 Cooling fans not running.
2 posters
MTRiviera
Cooling fans not running. Empty
PostSubject: Cooling fans not running.   Cooling fans not running. EmptyTue Jul 10, 2012 8:31 pm
I noticed that the cooling fans are not running on my "96 SC'd Riv. All related fuses check out as well as the relays...I think. I powered them up and could hear and feel them operate. So that leaves the temp sensor in the radiator itself. Am I missing anything here, and could it be something else? Does anyone have a part number for it? My searches are leading me nowhere. Also, is there any way to test the sensor?
Thanks, Rick
PostSubject: Re: Cooling fans not running.   Cooling fans not running. EmptyTue Jul 10, 2012 9:12 pm
What is your coolant temp gauge reporting? Fans may not turn on until above 220ºF. Do the fans turn on when you have the AC on?
MTRiviera
PostSubject: Re: Cooling fans not running.   Cooling fans not running. EmptyTue Jul 10, 2012 9:39 pm
Aaron, I just went and checked one more time, fans are working. Started car, fans run, AC on, fans running. Road test, up to temp(200 deg.) fans running, although rather slowly. So, don't know what to think.
Rick
PostSubject: Re: Cooling fans not running.   Cooling fans not running. EmptyTue Jul 10, 2012 9:58 pm
Our radiators are pretty good at keeping the engine cool without much help. As long as your coolant temp stays around 200, you don't really need the fans. The engine is happy between 180-210ºF. If you want it to run cooler while cruising, try a 180º thermostat. A $10 mod that takes some of the worry out of heavy throttle on hot days.
MTRiviera
PostSubject: Re: Cooling fans not running.   Cooling fans not running. EmptyTue Jul 10, 2012 10:02 pm
Thanks for the replys, Aaron. I think I'll stick with the current T-stat. The Riv has a" for sale" sign in her, so just want to make sure it's solid for the next owner.
» Cooling fans don't run.
» Cooling Fans
» Cooling Fans? When are they supposed to Run?
» why wont cooling fans turn off
» Write-Up: Replacing Radiator Cooling Fans
