c0reyl Addict
Name : Corey Age : 32 Location : JMU virginia Joined : 2011-07-25 Post Count : 569 Merit : 2
 | Subject: Plastidip over Vinyl? Tue Jun 26, 2012 1:44 pm | |
| I've been trying to paint my vinyl matte black for a while now, and Iv'e tried dupicolor vinyl paint, and Kyrlon fusion where people say both works. I used alcohol to clean and prep, but it's flaking off still. would plasti dip work (I know it can be peeled off but would it flake off of soft vinyl?)
I would like to finally get my interior finished some day and if plasti dip wont work then I will literally pay to get my door panels vacuum molded from fiberglass with custom speaker holes | |
 | Subject: Re: Plastidip over Vinyl? Tue Jun 26, 2012 2:54 pm | |
| I think it would take more than alchohol to prep vinyl for paint.you shoud get some wax wash and cleaner from the auto paint store.you would also have to scuff up vinyl real good with a 3=M red scuff pad.it should stick
Plast-dip? I dont know..might look really awful.that stuff goes on super thick.And I bet it would peel all to shit. | |
 | Subject: Re: Plastidip over Vinyl? Tue Jun 26, 2012 3:06 pm | |
| What vinyl are you painting? How exactly are you prepping the vinyl? It's a lot of work to prep it to make paint stick.
I don't think alcohol would be enough. Lacquer thinner maybe. Scuff it up good too. Consider using an adhesion promoting primer. (there's one I've used on plastic bumpers before called "Bulldog", not sure how it would do on vinyl parts). | |
c0reyl Addict
 | Subject: Re: Plastidip over Vinyl? Wed Jun 27, 2012 10:13 am | |
| - deekster_caddy wrote:
- What vinyl are you painting? How exactly are you prepping the vinyl? It's a lot of work to prep it to make paint stick.
I don't think alcohol would be enough. Lacquer thinner maybe. Scuff it up good too. Consider using an adhesion promoting primer. (there's one I've used on plastic bumpers before called "Bulldog", not sure how it would do on vinyl parts). Basically I'm trying to make my interior black. the ABS plastic is easy to paint, but the door panels and soft vinyl seems impossible. By the way, is the steering wheel real leather wrapped or vinyl wrapped because my steering wheel is so beat up that I can't even tell | |
Name : Location : Finger Lakes of New York State Joined : 2007-05-31 Post Count : 8529 Merit : 181
 | Subject: Re: Plastidip over Vinyl? Wed Jun 27, 2012 11:09 am | |
By the way, is the steering wheel real leather wrapped or vinyl wrapped because my steering wheel is so beat up that I can't even tell Steering wheel is wrapped in real leather, but the leather is coated, has an artifical 'skin' of sorts dep on color. You should consider getting replacement for the leather part from "Wheelskins" (look it us using google or some such0 painting the soft parts is possible but you should contact an auto paint store to get the right sutff, some people call it vinyl dye or vinyl coat, basically it's a "paint" that melts into the material being painted, re-skinning it in effect. Surface must be pristine clean for it to work. See http://www.vhtpaint.com/products/vinyldye/ - you must ***scrupulously*** follow the label directions or it won't work. Follow the directions and it works fantastic. Albertj | |
charlieRobinson Expert
Name : Charlie Age : 37 Location : Toledo, OH Joined : 2011-05-17 Post Count : 3922 Merit : 30
 | Subject: Re: Plastidip over Vinyl? Fri Jun 29, 2012 8:11 pm | |
| I had awesome results with the vinyl plastic spray at autozone. I think its rustoleum? Anyways, the results were impressive and I would use it again.
 | Subject: Re: Plastidip over Vinyl?  | |
