 Crazy air issues
4 posters
manofmany
Crazy air issues Empty
PostSubject: Crazy air issues   Crazy air issues EmptyMon Aug 27, 2012 1:44 pm
Awhile back my blower motor because blowing however it felt and not turning off. I replaced it and it worked normal and still is. However, when turning the steering wheel there seems to be a squeal that comes from the motor and it blows out differently. It almost sounds restricted when making turns.
I've also noticed change in blowing level when pressing the accelerator and letting off. Any ideas?
PostSubject: Re: Crazy air issues   Crazy air issues EmptyMon Aug 27, 2012 2:11 pm
Check your inside (accessory side) serpentine belt. If it is slipping, it could affect the AC, power steering, and any of the other accessories.
PostSubject: Re: Crazy air issues   Crazy air issues EmptyMon Aug 27, 2012 4:52 pm
also when was the last time you checked the battery? Yeah, under the back seat. Yeah.
PostSubject: Re: Crazy air issues   Crazy air issues EmptyTue Aug 28, 2012 2:18 pm
Check the belt tensioner. Sounds like your belt may be slipping.
Do you have any engine mods like smaller supercharger pulley? If so are you still running the stock belt size?
Crazy air issues
» Cams & Rockers
» FAQ: Warm/Hot Air on Drivers Side, Cold on Passenger Side
» help crazy idle
» 2 issues
» I NEED HELP WITH MY 95 RIVI
