 (8rib) 3" SC idler pulley part number?
2 posters
(8rib) 3" SC idler pulley part number? Empty
PostSubject: (8rib) 3" SC idler pulley part number?   (8rib) 3" SC idler pulley part number? EmptyMon Jul 21, 2008 6:21 pm
I need the part number for a 3" idler pulley for the SC that works with the 8rib belt.
Can anybody help!?!? Need it so we can finish up the belt wrap kit before I go to the track on Wed.
PostSubject: Re: (8rib) 3" SC idler pulley part number?   (8rib) 3" SC idler pulley part number? EmptyMon Jul 21, 2008 6:34 pm
wow....the only thing I'm finding is for the VW Vortex engine....
http://www.vortechsuperchargers.com/product_variation.php?pvk=395
Check to see if the bushing ID is the same and if the width will work for you....
PostSubject: Re: (8rib) 3" SC idler pulley part number?   (8rib) 3" SC idler pulley part number? EmptyMon Jul 21, 2008 6:46 pm
I appreciate the link but I'm looking for the OEM pn so I can get them from NAPA- I'm in a time crunch. ZZP sells them but they don't list the part number and I can;t wait until weeks end.
PostSubject: Re: (8rib) 3" SC idler pulley part number?   (8rib) 3" SC idler pulley part number? EmptyMon Jul 21, 2008 6:49 pm
Eric,
Just ask them to pull up all the 8 rib pulleys and have them check the bushing diameter...
PostSubject: Re: (8rib) 3" SC idler pulley part number?   (8rib) 3" SC idler pulley part number? EmptyMon Jul 21, 2008 6:51 pm
or just call ZZP and say you need the part number for a purchase order so you can enter it in the company computer...
PostSubject: Re: (8rib) 3" SC idler pulley part number?   (8rib) 3" SC idler pulley part number? EmptyMon Jul 21, 2008 6:58 pm
Actually, I might have to have them pull the pulleys if I can't get a part number- I need a bolt as well and as long as the diameter gives me room to work with the 1"x1" aluminum stock I am using, it should work.
My problem is I want to get all the parts I need 1st thing in the morning and drop them off in the a.m. as I have meetings all day and really want this belt wrap kit done by the time I go to the track on Wed afternoon.
PostSubject: Re: (8rib) 3" SC idler pulley part number?   (8rib) 3" SC idler pulley part number? EmptyMon Jul 21, 2008 7:31 pm
wait...is this for your belt wrap project?
PostSubject: Re: (8rib) 3" SC idler pulley part number?   (8rib) 3" SC idler pulley part number? EmptyMon Jul 21, 2008 8:27 pm
Yes it's for the belt wrap kit...
Got the numbers. For future reference:
38028 is the 76mm (about 3")
38022 is the 90mm (about 3.5")
24503929 is the GM pn for the bolt
» need help with a part number
» Part number help
» snout seal part number??
» 98 riviera trans part number?
» Write-Up: Rear Self-leveling Air Shocks
