 Strong gasoline smell
Mikel
9 posters
Mikel
Strong gasoline smell Empty
PostSubject: Strong gasoline smell   Strong gasoline smell EmptySat Oct 03, 2009 8:22 pm
Hello,
I've been having a strong gasoline smell come off the vents in my 97 Riviera. It also seems to come from under the car, although I haven't found any visible leaks yet. Are there any known trouble areas to look for?
Thank you.
Mikel
PostSubject: Re: Strong gasoline smell   Strong gasoline smell EmptySat Oct 03, 2009 8:40 pm
check for cracks in your headers and exhaust. check also for clogged cat...
PostSubject: Re: Strong gasoline smell   Strong gasoline smell EmptySat Oct 03, 2009 9:07 pm
You should look closer and will probably find a leak somewhere. Remove the engine cover and look closely. Also jack the car up where you can get underneath it and examine all the fuel lines and tank area, filter etc.
Bert tavis
PostSubject: Re: Strong gasoline smell   Strong gasoline smell EmptySat Oct 03, 2009 9:12 pm
also (immediately) check the nylon fuel lines in the engine compartment just in front of the cowl, part are under the engine cover and part are not.
As Bert says, you will probably fined a leak somewhere.
PostSubject: Re: Strong gasoline smell   Strong gasoline smell EmptySat Oct 03, 2009 10:22 pm
Check those nylon fuel lines!!! !!! !!! !!!
PostSubject: Re: Strong gasoline smell   Strong gasoline smell EmptySun Oct 04, 2009 1:53 am
also check injectors O rings...may be leaking from there tho...
PostSubject: Re: Strong gasoline smell   Strong gasoline smell EmptySun Oct 04, 2009 3:57 pm
whatever you do DON'T blow it off. Please find it and let us know what you find.
Mikel
PostSubject: Re: Strong gasoline smell   Strong gasoline smell EmptySun Oct 04, 2009 5:33 pm
One of the fiberglass hoses had split right at a joint, next to the cowl. Fixed!
Thank you all.
Merit : 150
PostSubject: Re: Strong gasoline smell   Strong gasoline smell EmptySun Oct 04, 2009 7:14 pm
Thank you all.
Glad you found your leak, and fixed it.
I thought I would pass this along. I have a friend with a 97 Riviera. He had a gasoline smell that he could not find for about a year. No visible leaks anywhere and he checked everywhere. At least he thought he had until he looked under the access panel for the fuel pump. There are metal fingers molded into the gas tank that grab the twist lock ring that holds the fuel pump assembly in. What had happened was a few of those fingers had rotted to the point that the pump was sitting up at an angle, and that was his problem. He said there was a lot of sand and debris back there and also quite a bit of rust. I checked mine a few weeks back and found quite a bit of rust and debris. I wire brushed it, hit with some rust reformer, and put some white grease in there to seal out as much moisture as possible. I advise anyone with a 95-99 Riv to check that area. My friend told me the fix for his problem was expensive and a royal pain in the butt. An ounce of prevention thumbsup
Sweepspear
Sweepspear
PostSubject: Re: Strong gasoline smell   Strong gasoline smell EmptyMon Oct 05, 2009 10:48 am
I just discovered and fixed a gas leak this past weekend on the '96.
While looking for a coolant leak (waterpump) I smelled raw gas, and noticed staining on top of the supercharger.
Started the car and sure enough, there was a small pinhole weeping leak from the 5/16" line right were it enters the fuel rail!
Bought one of those Dorman repair kits #800-57 and that took care of it.
I don't know how long I have been driving around with that time bomb under the hood! I'm sure all summer.
The wife did mention she thought the car smelled like gas at one time.
I didn't tell her I found a leak, lest I be given repeated "I told you so's."
nono rolleyes
seviper22
PostSubject: Re: Strong gasoline smell   Strong gasoline smell EmptyMon Nov 09, 2009 5:59 pm
same thing happen to mine 2 fuel lines had leaks and it got bad but thank god it only 10$ fix
» What Octane Grade Fuel for 3800 SC?
» HELP! dark gasoline leak
» raw gas smell
» Smell under hard acceleration?
» Gas smell at top of motor
