 Boost gauge and cold air intake suggestions
6 posters
Boost gauge and cold air intake suggestions Empty
PostSubject: Boost gauge and cold air intake suggestions   Boost gauge and cold air intake suggestions EmptyWed Feb 28, 2007 8:08 pm
Best bang for the buck?
PostSubject: Re: Boost gauge and cold air intake suggestions   Boost gauge and cold air intake suggestions EmptyWed Feb 28, 2007 8:11 pm
they dont make a cold air intakes for our cars.(there is'nt much riv specific aftermarket) only hot air intakes lol
if you want a good intake then make a FWI our of 4" PVC and stick a k&N cone on the end in the fender.
Boost gauge and cold air intake suggestions Dsc_0110
PostSubject: Re: Boost gauge and cold air intake suggestions   Boost gauge and cold air intake suggestions EmptyWed Feb 28, 2007 8:18 pm
you mean going down through that hole underneath of the airbox?
Best bang for buck: gutted stock air box.
PostSubject: Re: Boost gauge and cold air intake suggestions   Boost gauge and cold air intake suggestions EmptyWed Feb 28, 2007 8:21 pm
how much do the k and n cone filters run for? i gutted my airbox yesterday, looking for a little bit more, clever though aaron, best bang for free? agreed
PostSubject: Re: Boost gauge and cold air intake suggestions   Boost gauge and cold air intake suggestions EmptyWed Feb 28, 2007 8:34 pm
so run 4" pvc down into that hole with a k&n cone filter on the end of that?
PostSubject: Re: Boost gauge and cold air intake suggestions   Boost gauge and cold air intake suggestions EmptyWed Feb 28, 2007 8:58 pm
baisicly yes, there is a write up somewhere around here.
PostSubject: Re: Boost gauge and cold air intake suggestions   Boost gauge and cold air intake suggestions EmptyWed Feb 28, 2007 9:42 pm
mmk, I found the guide. seems fairly simple, but i'm still kind of puzzled on what size filter to use :< also, whether or not he used pvc glue on each fitting or if he just pushed them together
PostSubject: Re: Boost gauge and cold air intake suggestions   Boost gauge and cold air intake suggestions EmptyWed Feb 28, 2007 9:53 pm
ahh yes he did use glue !!!!!!!!!!!! happy
Merit : 64
PostSubject: Re: Boost gauge and cold air intake suggestions   Boost gauge and cold air intake suggestions EmptyThu Mar 01, 2007 1:16 pm
I made this write-up.
I did -> NOT <- use glue on the joints. You need to be able to rotate the pipes to their ideal position and be able to take it apart afterwards if necessary.
If I were to do it again, I would use a silicone reducer coupling on the engine and a smaller S&B powerstack 7" filter with a 4 or 4.5 inch flange inside diameter. If you use a 4" flange, you'll have to heat it up with a hair dryer and add a little lube to the PVC pipe for it to slip on.
PostSubject: Re: Boost gauge and cold air intake suggestions   Boost gauge and cold air intake suggestions EmptyFri Mar 02, 2007 9:30 pm
I also didn't glue my pieces together. There really is no need because they fit really tight together.
» Write-Up: Flexible Tube Fenderwell Intake
» Write-Up: Installing Boost Gauge
» Cold air intake?
» Interesting idea for cold air intake
» Faze boost/vac gauge pillar
