 95 Riviera A/C problem
5 posters
mtdew
95 Riviera A/C problem Empty
PostSubject: 95 Riviera A/C problem   95 Riviera A/C problem EmptyMon Aug 25, 2008 1:02 pm
I had the blower control module go out awhile ago and got a supposed new one on the web but the design was slightly different then the original. It works and now the blower shut's off.
After a few days the passenger side would only blow cold air and sometimes the rear console. Now I am lucky if the passenger side will blow cold. I have taken out the glove box and removed the acuator to the left of the glove box but manually opening that will not guarentee cold air to blow.
I have tried to watch all 5 acutators while cycling through the modes and all move but 2 of them. The one on the left of the glove box and the one in the middle of the 3 to the left of the radio/climate control area. I moved these doors but it seemed to make hot air come out.
There is NO flashing anything on the control head and all the modes seem to cycle. A/C has good charge and compressor is clicking on. This is a 1995 and no controls on the steering wheel. Can you suggest some other test to do?
PostSubject: Re: 95 Riviera A/C problem   95 Riviera A/C problem EmptyMon Aug 25, 2008 1:06 pm
Turn on the AC, fan on max and set it at the lowest temperature possible...
....then put your girlfriend in the front seat and see if she "nips out".....
PostSubject: Re: 95 Riviera A/C problem   95 Riviera A/C problem EmptyMon Aug 25, 2008 5:41 pm
well son of a bitch....I jinxed myself....my AC just bit it....
*shakes fits at karma....immediately retracts it due to elbow pain*
PostSubject: Re: 95 Riviera A/C problem   95 Riviera A/C problem EmptyTue Aug 26, 2008 8:40 pm
I'll see if I can find something in the Service Manual in the next few days and let you know. I do know everything has to be in the right position to operate correctly.
From what I have experienced it doesn't flash when an actuator isn't working properly but it does if there is something disconnected from the system.
mtdew
PostSubject: RATS!!!!   95 Riviera A/C problem EmptyTue Aug 26, 2008 9:47 pm
I took the car to another shop and they told me the compressor is bad. Although it is clicking on and off he showed me gauges hooked into the A/C line and he said the numbers we not what they should be.
I 'll find out tomorrow minus $600.
manofmany
PostSubject: Re: 95 Riviera A/C problem   95 Riviera A/C problem EmptyWed Aug 27, 2008 8:14 am
Umm what kind of gauges? Sounds like you may be getting hosed
PostSubject: Re: 95 Riviera A/C problem   95 Riviera A/C problem EmptyWed Aug 27, 2008 12:15 pm
The compressor is the only part of the A/C I've ever seen fail. It's not surprising, and $600 is not outrageous for a shop to replace it.
mtdew
PostSubject: Fixed now   95 Riviera A/C problem EmptyWed Aug 27, 2008 8:29 pm
They replaced the compressor, accumulator bottle, orifice tube, flushed system, added dye for future tests(leaks) and recharged it and it came to $621. Ahhh nice and cold like it used to be!
PostSubject: Re: 95 Riviera A/C problem   95 Riviera A/C problem EmptyWed Aug 27, 2008 8:40 pm
Sounds like the right fix.
Enjoy!
» 97 Riviera A/C problem
» 98 riviera electrical problem
» Not 2fast? 1997 Riviera SC, whats the problem?
» Write-Up: Installing Double DIN head unit in '96-99 Riviera
» Another heating problem or vent problem...
