket Lowering Springs - Page 22 Empty
PostSubject: Re: FAQ: Aftermarket Lowering Springs   FAQ: Aftermarket Lowering Springs - Page 22 EmptyTue May 21, 2024 8:09 pm
What year grand prix spring are those? Does anyone have a part number? I am going to be doing the suspension soon and I'm getting rid of the factory too soft nonsense.
Merit : 104
PostSubject: Re: FAQ: Aftermarket Lowering Springs   FAQ: Aftermarket Lowering Springs - Page 22 EmptyWed Jun 05, 2024 4:55 am
I can barely get a jack under my front sub-frame as it is...  Lowering?  surprised
Merit : 150
PostSubject: Re: FAQ: Aftermarket Lowering Springs   FAQ: Aftermarket Lowering Springs - Page 22 EmptyWed Jun 05, 2024 10:17 am
racinfan wrote:
Well does anyone know how the Riv's auto-level feature works?
Yes, there is a level sensor that signals a small compressor in the right side rear to inflate or release air to the air shocks in the REAR only. Not uncommon for the system to be troublesome. You will need an FSM to diagnose problems with it.
PostSubject: Re: FAQ: Aftermarket Lowering Springs   FAQ: Aftermarket Lowering Springs - Page 22 EmptyThu Jun 06, 2024 12:53 am
IF you put STS sway bars on and Gabriel shocks/struts that will get you a stiffer 'touring' suspension. You could contact horseheadspickapart.com and if they still have the parts they would have a yardman pull and ship you the front and rear bars off my old Riv (which is not there parting out). Ask them to give you the links too, they are Moog HD with some sort of nylon or poly bushings, work very well
Page 22 of 22Go to page : Previous  1 ... 12 ... 20, 21, 22
» KYB front struts for ’97 ???
» Group Buy: Eibach Lowering Springs
» lowering riv
» sts stock springs
» how to install rear springs?
