 AC cooling insufficient
6 posters
Merit : 64
AC cooling insufficient Empty
PostSubject: AC cooling insufficient   AC cooling insufficient EmptyWed Jun 08, 2011 6:04 pm
I topped off Mel's white riv today and brought the AC back down to a nice cold temp. It didn't take the whole can so I figured I'd top off the green riv, but I wasn't so lucky.
The refrigerant level was at the lower threshold and blowing hot. I tried to add a can of R134 by opening the valve with the engine at 2000 rpm (Procedure from other service manuals, but there's nothing in ours). The can didn't seem to want to flow into the car. The can got cold, but still weighed the same afterwards. Oddly enough, the compressor was on 100%, not cycling on and off. Any idea what would cause this ? I tried to follow the diagnostics in the FSM, but it doesn't seem clearly defined.
We put the remainder of the can in my friends' caprice using the same procedure with no issue. It took the whole can, so I think we can rule out the can itself.
PostSubject: Re: AC cooling insufficient   AC cooling insufficient EmptyWed Jun 08, 2011 8:54 pm
How did you verify the refrigerant level? Did you verify it again after refilling?
Merit : 64
PostSubject: Re: AC cooling insufficient   AC cooling insufficient EmptyThu Jun 09, 2011 8:38 am
the gauge measures pressure. The can's weight difference after opening the valve was negligeable, and the pressure didn't fluctuate.
PostSubject: Re: AC cooling insufficient   AC cooling insufficient EmptyThu Jun 09, 2011 10:35 am
Based on the low-side pressure with the AC running, and the ambient temp, you can know if the system has enough refrigerant. Here's a chart to calculate:
(this rules out the possibility there is not enough in the can)
AC cooling insufficient Temp-pressure-chart-33776F
Merit : 64
PostSubject: Re: AC cooling insufficient   AC cooling insufficient EmptyFri Jun 10, 2011 8:51 am
I know. That's why I was trying to add refrigerant. However the contents of the can didn't seem to want to flow into the car. The can got cold, but still weighed the same afterwards. The compressor was on 100% of the time, not cycling on and off.
joshuatim
Merit : -5
PostSubject: Re: AC cooling insufficient   AC cooling insufficient EmptyWed Aug 03, 2011 2:45 pm
The refrigerant level are checked by measuring tools which are attached with the refiling cylinders? But there is a traditional method also. At the nozzle where we fill the gas you will see transparent glass. If there is forming of bubbles there then it means your refrigerant level is low.
http://www.engineperformancechip.com
PostSubject: Re: AC cooling insufficient   AC cooling insufficient EmptyWed Aug 03, 2011 3:05 pm
Can anyone confirm joshuatim's bubbles in the glass theory? scratch
PostSubject: Re: AC cooling insufficient   AC cooling insufficient EmptyWed Aug 03, 2011 3:06 pm
Did you measure both high and low side pressures? Low alone won't tell you all you need to know. It's only useful if you are simply adding refrigerant, but not for diagnosing problems. This requires a full set of A/C gauges, not just a Low gauge like you get with the can-fillers.
Plus it can take 15-20 minutes to fill. My instructions were to leave it at idle during the fill, and rotate the can periodically.
PostSubject: Re: AC cooling insufficient   AC cooling insufficient EmptyWed Aug 03, 2011 3:07 pm
I was wondering the same thing. In industrial A/C there is usually a sight glass, but not in automotive.
95 rivieramn
95 rivieramn
PostSubject: Not anymore   AC cooling insufficient EmptyWed Aug 03, 2011 4:54 pm
Back years ago in early R12 refrigerant there was a site glass
But that was years ago and I have never seen one on a r134 system
PostSubject: Re: AC cooling insufficient   AC cooling insufficient EmptyWed Aug 03, 2011 5:08 pm
No, there are no more sight glasses in Automotive applications......
» Persistent P0401 Insufficient EGR Flow Code on '95
» Cooling fan
» Cooling
» Cooling Fans
» Engine cooling
