 Subframe Bushings
2 posters
BillBoost37
Merit : 26
Subframe Bushings Empty
PostSubject: Subframe Bushings   Subframe Bushings EmptyMon May 12, 2008 8:58 am
Last time my trans was out one of the subframe bolts tightened further than it should and I knew the bushings were history. Mileage ~210,000 miles and the bushings are 11-12 years old. It is a pain to get the part numbers for the bushings as they are relatively confusing in the dealership info. Position 1 is the front, then 2 is the next back and 3 being the furthest back.
Here's pics of the old ones
Subframe Bushings IMG_3060
Subframe Bushings IMG_3061
Subframe Bushings IMG_3062
Subframe Bushings IMG_3064
On position 1 and 3 top bushings there is a hard ring on one end. That ring faces down to sit on the subframe Here's a pic of the ring
Subframe Bushings IMG_3065
Squeezing the new one
Subframe Bushings IMG_3066
And the other end
Subframe Bushings IMG_3067
One of these parts had had given and collapsed. Luckily a junkyard wasn't far away. If I were to do it again, I'd get them as new.
Subframe Bushings IMG_3068
Subframe Bushings IMG_3069
Subframe Bushings IMG_3070
Some general pics
Subframe Bushings IMG_3071
Subframe Bushings IMG_3072
Tough to tell on this pic, the holes in the subframe aren't perfect circles. They have two flat sides to them. This way the bushings fit in and can't turn.
Subframe Bushings IMG_3073
The top piece fits inside the bottom bushing. I found some caliper lube to help fit them back together.
Subframe Bushings IMG_3074
This one had seen better days
Subframe Bushings IMG_3075
Subframe Bushings IMG_3076
Subframe Bushings IMG_3077
Gee Enrique...these would be super easy if the motor and trans were out. poke
PostSubject: Re: Subframe Bushings   Subframe Bushings EmptyMon May 12, 2008 9:02 am
As far as I can tell they were replaced when I had the Gimps transmission rebuilt. They look new.
Subframe Bushings
» Write-Up: Subframe/Cradle Mount Insulators & Bushings
» 93 Riv front subframe bushings- Please HELP
» Subframe Bushings for 1995
» Is the Riv subframe the same as one from a GP or Regal?
» FAQ: Rust Areas & Concerns
