 Write-Up: Wheel Stud Replacement
BillBoost37
8 posters
Go to page : Previous  1, 2
Write-Up: Wheel Stud Replacement - Page 2 Empty
PostSubject: Re: Write-Up: Wheel Stud Replacement   Write-Up: Wheel Stud Replacement - Page 2 EmptySun Nov 25, 2012 9:52 pm
I had to do this last year after breaking a wheel stud. The correct way to do it is to remove the hub, because there isn't enough room behind the mounting face to clear the studs when you pound them out.
BUT...
With a little ingenuity, the lug studs can be modified to fit past the hub. I'll post some pictures in a few minutes.
you can cut the stud short and press it out -- I would Avoid Pounding on the Hub; and IIRC there is at least one hole in the stationary part of the hub you can push the thing thru but don't quote me.
PostSubject: Re: Write-Up: Wheel Stud Replacement   Write-Up: Wheel Stud Replacement - Page 2 EmptySun Nov 25, 2012 10:11 pm
I didn't cut the studs short (aftermarkets are typically shorter), but I did grind off part of the flange so that it could fit past the hub. An engineer would probably disagree with this approach, but I've been running the modified stud for almost a year with no issues. I don't believe this compromises the integrity of the stud, as they usually shear near the middle, not inside the hub. If concerned, purchase an ARP stud.
Write-Up: Wheel Stud Replacement - Page 2 IMG_0376
Write-Up: Wheel Stud Replacement - Page 2 IMG_0377
I did pound out my old lug stud. It took relatively little force. Tip: freeze the new stud for a couple hours before installation. I pressed it in simply by tightening the wheel nut. Of course, check torque after 100 miles to be sure it's seated correctly.
» Write-Up: Spindle / Wheel Bearing / Hub Replacement
» Write-Up: Disabling and Removing the Airbag Module & Steering Wheel
» Rear Wheel Hub/Bearing Replacement
» Write-Up: Radiator Replacement
» Write-Up: OEM Front Brakes Pad & Rotor Maintenance
