 Belt slip & screech noise
3 posters
Supercharged
Supercharged
Belt slip & screech noise Empty
PostSubject: Belt slip & screech noise   Belt slip & screech noise EmptyWed Jul 02, 2008 12:22 pm
i was getting on it and when 1st gear was right about to shift and i let out of it as fast as i could shocked yeah it was the belt trying to catch up with the pulleys im guessing
it makes a horrible loud screech, never knew about that one gavel
PostSubject: Re: Belt slip & screech noise   Belt slip & screech noise EmptyWed Jul 02, 2008 1:24 pm
Somewhat normal. You can replace the belts if worn, or install a 3.5" SC tensioner pulley to tighten things up.
Supercharged
Supercharged
PostSubject: Re: Belt slip & screech noise   Belt slip & screech noise EmptyWed Jul 02, 2008 4:05 pm
somewhat normal???
BillBoost37
Merit : 26
PostSubject: Re: Belt slip & screech noise   Belt slip & screech noise EmptyThu Jul 03, 2008 8:38 am
A stretched or worn belt will frequently result in belt slip.
I think that's what Aaron was getting at.
PostSubject: Re: Belt slip & screech noise   Belt slip & screech noise EmptyThu Jul 03, 2008 9:23 am
I meant it's part of the physics behind a blower spinning 20k RPM and then being asked to stop instantly.
As long as I've had my car, when I floor it in 1st, then let off sharply at 5k RPM, it's going to slip a little, making a chirp. This gets even worse when belts are bad, but can happen even with fresh ones. Smaller SC pulleys also encourage this phenomenon.
When you're driving the car in an erratic fashion, some slip is "normal", imo. I wouldn't describe the noise as horrible, though. It's just a noise.
To Bill's point, since your engine has a stock SC pulley, the noise is probably the result of worn/stretched belts, but the reason for it happening is not surprising.
Supercharged
Supercharged
PostSubject: Re: Belt slip & screech noise   Belt slip & screech noise EmptyThu Jul 03, 2008 1:11 pm
okay, i see what your getting at
» Slip-like shift between 3rd and 4th gears, maybe, possibly
» Belt/Pulley Noise
» SC/Accessory Belt Slipping Off
» FAQ: Power Door Lock Problems
» Belt wrap kit
