 Front Speakers
4 posters
Yardley
Front Speakers Empty
PostSubject: Front Speakers   Front Speakers EmptyWed Aug 05, 2020 1:11 pm
Has anyone replaced both the mid and the tweeter in the doors with a component system? What did you use and how did you do it?
I'm installing a head unit and a sub woofer.
Thanks.
http://www.1badriv.com
Merit : 180
PostSubject: Re: Front Speakers   Front Speakers EmptyWed Aug 05, 2020 5:24 pm
Crutchfield has some good choices. Watch out for adverse impedance mismatches.
Merit : 149
PostSubject: Re: Front Speakers   Front Speakers EmptyThu Aug 06, 2020 11:42 am
The factory tweeters are actually pretty good. I believe I ran mine in parallel with a set of 2 way Polk speakers. Just a factory radio. Been that way for years, no problem.
PostSubject: Re: Front Speakers   Front Speakers EmptyThu Aug 06, 2020 8:46 pm
If it were me, I'd get a pair of 5 1/4" coaxial speakers (tweeters are mounted on the pole piece). Spend at least $65 on a new pair. $100-180 dollars will get you to the next level. Install them in the stock midrange location and leave the OE tweeters in place, disconnected. The OE tweeters are okay, but they positioned them in a terrible location.
Link: Coaxial Speakers on eBay...
For the sub, there are some small, powered all-in-one deals out there. Infinity used to have one called BassLink. These cost a bit more than throwing cheap subs in a box and mounting an amp, but they're plug & play and will sound great. Some of the used ones are a deal.
Link: Infinity BassLinks on eBay...
Yardley
PostSubject: Re: Front Speakers   Front Speakers EmptySat Aug 08, 2020 11:02 pm
So, there is no reason to use a component speaker? Just toss some 5.25s in there?
Front Speakers
» FAQ: Installing Front Speakers
» Aftermarket Speakers???
» Replace 10 ohm rear speakers
» aurora speakers
» Infinity speakers, need help!
