| tortuga | |
+52Rivit 98riv rivparadise ironclyde th3fr4nchi5e Birdawgxx 96_Juggernaut 69GSColorado chitown_riv98 Sir Psycho Sexy matt270avian albertj joshuadalegrimes sniperdude LARRY70GS llamalor2112 denim RidzRiv setsuna57 J. Chris Davis Hometown Hero Z-type pbrktrt Dragnet charlieRobinson Turbocharged400sbc gmann3001 95rivy 97 park ave 97buickriviera ghpcnm nothincame2mind deekster_caddy nebstewart07 bigdave Eldo Abaddon sburch23 BMD DEMonte1997 flyineagle96 Karma ibmoses Rickw robotennis61 T Riley IBx1 AA Snowdog L67 stan turtleman 56 posters |
| Subject: Re: tortuga Sun Oct 31, 2010 9:24 pm | |
| dynomite turtleman! do you have the part #s for the swagelok and the compression fittings? and did you have any problem fitting the compression an fitting to our steel fuel line considering the fittings are made for aluminium? and whats the part # for the regulator? thanks. im gonna order this tonight! | |
| Subject: Re: tortuga Sun Oct 31, 2010 10:09 pm | |
| Save a few bucks. Order from Lightning Motorsports: http://lightningmotorsports.com/store/product/itmitem.aspx?itemid=167980 _________________ '05 GTO 6.0L • 6-spd • 95k miles • 0-60: 4.8s • 16.9 avg MPG • Nelson Ledges Lap: 1:26'95 Celica GT 2.2L • 5-spd • 165k miles • 0-60: yes'98 SC Riviera • 281k miles • 298 HP/370 TQ • 0-60: 5.79s • ET: 13.97 @ 99.28 • 4087 lb • 20.1 avg MPG • Nelson Ledges Lap: 1:30 3.4" pulley • AL104 plugs • 180º t-stat • FWI w/K&N • 1.9:1 rockers • OR pushrods • LS6 valve springs • SLP headers • ZZP fuel rails KYB GR2 struts • MaxAir shocks • Addco sway bars • UMI bushings • GM STB • Enkei 18" EV5s w/ Dunlop DZ101s • F-body calipers EBC bluestuff/Hawk HP plus • SS lines • Brembo slotted discs • DHP tuned • Aeroforce • Hidden Hitch^^^ SOLD ^^^ '70 Ninety-Eight Holiday Coupe 455cid • 116k miles^^^ SOLD ^^^ | |
| Subject: Re: tortuga Sun Oct 31, 2010 10:18 pm | |
| my year isnt specified? do the 95s share the same mounting tabs as the series 2? | |
| Subject: Re: tortuga Sun Oct 31, 2010 10:23 pm | |
| Check injector spacing, too - may be different on '95.
| Subject: Re: tortuga Sun Oct 31, 2010 10:25 pm | |
| man you guys are holding out on the good stuff! whats the spacing on the series 2? | |
Karma Aficionado
| Subject: Re: tortuga Sun Oct 31, 2010 11:02 pm | |
| and keeping in mind that the injectors are in the heads for series 2, and in the LIM for series one. _________________ | |
| Subject: Re: tortuga Sun Oct 31, 2010 11:14 pm | |
| i see that now. amazing how excitment gives way disapointment. im pretty sure the hoses and fitting fit. the series 1 has both,5/16 and 3/8 feed and return lines. looks like all i can do is replace the oem plastic fuel lines with an type. thats a start.... | |
| Subject: Re: tortuga Sun Oct 31, 2010 11:24 pm | |
| Subject: Re: tortuga Sun Oct 31, 2010 11:37 pm | |
| I am allways amazed at your skills AA. My spacing is for the front facing, 58mm 1st to 2nd inj. 69mm from 2nd inj. to 3rd. damn. | |
| Subject: Re: tortuga Sat Nov 27, 2010 11:38 pm | |
| what I'm working on for this car now I don't have the blower here right now to do any work on it so I figured I'd work on this in my down time. This intake literally has my blood on it now. lol one side basically done the side I didn't do yet is how I got it - it already had lots of work done but not terribly pretty and the runners were still a bit rough IMO. decent number of hours in this thing... On my end probably about 3 movies worth easily
| Subject: Re: tortuga Sat Nov 27, 2010 11:43 pm | |
| that's really beautiful . i did mine too though not as thorough. the price of the burrs and sanding cones comes to a small fortune IMO. | |
BMD Aficionado
| Subject: Re: tortuga Sun Nov 28, 2010 12:03 am | |
| Very nice man, looks like art to me. | |
T Riley Guru
| Subject: Re: tortuga Sun Nov 28, 2010 11:05 am | |
sburch23 Addict
| Subject: Re: tortuga Sun Nov 28, 2010 6:23 pm | |
| I wonder how much it would be to have some LIM extrude honed? | |
| Subject: Re: tortuga Sun Dec 26, 2010 2:52 pm | |
| next season is going to be FUN! | |
| Subject: Re: tortuga Sun Dec 26, 2010 3:04 pm | |
| Somewhere, off in the distant future, I can hear a POOF Jk man. That should be real fun. | |
| Subject: Re: tortuga Mon Jan 03, 2011 4:42 am | |
| So far, just got the bottle put somewhere at least temporarily and the NMU is mounted and connected to the bottle. NMU is mounted via brackets over the master cylinder. nothing overly fancy but effective and clean I know I'm going to catch shit for this but that's how it's gonna be for now. drilled and tapped the new TB adapter (won't be used until the IC & genV go on - right now I'm going to have to use the stupid bulkhead fitting on the intake pipe) I had to take the TB off my car so I could fit it and make sure the butterfly wasn't going to hit the nozzle before I drilled it. Good to go! The wiring won't be completed until I can get the steering wheel I need and some other things but I'll set it up for some test runs. Sorry these pictures kinda suck. They don't look that bad on the phone but man when you get them on a 1080 computer screen - woof. Plus I have no idea why they are still 1600x1200, I changed them to 800x600 on photobucket and they still show up huge here... | |
| Subject: Re: tortuga Mon Jan 03, 2011 8:42 am | |
| subtlety is an acquired taste turtle... | |
Karma Aficionado
| Subject: Re: tortuga Mon Jan 03, 2011 10:30 am | |
| that cars gonna move! _________________ | |
Name : Mark Age : 59 Location : West Salem, Oregon... FINALLY Joined : 2009-04-09 Post Count : 3141 Merit : 104
| Subject: Re: tortuga Mon Jan 03, 2011 6:30 pm | |
| Well, at least you found a use for the center-rear seatbelts... I took mine out a long time ago. | |
| Subject: Re: tortuga Mon Jan 03, 2011 8:27 pm | |
| You knew you'd get shit for it, so I'm taking the first squat. I you got into a wreck, that bottle could fly forward and kill you or somebody else. For that reason, I think it sucks. Why not install it with brackets in the trunk, and have the armrest pull down for access? _________________ '05 GTO 6.0L • 6-spd • 95k miles • 0-60: 4.8s • 16.9 avg MPG • Nelson Ledges Lap: 1:26'95 Celica GT 2.2L • 5-spd • 165k miles • 0-60: yes'98 SC Riviera • 281k miles • 298 HP/370 TQ • 0-60: 5.79s • ET: 13.97 @ 99.28 • 4087 lb • 20.1 avg MPG • Nelson Ledges Lap: 1:30 3.4" pulley • AL104 plugs • 180º t-stat • FWI w/K&N • 1.9:1 rockers • OR pushrods • LS6 valve springs • SLP headers • ZZP fuel rails KYB GR2 struts • MaxAir shocks • Addco sway bars • UMI bushings • GM STB • Enkei 18" EV5s w/ Dunlop DZ101s • F-body calipers EBC bluestuff/Hawk HP plus • SS lines • Brembo slotted discs • DHP tuned • Aeroforce • Hidden Hitch^^^ SOLD ^^^ '70 Ninety-Eight Holiday Coupe 455cid • 116k miles^^^ SOLD ^^^ | |
| Subject: Re: tortuga Mon Jan 03, 2011 9:37 pm | |
- You knew you'd get shit for it, so I'm taking the first squat. I you got into a wreck, that bottle could fly forward and kill you or somebody else. For that reason, I think it sucks. Why not install it with brackets in the trunk, and have the armrest pull down for access?
He did say, "for now"... it's not permanent. However, you do raise a good point - how about just wrapping it in a blanket for now, put it on the RR floorboard and run the passenger seat all the way back, so it can't go anywhere in case of impact? | |
| Subject: Re: tortuga Mon Jan 03, 2011 10:27 pm | |
| I really just haven't exactly decided what to do with it yet. It's decently secure. It would take nothing short of a massive collision to make it go anywhere. It sits really snug in the armrest cavity and the seatbelt is tight. Also the line is sort of a backup. The advantage to this location is you can reach the valve from the drivers seat. There isn't really any other place this could go where that can happen. I have no intention of buying a remote valve opener. | |
| Subject: Re: tortuga Mon Jan 03, 2011 11:36 pm | |
| What's the advantage to reaching it from the drivers seat? _________________ '05 GTO 6.0L • 6-spd • 95k miles • 0-60: 4.8s • 16.9 avg MPG • Nelson Ledges Lap: 1:26'95 Celica GT 2.2L • 5-spd • 165k miles • 0-60: yes'98 SC Riviera • 281k miles • 298 HP/370 TQ • 0-60: 5.79s • ET: 13.97 @ 99.28 • 4087 lb • 20.1 avg MPG • Nelson Ledges Lap: 1:30 3.4" pulley • AL104 plugs • 180º t-stat • FWI w/K&N • 1.9:1 rockers • OR pushrods • LS6 valve springs • SLP headers • ZZP fuel rails KYB GR2 struts • MaxAir shocks • Addco sway bars • UMI bushings • GM STB • Enkei 18" EV5s w/ Dunlop DZ101s • F-body calipers EBC bluestuff/Hawk HP plus • SS lines • Brembo slotted discs • DHP tuned • Aeroforce • Hidden Hitch^^^ SOLD ^^^ '70 Ninety-Eight Holiday Coupe 455cid • 116k miles^^^ SOLD ^^^ | |
| Subject: Re: tortuga Tue Jan 04, 2011 12:16 am | |
- What's the advantage to reaching it from the drivers seat?
To take a hit while ur drivin | |
| Subject: Re: tortuga | |
| tortuga | |
