 Write-Up: Front/Rear (Addco) Stabilizer/Sway Bar Installation
Natesriv
pbrktrt
brutusk1
Jamax
97 park ave
Ash
sdconcepts
EatDirtFartDust
napalmpt
Face
44 posters
Go to page : Previous  1 ... 10 ... 17, 18, 19, 20, 21, 22  Next
Merit : 17
Write-Up: Front/Rear (Addco) Stabilizer/Sway Bar Installation - Page 18 Empty
PostSubject: Re: Write-Up: Front/Rear (Addco) Stabilizer/Sway Bar Installation   Write-Up: Front/Rear (Addco) Stabilizer/Sway Bar Installation - Page 18 EmptyMon Apr 01, 2013 11:42 am
Will these energy suspension stabilizer bar bushings fit my rear addco bar? they are 7/8 in. or 22mm.
http://www.energysuspensionparts.com/proddetail.asp?prod=9.5158
I'm having a hard time figuring out a bushing that will work.
PostSubject: Re: Write-Up: Front/Rear (Addco) Stabilizer/Sway Bar Installation   Write-Up: Front/Rear (Addco) Stabilizer/Sway Bar Installation - Page 18 EmptyMon Apr 01, 2013 1:26 pm
Probably not, but you could try them. I think they're just the wrong general shape. Best option is the OEM FE2 (orange) rubber bushings. These are discussed earlier in the thread.
Merit : 150
PostSubject: Re: Write-Up: Front/Rear (Addco) Stabilizer/Sway Bar Installation   Write-Up: Front/Rear (Addco) Stabilizer/Sway Bar Installation - Page 18 EmptyMon Apr 01, 2013 1:57 pm
Here's a picture of the bushings needed. The ones on the left fit the Addco bar. You can make out the GM part number.
Write-Up: Front/Rear (Addco) Stabilizer/Sway Bar Installation - Page 18 22714674016_large[/quote]
PostSubject: Addco front sway bar for 1995 Riviera, Addco asking for photos, specs   Write-Up: Front/Rear (Addco) Stabilizer/Sway Bar Installation - Page 18 EmptyFri Apr 12, 2013 11:59 am
I dropped an email to Addco product development yesterday and pointed out that they only make a replacement rear sway bar for the 1995 Riviera, but not a front. However, they do make both front and rear replacments for later years of this series.
I mentioned that there seems to be a lot of 1995 owners that can't get replacement or peroformance parts for that particular year, and an Addco front bar was one of those so I suspected they could sell quite a few.
With that, they asked me if I could provide photos of the front bar for the 1995 Riviera. They didn't say if they wanted photos of the bar installed or out of the car, but I would suspect that both examples would be helpful, especially out of the car so they can see how the bar is bent, etc.
So, does anyone have, or could take, any photos of the 1995 Riviera sway bar out of the car? I could take some of mine as installed. It would be great to give them any significant dimensions as well if someone has the bar out the car.
If someone had a junked 1995, we could even think about mailing them one if they asked as that might make it really easy for them to fabricate.
Thanks,
PostSubject: Re: Write-Up: Front/Rear (Addco) Stabilizer/Sway Bar Installation   Write-Up: Front/Rear (Addco) Stabilizer/Sway Bar Installation - Page 18 EmptyFri Apr 12, 2013 12:20 pm
Al, I think it might be time for you to remove your front bar to photograph, or visit a local yard and purchase one. They can't be selling for very much. You can drive the car with no bar short term without too much consequence
Props to Addco for showing interest and responding to your request. Give them what they need to get the process started! Other '95 owners are counting on you!
PostSubject: Re: Write-Up: Front/Rear (Addco) Stabilizer/Sway Bar Installation   Write-Up: Front/Rear (Addco) Stabilizer/Sway Bar Installation - Page 18 EmptyFri Apr 12, 2013 12:30 pm
I was thinking along the same lines, although I read in a prior thread about about difficult it was to remove the front OEM sway and the one 95 I've found in a local yard is on the ground with no wheels, so that isn't easy either.
I may do so anyway though, but was curious if anyone just coincidentally had a 95 front sway already out that could be photographed to save some time.
Thanks,
PostSubject: Re: Write-Up: Front/Rear (Addco) Stabilizer/Sway Bar Installation   Write-Up: Front/Rear (Addco) Stabilizer/Sway Bar Installation - Page 18 EmptySat Apr 13, 2013 9:42 am
Do we know if the front sway bar for the 1995 and 1996 are the same?
I found an eBay auction by our friends at Morad for a 1996 OEM front sway bar that they list as being compatible. If so, that might be an even larger incentive for Addco as it would cover two model years.
I've asked Morad if they can confirm the x-ref and if I can use their photos for Addco.
PostSubject: Re: Write-Up: Front/Rear (Addco) Stabilizer/Sway Bar Installation   Write-Up: Front/Rear (Addco) Stabilizer/Sway Bar Installation - Page 18 EmptySat Apr 13, 2013 10:25 am
i have the addco bars on my 96.
Write-Up: Front/Rear (Addco) Stabilizer/Sway Bar Installation - Page 18 Dsc_0110
PostSubject: Re: Write-Up: Front/Rear (Addco) Stabilizer/Sway Bar Installation   Write-Up: Front/Rear (Addco) Stabilizer/Sway Bar Installation - Page 18 EmptySat Apr 13, 2013 11:31 am
According to our holy grail parts thread, 95 & 96 share the same stabilizer bar part #. Merging to the Addco sway bar thread...
PostSubject: Re: Write-Up: Front/Rear (Addco) Stabilizer/Sway Bar Installation   Write-Up: Front/Rear (Addco) Stabilizer/Sway Bar Installation - Page 18 EmptySat Apr 13, 2013 8:56 pm
Hi, you have the Addco front and rear on your 96? ? That would be interesting news cool
I was under the impression, as is Addco I believe, that they do not have a front bar for the 95 & 96.
Did you get the "97-01" front and rear?
According to the Addco catalog, this is what they offer for the Riviera.
FRONT BAR
YEAR STOCK # DIAMETER ENDLINK KIT NOTE #
97-01 2018 1 1/4″ 015
86-96 N/A N/A N/A
REAR BAR
97-01 2015 7/8″ N/A
86-96 419 7/8″ 019 13
Ed Morad sent me some photos of a 96 front bar, which he is also under the impression is identical to a 95. So I sent those photos to Addco. Ed even offered to send a bar to Addco, which was really great. Be sure to send him any business. BTW, he apparently has a 96 green Riviera right now from the photos in his eBay ad.
Thanks!
PostSubject: Re: Write-Up: Front/Rear (Addco) Stabilizer/Sway Bar Installation   Write-Up: Front/Rear (Addco) Stabilizer/Sway Bar Installation - Page 18 EmptySun Apr 14, 2013 12:07 am
Nice work. I think it's apparent the Addco front bar will work on a '95, but Addco has only just now been made aware of it.
PostSubject: Re: Write-Up: Front/Rear (Addco) Stabilizer/Sway Bar Installation   Write-Up: Front/Rear (Addco) Stabilizer/Sway Bar Installation - Page 18 EmptySun Apr 14, 2013 8:28 am
I haven't heard back from Addco yet. I just sent them the photos yesterday.
Am also waiting for Mr.Riviera to confirm what bars, model and front and rear he fit up to this 96. Would also want to confirm he has the 96 lower control arms still and not the later ones, although not sure that would matter.
But yes, that would be good news if the Addco bars fit 95 & 96 directly thumbsup
PostSubject: Re: Write-Up: Front/Rear (Addco) Stabilizer/Sway Bar Installation   Write-Up: Front/Rear (Addco) Stabilizer/Sway Bar Installation - Page 18 EmptySun Apr 14, 2013 9:58 am
Ill have to check part numbers when i get home. I am running solid larger front and rear sway bars, not sure anyone but addco makes them and i have the 96 lca because the 97+ ones do not fit bc of a bushing change.
Merit : 66
PostSubject: Hopefully my last post on the subject   Write-Up: Front/Rear (Addco) Stabilizer/Sway Bar Installation - Page 18 EmptySun Apr 14, 2013 11:13 am
I don't monitor this site much anymore so I missed this thread's expansion. Sort of bored with the riv a bit but it has been reliable!
The addco catalogue is garbage. It has always been riddled with errors. There were glaring errors back in the regalgs.org group buy days, and there still are now. The bar was never designed for the Riv. It was specifically made for the STS with the other G-body vehicle applications being an afterthought. Addco was made aware of the catalogue application issue multiple times over several year and did nothing. For the final time, IGNORE the Addco parts catalogue. The part numbers are 02015 and 02018 for all 95-99 rivieras.
The front bars fit 95-99 rivieras. The difference between the 95-96 and 97+ bars is just the diameter.
Go for the addco bars. It's a great -perhaps the best- handling mod.
Has anyone tried an addco 2015 in the back and an F41 up front? Based on 0 firsthand experience and only what i've read here, this combo plus the STS STB is what I think I am looking for.
Front Sway Bar P/N# 25649664 = F41 sport tuned '97-2004 PAU
Don't bother with the F41 front/addco rear combo. The bars will be mismatched. On p. 19 I showed the cut bars, and expanded on the increase in stiffness. The F41 is a hollow 30mm bar. The spreadsheet below should help you see why. Someone on a tight budget could benefit from getting both matched OEM STS bars (30mm hollow front, 22mm hollow rear) bars from a u-pull-it.
I'm getting pretty tired of posting this kind of thing so here's a link to the G-Body (FWD) swaybar google docs spreadsheet. LMK if it works.
PostSubject: Re: Write-Up: Front/Rear (Addco) Stabilizer/Sway Bar Installation   Write-Up: Front/Rear (Addco) Stabilizer/Sway Bar Installation - Page 18 EmptySun Apr 14, 2013 7:56 pm
Thanks!
Merit : 31
PostSubject: Re: Write-Up: Front/Rear (Addco) Stabilizer/Sway Bar Installation   Write-Up: Front/Rear (Addco) Stabilizer/Sway Bar Installation - Page 18 EmptyTue May 14, 2013 3:24 pm
Thank you, good sir. I've memorized the addco #s but it was those bushings I was looking for!
Do we need new bracket/mount things for the bushings or will the ones on the car already work fine?
AA, you should update your first post in this thread with all part #s so its not a treasure hunt each time. smile thanks!
LOL theyre like 3 posts up from here. But still. Write up threads should have all part #s in first post. Everyone agree? Ok. cool.
HOLY CRAP. $250+ for this bar?!
AA, isn't this a pic from your install?
Write-Up: Front/Rear (Addco) Stabilizer/Sway Bar Installation - Page 18 $T2eC16ZHJG8E9nyfoUPtBRC0-VD9Og~~60_12
Do you know neverenoughauto is using it?
http://www.ebay.com/itm/Addco-2018-Front-Performance-Anti-Sway-Bar-Stabilizer-Kit-/310415113460?pt=Motors_Car_Truck_Parts_Accessories&hash=item48462ebcf4&vxp=mtr
PostSubject: Re: Write-Up: Front/Rear (Addco) Stabilizer/Sway Bar Installation   Write-Up: Front/Rear (Addco) Stabilizer/Sway Bar Installation - Page 18 EmptyTue May 14, 2013 3:31 pm
Holy sh*t. It is!!! Good catch man lol.
PostSubject: Re: Write-Up: Front/Rear (Addco) Stabilizer/Sway Bar Installation   Write-Up: Front/Rear (Addco) Stabilizer/Sway Bar Installation - Page 18 EmptyTue May 14, 2013 4:07 pm
Page 23.
Merit : 31
PostSubject: Re: Write-Up: Front/Rear (Addco) Stabilizer/Sway Bar Installation   Write-Up: Front/Rear (Addco) Stabilizer/Sway Bar Installation - Page 18 EmptyTue May 14, 2013 4:13 pm
Page 23.
Did you ever say anything to them?
PostSubject: Re: Write-Up: Front/Rear (Addco) Stabilizer/Sway Bar Installation   Write-Up: Front/Rear (Addco) Stabilizer/Sway Bar Installation - Page 18 EmptyTue May 14, 2013 4:15 pm
No, I didn't say anything. When you upload an image to web, it's not "yours" anymore. They were fair in providing the bars to us, so I don't mind. Maybe I'll ask them to change the watermark and see what happens.
Make him an offer.
PostSubject: Re: Write-Up: Front/Rear (Addco) Stabilizer/Sway Bar Installation   Write-Up: Front/Rear (Addco) Stabilizer/Sway Bar Installation - Page 18 EmptyTue May 14, 2013 7:16 pm
Complete Part List for Addco Front/Rear Sway Bar Installation
Addco Front Bar- PN# 02018
*Summit- ACO-2018
Addco Rear Bar- PN# 02015
*Summit-ACO-2015
Energy Suspension Greasable Polyurethane Bushings- PN# 9.5165
*Qty-2
Energy Suspension Rear Links- PN# 9.8123G
*Qty-2
*Or buy rear links from our fearless leader AA
Addco Rear Bushings- GM PN# 25666235
*Qty-2
*I believe if you are ordering from Summit, the kit already comes with these, so no purchase necessary.
Merit : 31
PostSubject: Re: Write-Up: Front/Rear (Addco) Stabilizer/Sway Bar Installation   Write-Up: Front/Rear (Addco) Stabilizer/Sway Bar Installation - Page 18 EmptyWed Sep 25, 2013 8:34 pm
Yo yo yo!!
Where are those fancy mounts and bushings AA and Codith used, I think, on their sway bars?
I can't seem to find them!
Will somebody link me, please?
I am looking for those alien tech looking mounts+bushings for the rear 2015 Addco bar!
Thank you!
PostSubject: Re: Write-Up: Front/Rear (Addco) Stabilizer/Sway Bar Installation   Write-Up: Front/Rear (Addco) Stabilizer/Sway Bar Installation - Page 18 EmptyWed Sep 25, 2013 9:08 pm
Merit : 31
PostSubject: Re: Write-Up: Front/Rear (Addco) Stabilizer/Sway Bar Installation   Write-Up: Front/Rear (Addco) Stabilizer/Sway Bar Installation - Page 18 EmptyWed Sep 25, 2013 11:57 pm
Thank you. Looks like those are for the front addco bar.
I'll see if I can find a part number from them that will fit the rear 2015 addco bar.
PostSubject: Re: Write-Up: Front/Rear (Addco) Stabilizer/Sway Bar Installation   Write-Up: Front/Rear (Addco) Stabilizer/Sway Bar Installation - Page 18 EmptyThu Sep 26, 2013 7:48 am
There are no aftermarket rear bushings. It's a different type of mount.
Page 18 of 22Go to page : Previous  1 ... 10 ... 17, 18, 19, 20, 21, 22  Next
» Write-Up: ES Bracket Wear - UMI Performance Brackets (for Addco sway bars)
» Write-Up: Cadillac STS Rear Sway Bar Install
» REAR SWAY BAR?
» Stock Sway Bar Bushings
» Group Buy: ADDCO F/R Sway Bar Kit
