dreww Junkie
| Subject: code p0748??? Fri Oct 23, 2009 7:22 pm | |
| K, got the new pcm in the car, but Im pulling up this code occasionally. what is it? I want to know what the code is for before I remove it. | |
| Subject: Re: code p0748??? Fri Oct 23, 2009 7:29 pm | |
| Short answer, Pressure Control Solenoid, A
Would have to look up in the FSM for more info. I have a small utility program for these brief descriptions. Do you have a FSM for your car.? I thought you did with all the PCM work and wiring changes planned. | |
dreww Junkie
| Subject: Re: code p0748??? Sat Oct 24, 2009 1:14 am | |
| sounds like something for the trans. i dont have my new trans in which is electronically controlled by this new pcm the computer is trying to read the trans and my stoxk 96 is vac controlled....so its not sending signals to the new pcm | |
| Subject: Re: code p0748??? | |
