 turn signal help
LaFlare
texasfan010
7 posters
texasfan010
texasfan010
turn signal help Empty
PostSubject: turn signal help   turn signal help EmptyWed Nov 12, 2008 11:16 pm
hey i have a marker light out in front(the little orange lens in the bumper) I need help, I dont know how to get to it to replace the bulb.
PostSubject: Re: turn signal help   turn signal help EmptyThu Nov 13, 2008 12:42 am
remove the plastic pins that hold the inner fender (black plastic) over the area where the light is, then reach up and replace the bulb. The socket twists or pulls out IIRC. Easier to do if you lay on the ground and look up at it (wear safety glasses to keep the dirt out of your eyes). After you've replaced it once you probably won't need to look at it at all to replace one next time, except maybe to remove/replace the inner fender because the holes for those little pastic pins don't line up
texasfan010
texasfan010
PostSubject: Re: turn signal help   turn signal help EmptyThu Nov 13, 2008 6:43 pm
thanks i appreciate it
LaFlare
PostSubject: Re: turn signal help   turn signal help EmptyThu Sep 16, 2010 1:19 pm
question, how many bulbs are there for the turn signal?
PostSubject: Re: turn signal help   turn signal help EmptyThu Sep 16, 2010 1:30 pm
Should be 5 total (per side). 1 for the cornering light, 2 for the big yellow side marker on the bumper, and 2 in the rear tail light assembly.
LaFlare
PostSubject: Re: turn signal help   turn signal help EmptyThu Sep 16, 2010 1:40 pm
ahh okay. yeah i meant for the yellow side signal. so there's two in there? i just bought a replacement 3057, should've double checked before i went and bought. which is the second bulb for this? are they both 3057 because in the manual it only shows 3057 for the turn signal, i think
PostSubject: Re: turn signal help   turn signal help EmptyThu Sep 16, 2010 2:50 pm
Yes, there are 2 bulbs in there. One 3057 and one 194, which is right behind the the 3057, closer to the door. Look through the marker (if it's clear enough) and you can see them both.
PostSubject: Re: turn signal help   turn signal help EmptyThu Sep 16, 2010 5:09 pm
In the manual it says only the 3057 is the turn signal bulb.... because the 194 (you can use a 168 in a pinch) is the "side marker" bulb. So the manual says only the 3057s are the turn signals.
The side marker bulbs are wired in such a way that they blink opposite the turn signals...
...but don't confuse them with the turn signals. .
PostSubject: Re: turn signal help   turn signal help EmptyThu Sep 16, 2010 5:11 pm
Doesn't that make them part of the turn signals???? It blinks right????
EDIT: It's also wired into the turn signal circuit....connects directly to the Left turn signal indicator on the dash, and also the Turn Signal Switch.
PostSubject: Re: turn signal help   turn signal help EmptyThu Sep 16, 2010 10:48 pm
Depends on how you care to define 'turn signal.'
They are part of the turn signals if your definition is that turn signals are what blinks if you use the car's installed signalling device to indicate a turn or emergency (as in emergancy flashers).
They are not if you use the definition in the manual.
Most likely they are defined as such in the manual because turn signal lights must comply with technical (not legal) standards stipulating intensity, horizontal and vertical visibility, and minimum illuminated surface area to ensure that they can be seen at all relevant angles, don't dazzle others, and are conspicuous in the dark as well as full direct sunlight. The side marker lamps aren't visible from the front of the car, and as such fail the technical "test" for what is a turn signal. They are helpful, and do serve a purpose if they flash to indicate a turn -- GM has wired side markers to so flash I think for decades, in the USA they first became common in the late 1960's.
For those of you curious about automotive lighting, you may want to look at danielsternlighting.com or at the wikipedia page, http://en.wikipedia.org/wiki/Automotive_lighting which has 73 references from NHTSA and other authoritative sources.
Last edited by albertj on Fri Sep 17, 2010 1:32 pm; edited 1 time in total (Reason for editing : moved a lost comma.)
PostSubject: Re: turn signal help   turn signal help EmptyThu Sep 16, 2010 11:17 pm
Well, if it looks like a duck, quacks like a duck, and walks like a duck, it certainly isn't an elephant joker
PostSubject: Re: turn signal help   turn signal help EmptyFri Sep 17, 2010 12:48 pm
I agree.
PostSubject: Re: turn signal help   turn signal help EmptyFri Sep 17, 2010 1:12 pm
razz Just messin with 'ya man.
Merit : 149
PostSubject: Re: turn signal help   turn signal help EmptyWed Sep 22, 2010 8:28 pm
It's actually 7 per side. In the back lens, there is a 194 bulb between each pair of the bigger bulbs. Easy to miss. Last time I replaced one of the rear bulbs, I spotted the 194's, and they were both out. There is also a 194 on each side of the rear bumper, the red marker lights.
PostSubject: Re: turn signal help   turn signal help EmptyWed Sep 22, 2010 8:53 pm
You are correct, but the 194's in the rear don't blink. wink
Merit : 149
PostSubject: Re: turn signal help   turn signal help EmptyWed Sep 22, 2010 8:56 pm
You are correct. Just thought I'd mention the 194's. I bet a lot of guys don't even realize that they are there. I sure didn't.
LaFlare
PostSubject: Re: turn signal help   turn signal help EmptyTue Nov 09, 2010 4:21 pm
hey im trying to replace the 194 bulb, but i dont know how to take the actual bulb out.. i dont want to break the bulb while its still in its little base thing (lol cant think of the proper term). how do i get the bulb out? i try pushing then turning, and doing it all carefully, i just dont want the bulb to break while still in. its so small!!
PostSubject: Re: turn signal help   turn signal help EmptyTue Nov 09, 2010 4:29 pm
Don't push or turn it, just pull straight out.
Merit : 104
PostSubject: Re: turn signal help   turn signal help EmptySat Dec 18, 2010 3:30 pm
And of course with the hassle of removing/replacing the fragile rear lamp assembly, which can also cause a leak if you don't put it back perfectly, I recommend replacing all the rear bulbs if you have it apart... with the LL (long life) type. wink
turn signal help
» Turn signal issue
» turn signal lense removal
» side mirror turn signal
» Turn Signal & Hazard Flashers - Location/Troubleshooting
» Turn signal not blinking after being broadsided... again!
