 Clunking noise from the front left wheel well area
4 posters
Clunking noise from the front left wheel well area Empty
PostSubject: Clunking noise from the front left wheel well area   Clunking noise from the front left wheel well area EmptyTue May 27, 2008 8:40 am
There is a Clunking noise when i put my car into Park from reverse, Reverse to drive (stopped of course). Is there any cradle bolts the Tranny shop may not have tightened now that i think about it, it could be my FWI shocked God i hope i answered my own Question grimace
rock
PostSubject: Re: Clunking noise from the front left wheel well area   Clunking noise from the front left wheel well area EmptyTue May 27, 2008 8:44 am
There are a lot of things this could be. On my car it ended up being the front control arm bushings. Although now everything is so tight I have a new crack noise which I think might be the CV joint. No more suspension flex means my hard shifts are going right to the tires...
PostSubject: Re: Clunking noise from the front left wheel well area   Clunking noise from the front left wheel well area EmptyTue May 27, 2008 8:48 am
are those the polyurethane looking things that are cylinder shape?
PostSubject: Re: Clunking noise from the front left wheel well area   Clunking noise from the front left wheel well area EmptyTue May 27, 2008 9:01 am
Yes. They are a PITA to change, I bought complete control arms instead, that includes the rear bushings (non-servicable) and ball joints. I got them OEM for under $200 each from monsterpartsonline.com
PostSubject: Re: Clunking noise from the front left wheel well area   Clunking noise from the front left wheel well area EmptyTue May 27, 2008 9:27 am
since i didn't truse the tranny shop with my FWI i decided to put in a open cone....... No noise,,,,,,, now after i installed my FWI i have the noise........ gosh i hope im right no
PostSubject: Re: Clunking noise from the front left wheel well area   Clunking noise from the front left wheel well area EmptyWed May 28, 2008 9:32 am
its the FWI....... but the 1-2 shift wierd thing is Well WIERD............... but it DOESNT seem to effect performance.
PostSubject: Re: Clunking noise from the front left wheel well area   Clunking noise from the front left wheel well area EmptyWed May 28, 2008 9:40 am
When I got my car back from transmission repair, mine clanked, too. The bolt securing the FWI was broken off!
PostSubject: Re: Clunking noise from the front left wheel well area   Clunking noise from the front left wheel well area EmptyWed May 28, 2008 9:42 am
neutral did you shoot anyone?
PostSubject: Re: Clunking noise from the front left wheel well area   Clunking noise from the front left wheel well area EmptyWed May 28, 2008 9:45 am
No, I considered the possibility that taking taking the trans in and out 4-5 times, the bolt may have broken by itself. There's the chance they didn't know it was there.
Took me 1/2 to drill out and replace.
PostSubject: Re: Clunking noise from the front left wheel well area   Clunking noise from the front left wheel well area EmptyWed May 28, 2008 9:46 am
They took out your tranny that many times??? shocked wowzers
PostSubject: Re: Clunking noise from the front left wheel well area   Clunking noise from the front left wheel well area EmptyWed May 28, 2008 9:54 am
Yeah, the guy was a perfectionist. If something didn't feel right, he'd pull it out and do it again.
PostSubject: Re: Clunking noise from the front left wheel well area   Clunking noise from the front left wheel well area EmptyWed May 28, 2008 9:56 am
You got a GREAT mechanic to go to for tranny work than cool
PostSubject: Re: Clunking noise from the front left wheel well area   Clunking noise from the front left wheel well area EmptyWed May 28, 2008 10:01 am
Yo Travis - might just be motor/transmission mounts.
PostSubject: Re: Clunking noise from the front left wheel well area   Clunking noise from the front left wheel well area EmptyWed May 28, 2008 10:03 am
never thought about that
» Have the left rear wheel speed sensor open or shorted dealer codes 1234 123
» Noise coming from tranny area
» Noise from front left - 1998 Riviera
» Low speed thunking from rear driver's side suspension
» Wheel Skins Wheel Cover (possible group buy?)
