| which radiator do you recommend | |
+4deekster_caddy Sir Psycho Sexy matt270avian highwaywarrior 8 posters |
highwaywarrior Fanatic
| Subject: which radiator do you recommend Wed Aug 28, 2013 7:16 pm | |
| Damn its been awhile, well, at 155000 miles my radiator cracked, no worries, but what radiator do you guuys recommend, especially the guys with modded rivs? | |
matt270avian Expert
| Subject: Re: which radiator do you recommend Wed Aug 28, 2013 7:21 pm | |
| I think there's some running the ZZP oversized radiator. It's probably a solid replacement, even though a stock one would probably work fine. | |
| Subject: Re: which radiator do you recommend Wed Aug 28, 2013 7:24 pm | |
| Oh cool, hopefuly they will chime in, if its a bolt in affair or minimsl mods im all for it | |
Sir Psycho Sexy Junkie
| Subject: Re: which radiator do you recommend Wed Aug 28, 2013 7:27 pm | |
| Get a Jegs aluminum one! I dont know the dimensions of the Riv radiator off hand, but just measure it and order the one thats closest in size. It probably cheaper that a parts store replacement radiator, and youll get an awesome Jegs sticker to put on your tool box! | |
| Subject: Re: which radiator do you recommend Wed Aug 28, 2013 7:46 pm | |
| stock radiator is mostly aluminum and an easy replacement. Plus you don't have to fart around with bracketry and junk. Just replace it the right way. | |
| Subject: Re: which radiator do you recommend Wed Aug 28, 2013 7:53 pm | |
| I did see an acdelco radiwtor on rock auto
And theeeen I see one for 163 plus free shipping, acdelco52472783! | |
| Subject: Re: which radiator do you recommend Thu Aug 29, 2013 12:26 am | |
| Tough decision. Mods don't matter much for radiator choice. I've raced this car with stock radiator and engine stays more than cool enough with a 180º high-flow stat. What really matters is how much time you have, and how long you want to keep the car.
Even though the stock unit cools just fine, the plastic corners can crack and leak. This happens slowly over time. My original radiator started seeping somewhere between 150-200k miles. This went on for a long time, loosing almost no coolant, then changed it (new OEM radiator) at 236k after it cracked open pretty bad. Now at 266k miles, I can smell coolant sometimes, and I notice the new radiator has residue in the same plastic corner. I suspect it's leaking again, but I'm not concerned - yet. It uses zero coolant, just a very slight seep on some days.
Why would you use an OEM radiator? It's a piece of cake to install, for one. Just drop in, basically, and you're good for 50k miles or more. It's also very light weight. Some of the all-metal aftermarket ones are sure to last longer, but they are often different than stock size, may require some cutting, maybe extra mounting hardware. If you buy aftermarket, don't do it because you want better cooling - do it because you plan to drive the car forever. _________________ '05 GTO 6.0L • 6-spd • 95k miles • 0-60: 4.8s • 16.9 avg MPG • Nelson Ledges Lap: 1:26'95 Celica GT 2.2L • 5-spd • 165k miles • 0-60: yes'98 SC Riviera • 281k miles • 298 HP/370 TQ • 0-60: 5.79s • ET: 13.97 @ 99.28 • 4087 lb • 20.1 avg MPG • Nelson Ledges Lap: 1:30 3.4" pulley • AL104 plugs • 180º t-stat • FWI w/K&N • 1.9:1 rockers • OR pushrods • LS6 valve springs • SLP headers • ZZP fuel rails KYB GR2 struts • MaxAir shocks • Addco sway bars • UMI bushings • GM STB • Enkei 18" EV5s w/ Dunlop DZ101s • F-body calipers EBC bluestuff/Hawk HP plus • SS lines • Brembo slotted discs • DHP tuned • Aeroforce • Hidden Hitch^^^ SOLD ^^^ '70 Ninety-Eight Holiday Coupe 455cid • 116k miles^^^ SOLD ^^^ | |
| Subject: Re: which radiator do you recommend Thu Aug 29, 2013 12:57 am | |
| ...or the little Jegs alu schnoz peaking out from underneath the rad cover looks oh so cool & tasty! jmo but what do I know | |
96riv Fanatic
| Subject: Re: which radiator do you recommend Thu Aug 29, 2013 9:22 am | |
| I bought a stock replacement china version from a local radiator shop for under $120 that fit perfect and has survived 2 Phoenix summers. | |
| Subject: Re: which radiator do you recommend Fri Aug 30, 2013 10:58 pm | |
| - highwaywarrior wrote:
- Damn its been awhile, well, at 155000 miles my radiator cracked, no worries, but what radiator do you guuys recommend, especially the guys with modded rivs?
I liked the Visteon replacement I got from RockAuto, it has extra cooling area. Albertj | |
| Subject: Re: which radiator do you recommend Tue Sep 03, 2013 9:40 am | |
| hey albertj thanks. direct bolt in? | |
| Subject: Re: which radiator do you recommend Tue Sep 03, 2013 9:43 am | |
| Hey AA good point , i do plan on keeping this car for a very long time. i admit i was getting a bit bored with her BUT, i had a newfound interest all of a sudden... i bought a 1992 prelude as a bck up car and let me just say... it isnt a car i would drive on a long haul ( lowered, stiffened, but quick though) | |
| Subject: Re: which radiator do you recommend Wed Sep 04, 2013 8:11 am | |
- hey albertj thanks. direct bolt in?
Yes, i bought it on rock auto.com, reused the old plastic mount thingy instead of the new one that came with the rad. Fit just fine. What they did was reduced the height of the fins a little, and put 5 or so more tubes in the rad. Albertj | |
| Subject: Re: which radiator do you recommend | |
