| Differential removal | |
+5robotennis61 albertj Mr.Riviera AA T Riley 9 posters |
T Riley Guru
| Subject: Differential removal Tue May 04, 2010 7:24 pm | |
| Sooo has anyone ever pulled the diff on a riv? all my tranny fluid is laying on the side of the road somewhere and my cv shaft is dangling along with the diff cover I dun fugged it up | |
| Subject: Re: Differential removal Tue May 04, 2010 10:03 pm | |
| Where you doing burn-outs? _________________ '05 GTO 6.0L • 6-spd • 95k miles • 0-60: 4.8s • 16.9 avg MPG • Nelson Ledges Lap: 1:26'95 Celica GT 2.2L • 5-spd • 165k miles • 0-60: yes'98 SC Riviera • 281k miles • 298 HP/370 TQ • 0-60: 5.79s • ET: 13.97 @ 99.28 • 4087 lb • 20.1 avg MPG • Nelson Ledges Lap: 1:30 3.4" pulley • AL104 plugs • 180º t-stat • FWI w/K&N • 1.9:1 rockers • OR pushrods • LS6 valve springs • SLP headers • ZZP fuel rails KYB GR2 struts • MaxAir shocks • Addco sway bars • UMI bushings • GM STB • Enkei 18" EV5s w/ Dunlop DZ101s • F-body calipers EBC bluestuff/Hawk HP plus • SS lines • Brembo slotted discs • DHP tuned • Aeroforce • Hidden Hitch^^^ SOLD ^^^ '70 Ninety-Eight Holiday Coupe 455cid • 116k miles^^^ SOLD ^^^ | |
| Subject: Re: Differential removal Tue May 04, 2010 11:06 pm | |
| wait, didnt you just get new 555R tires?? _________________ 1996 with 254k miles, L32 4" FWI -> ported N* -> Ported Gen V w/3.0" Pulley, Stage 3 Phenolic I/C, ZZP FMHE, 1.84 RR, Headers and 3" pipe to mufflers, F-body brakes, and lowered on Eibachs. -RIP AMG C400 White on black. Stage 2 w/E30 - 11.9@117 -daily | |
| Subject: Re: Differential removal Wed May 05, 2010 1:37 am | |
| - 98riviera98 wrote:
- Sooo has anyone ever pulled the diff on a riv?
I dun fugged it up Please comment - what led to this problem? Albertj | |
| Subject: Re: Differential removal Wed May 05, 2010 1:43 am | |
| QUE?! OTRA VEZ? INGRATO! DESCUIDADO! TIRA BUZONES! NO TENAIS VERGUENZA?? Y SU MAMA TAMBIEN! | |
T Riley Guru
| Subject: Re: Differential removal Wed May 05, 2010 5:39 am | |
| lol.. the DR's weren't even on yet! I was driving normal. (no joke) before it went into 2nd gear.. it went KABOOOMSHAKALAKA.. well anyway.. PLEASE if you know.. how do you remove the diff | |
T Riley Guru
| Subject: Re: Differential removal Wed May 05, 2010 4:58 pm | |
| Subject: Re: Differential removal Wed May 05, 2010 6:00 pm | |
| Travis, You have a subscription to AllData. Does that not have at least some of the information you need to get started. Try getting started and then maybe I'll stop and open my manual and try to learn and help. But I would venture to guess that very few, if anyone on here has done one before. So, instead of just starting out looking for all the answers, maybe you need to ask some direct questions.
Even though I was apprehensive in answering your question that way I know you can understand and take it without a big Red X. This is part of what I mentioned in the other thread. Sometimes it is the only way I know how to say something and some people just don't have the extra layer of skin to tolerate it. But not Travis, he understands, that I will help him help himself. | |
T Riley Guru
| Subject: Re: Differential removal Wed May 05, 2010 8:01 pm | |
| - Rickw wrote:
- Travis,
Even though I was apprehensive in answering your question that way I know you can understand and take it without a big Red X. This is part of what I mentioned in the other thread. Sometimes it is the only way I know how to say something and some people just don't have the extra layer of skin to tolerate it. But not Travis, he understands, that I will help him help himself. LOL rick your a life saver.. I FORGOT ABOUT ALLDATA i'm such a n00b | |
T Riley Guru
| Subject: Re: Differential removal Wed May 05, 2010 10:56 pm | |
| I still cannot find any info anywhere... I am pretty sure i can figure most of it out.. but I need to know the tid bits on how to reset the diff pin and things like that.. | |
| Subject: Re: Differential removal Wed May 05, 2010 11:47 pm | |
| Travis, instead of looking for "differential", try looking under "Final Drive"... | |
T Riley Guru
| Subject: Re: Differential removal Wed May 05, 2010 11:49 pm | |
| - Eldo wrote:
- Travis, instead of looking for "differential", try looking under "Final Drive"...
will do | |
T Riley Guru
| Subject: Re: Differential removal Fri May 07, 2010 2:26 am | |
| Well I got the diff out.. it was super easy.. I fried the FUGG outta it.. lolz i have pictures and THEY WILL come... my Diff ESPLODED... I'm debating on welding the spider gears.... its an idea at this moment... | |
| Subject: Re: Differential removal Fri May 07, 2010 9:03 am | |
| I have an Intense 3rd gen LSD if you are interested... | |
| Subject: Re: Differential removal Fri May 07, 2010 9:41 am | |
| - Quote :
- Well I got the diff out.. it was super easy.. I fried the FUGG outta it.. lolz i have pictures and THEY WILL come... my Diff ESPLODED... I'm debating on welding the spider gears.... its an idea at this moment...
Classic symptoms of the one-wheel burn-out. _________________ '05 GTO 6.0L • 6-spd • 95k miles • 0-60: 4.8s • 16.9 avg MPG • Nelson Ledges Lap: 1:26'95 Celica GT 2.2L • 5-spd • 165k miles • 0-60: yes'98 SC Riviera • 281k miles • 298 HP/370 TQ • 0-60: 5.79s • ET: 13.97 @ 99.28 • 4087 lb • 20.1 avg MPG • Nelson Ledges Lap: 1:30 3.4" pulley • AL104 plugs • 180º t-stat • FWI w/K&N • 1.9:1 rockers • OR pushrods • LS6 valve springs • SLP headers • ZZP fuel rails KYB GR2 struts • MaxAir shocks • Addco sway bars • UMI bushings • GM STB • Enkei 18" EV5s w/ Dunlop DZ101s • F-body calipers EBC bluestuff/Hawk HP plus • SS lines • Brembo slotted discs • DHP tuned • Aeroforce • Hidden Hitch^^^ SOLD ^^^ '70 Ninety-Eight Holiday Coupe 455cid • 116k miles^^^ SOLD ^^^ | |
T Riley Guru
T Riley Guru
| Subject: Re: Differential removal Fri May 07, 2010 2:22 pm | |
| - deekster_caddy wrote:
- I have an Intense 3rd gen LSD if you are interested...
I probably can't afford it | |
T Riley Guru
| Subject: Re: Differential removal Sat May 08, 2010 9:34 pm | |
| I got a new diff.. now need to put it in | |
| Subject: Re: Differential removal Sat May 08, 2010 10:08 pm | |
| where'd you get the diff? (and did you find the info you needed under Final Drive?) | |
T Riley Guru
| Subject: Re: Differential removal Sat May 08, 2010 11:44 pm | |
| - Eldo wrote:
- where'd you get the diff?
(and did you find the info you needed under Final Drive?) i got the diff on a local forum had to drive 120 miles to get it.. and no i didn't find crap on Alldata.. i found my INFO herrrr son. http://www.grandprixforums.net/f21/4t65e-differential-install-pics-1928.html GREAT info.. i vote sticky for the High HP guys when they grenade their diff's | |
| Subject: Re: Differential removal Sun May 09, 2010 2:11 pm | |
| Do you have any pic's of the destruction yet.? Would like to see. - 98riviera98 wrote:
I probably can't afford it First off, Derek, what is a 3rd gen LSD and Travis, how do you know you can't afford it without asking how much. Even though I don't know specifically what it is, HA. STILL want pic's or it didn't happen. | |
T Riley Guru
| Subject: Re: Differential removal Sun May 09, 2010 8:14 pm | |
| Subject: Re: Differential removal Sun May 09, 2010 8:40 pm | |
| OUCH, it looks bad, but if you say it can be up and running quickly, i believe you. Especially seeing your NEW ride. HAHAHAHA
| Subject: Re: Differential removal Sun May 09, 2010 8:42 pm | |
^^ car i bought for 200 bucks while riv is down for a bit.. (thought the damage was wayyyy worse..) Things must have looked bad for this to be purchased. Maybe Ilan will buy it when your done with it for a college run-about. | |
| Subject: Re: Differential removal Sun May 09, 2010 11:25 pm | |
| What a miserable job... I can't believe you can do it with the tranny in the car! | |
| Subject: Re: Differential removal | |
