| measuring resistance for duplicate keys... help? | |
LaFlare Member
Name : G Joined : 2010-07-14 Post Count : 84 Merit : 1
 | Subject: measuring resistance for duplicate keys... help? Fri May 06, 2011 3:36 pm | |
| i only have 1 key and no spares so i plan on getting a blank key online or on ebay, but before i order i have to know the resistance of course and they will come programed already.
i'm not too savvy with the technical sides of things, but i'm trying to measure this keys chip and i cant get a reading? im using this craftsman multi meter, i set it to ohms, press down on each end of the little metal piece, and the screen shows random numbers for a few seconds then goes to 000. doesnt give me a set number?
also side note, this whole vats security stuff, will it be a problem later down the road because in the future i plan on installing a viper alarm with autostart... | |
 | Subject: Re: measuring resistance for duplicate keys... help? Fri May 06, 2011 4:08 pm | |
| Set the range correctly on your meter. Start with the lowest range and work up. The key pellet should measure in the hundred or thousands (K) of ohms. Here's a list of possible values:  _________________ '05 GTO 6.0L • 6-spd • 95k miles • 0-60: 4.8s • 16.9 avg MPG • Nelson Ledges Lap: 1:26'95 Celica GT 2.2L • 5-spd • 165k miles • 0-60: yes'98 SC Riviera • 281k miles • 298 HP/370 TQ • 0-60: 5.79s • ET: 13.97 @ 99.28 • 4087 lb • 20.1 avg MPG • Nelson Ledges Lap: 1:30 3.4" pulley • AL104 plugs • 180º t-stat • FWI w/K&N • 1.9:1 rockers • OR pushrods • LS6 valve springs • SLP headers • ZZP fuel rails KYB GR2 struts • MaxAir shocks • Addco sway bars • UMI bushings • GM STB • Enkei 18" EV5s w/ Dunlop DZ101s • F-body calipers EBC bluestuff/Hawk HP plus • SS lines • Brembo slotted discs • DHP tuned • Aeroforce • Hidden Hitch^^^ SOLD ^^^ '70 Ninety-Eight Holiday Coupe 455cid • 116k miles^^^ SOLD ^^^  | |
jlaw Member
Name : Jay Location : Vancouver Island, Canada Joined : 2011-04-19 Post Count : 70 Merit : 2
 | Subject: Re: measuring resistance for duplicate keys... help? Fri May 06, 2011 4:37 pm | |
| I just had this done at the GM dealer - $80 cdn for a copy, figured it was worth it... | |
flyineagle96 Junkie
Name : James E Age : 54 Location : Dalton,Mass Joined : 2009-12-21 Post Count : 915 Merit : 23
 | Subject: Re: measuring resistance for duplicate keys... help? Fri May 06, 2011 6:37 pm | |
| Your local lock shop, would have made you one for $35.oo !!! | |
Name : Location : Finger Lakes of New York State Joined : 2007-05-31 Post Count : 8542 Merit : 181
 | Subject: Re: measuring resistance for duplicate keys... help? Sat May 07, 2011 10:17 am | |
| - LaFlare wrote:
- i only have 1 key and no spares so i plan on getting a blank key online or on ebay, but before i order i have to know the resistance of course and they will come programed already.
also side note, this whole vats security stuff, will it be a problem later down the road because in the future i plan on installing a viper alarm with autostart... You have to measure not along the length of the metal pellet but from one side to the other, basically *through* the key. The multimeter is working correctly, it's using an autoranging feature to guess what the right scale should be then telling you there's no resistance. Finally, about that VIper: you might want to look for the other posts on this site about installing aftermarket alarms. | |
jlaw Member
 | Subject: Re: measuring resistance for duplicate keys... help? Sat May 07, 2011 11:43 am | |
| My local lock shop told meI had to get the blank with the right resistor from the dealer, which was most of the cost. | |
96RIVMANN Fanatic
Name : Paul Location : MN Joined : 2007-10-22 Post Count : 253 Merit : 11
 | Subject: Re: measuring resistance for duplicate keys... help? Sun May 08, 2011 10:52 pm | |
| Just measure the resistance across the key and solder in a resistor inline with the security wires. They are two thin wires encased in a black shield leading down from the ignition. | |
 | Subject: Re: measuring resistance for duplicate keys... help?  | |
