 Does this leak look like a problem?
6 posters
Does this leak look like a problem? Empty
PostSubject: Does this leak look like a problem?   Does this leak look like a problem? EmptyMon Dec 21, 2009 7:22 pm
Does this leak look like a problem? Leak
It doesn't appear to have progressed any in the last couple years. A mechanic said it was fine then.
PostSubject: Re: Does this leak look like a problem?   Does this leak look like a problem? EmptyMon Dec 21, 2009 7:24 pm
If it hasn't progressed, and is not wet, then it is probably more than likely a stain and not a leak.
Although it is in a precarious spot, right near the coolant passage. Actually could just be some seapage from the valve cover.
I wouldn't worry about it if I saw that on my car.
Hey, could you use one of those new foam filters that's deteriorated on your solenoid.
I'll mail you an extra I have if you want it.
Merit : 149
PostSubject: Re: Does this leak look like a problem?   Does this leak look like a problem? EmptyMon Dec 21, 2009 7:44 pm
My LIM gasket seeps a bit in that area. I notice it more during cold weather. coolant level is unchanged though. I think I'll change it in the Spring.
PostSubject: Re: Does this leak look like a problem?   Does this leak look like a problem? EmptyMon Dec 21, 2009 8:55 pm
I don't think it's wet. It looks old (and is old). I'm paranoid that the Dexcool is going to take out my gaskets before it's convenient to change them.
I'm not turning down a freebie lol I don't know where the solenoid is or what condition the filter is in though. Still got some learnin' to do. teach
PostSubject: Re: Does this leak look like a problem?   Does this leak look like a problem? EmptyMon Dec 21, 2009 9:02 pm
In that pic you posted, look above the red circle.
There is a deteriorated and half eaten foam filter that it designed to filter the air going into that switch.
Do You See It.??????
It has left that tube open and exposed.!!!!!
I forget the proper name for it at the moment.
Mark (Eldo), sent me 2, I'm willing to mail you one if you want.
Merit : 104
PostSubject: Re: Does this leak look like a problem?   Does this leak look like a problem? EmptyMon Dec 21, 2009 9:04 pm
Hey, could you use one of those new foam filters that's deteriorated on your solenoid. I'll mail you an extra I have if you want it.
He's referring to the Boost Control Solenoid valve, which has a delicate foam filter on one of its ports, right where it gets destroyed when you change the thermostat... The torn filter is in your photo, right above your red circles.
Merit : 104
laughat There we are in stereo again, Rick!
PostSubject: Re: Does this leak look like a problem?   Does this leak look like a problem? EmptyMon Dec 21, 2009 9:06 pm
This is getting Bizarre.!!!!!!!
JR,
I'll mail the foam filter soon.
Still have all info on file. I think.?
Rick
PostSubject: Re: Does this leak look like a problem?   Does this leak look like a problem? EmptyMon Dec 21, 2009 10:02 pm
it's a slow process, you'll know about it before you get stranded, as long as you check your fluids regularly. The gaskets don't fail catastrophically or suddenly.
PostSubject: Re: Does this leak look like a problem?   Does this leak look like a problem? EmptyMon Dec 21, 2009 11:19 pm
Damn, I see what you guys are talking about now! How could I have missed it?
May be the work of my mouse friends again. The top of my engine is covered in acorn shells.
How can cars be designed this way?
Well, that's a relief. Thanks for the tip.
PostSubject: Re: Does this leak look like a problem?   Does this leak look like a problem? EmptyMon Dec 21, 2009 11:26 pm
The little sponge filter has been missing from mine for maybe 150k miles. No problems so far.
To see if your LIM gasket is bad, check your spark plugs. If coolant is weeping into the cylinders, it will leave deposits on your plug electrodes. If plugs look good, I wouldn't worry too much. Or it could be oil from the valve cover gaskets. An easy fix, but probably not worth getting excited over.
PostSubject: Re: Does this leak look like a problem?   Does this leak look like a problem? EmptyTue Dec 22, 2009 1:33 am
I don't think there's a problem with the plugs, but I'll check.
PostSubject: Re: Does this leak look like a problem?   Does this leak look like a problem? EmptyTue Dec 22, 2009 6:56 pm
The leak is dry, like I thought.
I pulled a spark plug -
Does this leak look like a problem? Deposit
I've noticed the exhaust is awfully strong smelling - maybe running 104's with no mods has caught up with me?
PostSubject: Re: Does this leak look like a problem?   Does this leak look like a problem? EmptyTue Dec 22, 2009 7:05 pm
Prior to doing any Mod's on my car and trying to run AL 104's was not worth doing. The plugs got lightly fouled relatively quick.
I changed back to a stock heat range AC Delco plug until I finally finished the current mod's.
I don't recommend changing the heat range on your plugs unless the engine requires it.
I knew better, but tried anyway when I was due a plug change. Didn't run them for more than 3,000 miles before I switched back to stock.
After installing the 3.4" pulley, which was the last thing I did, then I changed plugs. They were burning clean the last time i checked, which was about 1,000 miles after install.
Now that you mention it I'm due to check them again, it's just too cold out right now.
I'll wait until ambient gets over freezing then I'll pull a front and a rear to inspect them.
PostSubject: Re: Does this leak look like a problem?   Does this leak look like a problem? EmptyTue Dec 22, 2009 7:09 pm
What do the plugs need to be torqued down to?
PostSubject: Re: Does this leak look like a problem?   Does this leak look like a problem? EmptyTue Dec 22, 2009 7:17 pm
I don't know what the manual calls out for a specific torque.
But I just have my right arm calibrated once a year and it seems to work good for me.
Maybe someone else knows the correct torque per the FSM ?
Merit : 149
PostSubject: Re: Does this leak look like a problem?   Does this leak look like a problem? EmptyTue Dec 22, 2009 7:26 pm
They are tapered seat plugs. 1/16 of a turn past hand tight. Most people over tighten them. I think it is something like 15 ft. lbs, but I would never put a torque wrench on plugs. It just isn't necessary.
Btw, my leak is external only. It never drips. It's just wet below the corner of the intake.
Merit : 149
PostSubject: Re: Does this leak look like a problem?   Does this leak look like a problem? EmptyTue Dec 22, 2009 7:30 pm
I just looked in the FSM. 11 ft lbs. My 1970 Chassis manual says 15 ft lbs. Same type of plug, tapered seat.
PostSubject: Re: Does this leak look like a problem?   Does this leak look like a problem? EmptyTue Dec 22, 2009 7:50 pm
4 of mine are always clean. Cylinders 2 and 6 get deposits from the LIM leaking coolant. It's not too bad, and I've been meaning to fix it, but the problem doesn't seem to be getting any worse for now, so I have been changing my oil every 2500 miles until spring.
PostSubject: Re: Does this leak look like a problem?   Does this leak look like a problem? EmptyTue Dec 22, 2009 7:58 pm
Aaron, do you know if that is typical by any chance.?
I mean is it usually #2 and #6 that show an internally leaking LIM gasket.?
If so, then it would make sense for me to pull only those plugs when I do a plug check.
PostSubject: Re: Does this leak look like a problem?   Does this leak look like a problem? EmptyTue Dec 22, 2009 8:04 pm
I'm not sure. I know it's been typical on mine for over a year.
PostSubject: Re: Does this leak look like a problem?   Does this leak look like a problem? EmptyTue Dec 22, 2009 8:51 pm
I took out the easy plug by the leak - is that six?
PostSubject: Re: Does this leak look like a problem?   Does this leak look like a problem? EmptyTue Dec 22, 2009 8:54 pm
That's #5.
» FAQ: Wet Carpet - Interior Leak Problems
» EGR Leak
» Oil leak...from where???
» A/C LEAK
» Oil leak?
