 clicking noise around dash.... then almost dies....
4 posters
ssei turbo
ssei turbo
clicking noise around dash.... then almost dies.... Empty
PostSubject: clicking noise around dash.... then almost dies....   clicking noise around dash.... then almost dies.... EmptySun Dec 06, 2009 2:48 pm
well as the title says, sometimes when i start the car, while it's idling i'll occasionally hear this "clicking noise" , kinda like a relay click. at the same time of the click the engine does a little shutter.. after a while it'll run smooth, but over the past week or so it seems to have gotten a little worse.. anyone have any suggestions as to what this could be? i said it sounds like it's coming from the dash, but it seems loudest around the shifter console.. make any sense? thanks in advance for anyone who can help me with this..
PostSubject: Re: clicking noise around dash.... then almost dies....   clicking noise around dash.... then almost dies.... EmptySun Dec 06, 2009 3:48 pm
Check your battery cables at the battery and check the positive/negative connections under the hood and verify nothings loose or corroded. Especially the cables at the battery. Remove them and inspect closely. Peel the rubber insulators back away from the cable end so you can verify condition.
Bert tavis
PostSubject: Re: clicking noise around dash.... then almost dies....   clicking noise around dash.... then almost dies.... EmptySun Dec 06, 2009 4:41 pm
Possible ignition switch?
PostSubject: Re: clicking noise around dash.... then almost dies....   clicking noise around dash.... then almost dies.... EmptySun Dec 06, 2009 5:07 pm
I second what Derek said but definitely check the normal culprits like battery, connections and whatnot (as Bert suggested). Your symptoms sound similar to what it sounded like on my Regal when the ignition switch went south though.
GL
ssei turbo
ssei turbo
PostSubject: Re: clicking noise around dash.... then almost dies....   clicking noise around dash.... then almost dies.... EmptyMon Dec 07, 2009 8:31 am
cool, i'll start off by checking the battery connections and the connections under the hood. i'll post again when i get it done. thanks guys.
» Dash lights/Brights clicking on and off when starting car
» Unknown Clicking Noise Coming From Center Console
» Car just dies
» Strange intermittent vibration/chatter/noise behind dash
» Curious about "clicking" sound.
