| Rusty Fuel Tank Tab Repair | |
+15saintsnsinners jbeganny LARRY70GS Riviera_Bob sedwards5390 matt270avian ppscheerer RivGuy AA Yardley joshuadalegrimes deekster_caddy robotennis61 stan 71gsx455-4spd 19 posters |
71gsx455-4spd Member
Name : Ken Age : 62 Location : Connecticut Joined : 2007-05-26 Post Count : 64 Merit : 3
| Subject: Rusty Fuel Tank Tab Repair Thu Mar 13, 2014 10:31 pm | |
| Thought I'd throw up this picture of a stainless ring I designed and had fabricated as a repair for fuel tanks with rusty tabs. It's for my '96 Riv, but is shown on a spare '97 tank with good tabs I used to match up dimensions. I'll remove the remainder of the tabs and then pop rivet this ring in place. I plan to do this over the weekend and will post up whether a success or failure. | |
| Subject: Re: Rusty Fuel Tank Tab Repair Thu Mar 13, 2014 10:52 pm | |
| Ken,u designed this?.Now that's cool. | |
| Subject: Re: Rusty Fuel Tank Tab Repair Thu Mar 13, 2014 11:04 pm | |
| Necessity is the mother of invention! That and I'm an engineer. Hopefully it will work. I don't have a good reason to think that it won't. | |
| Subject: Re: Rusty Fuel Tank Tab Repair Thu Mar 13, 2014 11:08 pm | |
| It'll work I think,but it looks nice. | |
| Subject: Re: Rusty Fuel Tank Tab Repair Fri Mar 14, 2014 12:46 am | |
| Subject: Re: Rusty Fuel Tank Tab Repair Fri Mar 14, 2014 8:54 am | |
| Ken that IS cool! A great solution to a frequently encountered problem. If you feel like making several of these you will be able to sell them! | |
joshuadalegrimes Addict
| Subject: Re: Rusty Fuel Tank Tab Repair Fri Mar 14, 2014 12:55 pm | |
| Subject: Re: Rusty Fuel Tank Tab Repair Fri Mar 14, 2014 1:54 pm | |
| I have several flat blanks to form. As soon as I successfully install the one I have, I'll start cranking more out. | |
Yardley Enthusiast
| Subject: Re: Rusty Fuel Tank Tab Repair Sat Mar 15, 2014 8:55 am | |
| Yo Cuz. For a noob who hasn't had the misfortune of dealing with this yet... You made the part that you are attaching to the tank, but where did the locking ring come from? It looks new. And I am assuming it just slips over the top of the sending unit and twists onto the new piece you made, right? | |
| Subject: Re: Rusty Fuel Tank Tab Repair Sat Mar 15, 2014 9:31 am | |
| You can get a locking ring from any GM parts counter. I think it's $10 or so. _________________ '05 GTO 6.0L • 6-spd • 95k miles • 0-60: 4.8s • 16.9 avg MPG • Nelson Ledges Lap: 1:26'95 Celica GT 2.2L • 5-spd • 165k miles • 0-60: yes'98 SC Riviera • 281k miles • 298 HP/370 TQ • 0-60: 5.79s • ET: 13.97 @ 99.28 • 4087 lb • 20.1 avg MPG • Nelson Ledges Lap: 1:30 3.4" pulley • AL104 plugs • 180º t-stat • FWI w/K&N • 1.9:1 rockers • OR pushrods • LS6 valve springs • SLP headers • ZZP fuel rails KYB GR2 struts • MaxAir shocks • Addco sway bars • UMI bushings • GM STB • Enkei 18" EV5s w/ Dunlop DZ101s • F-body calipers EBC bluestuff/Hawk HP plus • SS lines • Brembo slotted discs • DHP tuned • Aeroforce • Hidden Hitch^^^ SOLD ^^^ '70 Ninety-Eight Holiday Coupe 455cid • 116k miles^^^ SOLD ^^^ | |
| Subject: Re: Rusty Fuel Tank Tab Repair Sat Mar 15, 2014 10:27 am | |
| The ring I got is from Advance Auto. If I'm not mistaken it's made by spectrum. | |
Yardley Enthusiast
| Subject: Re: Rusty Fuel Tank Tab Repair Sat Mar 15, 2014 6:04 pm | |
| Is it for a '97 Riv? Or is it for a Park Avenue or something else? | |
| Subject: Re: Rusty Fuel Tank Tab Repair Tue Apr 01, 2014 12:11 pm | |
| Finally had a little break in the weather. Here's done, no more fuel smell!! I will do a write up on this and will start to make some ring kits. | |
RivGuy Member
Name : Bob Norton Joined : 2009-06-14 Post Count : 76 Merit : 0
| Subject: Gas tank repair ring Tue Apr 01, 2014 1:02 pm | |
| Ken I will need one of these when you get them ready, this is a nice car I have with only 69000 miles. I can't believe how much rust is on the tank, it has started to leak when full. Please contact me @ MOcarGuy@ aol.com | |
| Subject: Re: Rusty Fuel Tank Tab Repair Tue Apr 01, 2014 2:30 pm | |
| I hear ya, Bob, my car is a '96 that just turned 70kmi, so right with you! I will keep you posted when I make more. | |
ppscheerer Special
Name : Peter Location : Rotterdam, NY 12303 Joined : 2011-08-19 Post Count : 1 Merit : 0
| Subject: Re: Rusty Fuel Tank Tab Repair Wed Apr 09, 2014 9:35 pm | |
| Ken, I just took out the fuel pump assembly from my 95 riv SC. and the lower ring is not even in existences. Practically rusted away and no tabs left. I sure like what you did with your dilemma and would love to do the same to mine...have you a tab ring available that I could purchase? also let me know how I can attach the ring to the tank and what tools I would need. Thank you very much, I am inspired and hope has returned. | |
| Subject: Re: Rusty Fuel Tank Tab Repair Sun Apr 13, 2014 8:52 am | |
| Peter, I just sent you a response to your PM. I'll let you know when I have an additional ring! | |
| Subject: Re: Rusty Fuel Tank Tab Repair Thu Apr 17, 2014 1:28 pm | |
| Peter, I just check the UPS tracking number and your ring should be arriving today. Please take care in making sure there are no spark hazards when you are installing! Photos with written descriptions and my phone number are included.
Peter is concerned as his fuel pump has moved up out of position and some of the crap that collects around the pump has probably fallen into the tank. His plan is to drain it, run a supply of fresh air through the fill spout to dry it and drive out as much fumes as possible, and vacuum the tank out. I'd be concerned about using a vacuum to draw residual fumes through the vacuum motor brushes.
Anyone else done an in-car tank clean out successfully? | |
matt270avian Expert
| Subject: Re: Rusty Fuel Tank Tab Repair Thu Apr 17, 2014 1:39 pm | |
| I would drop the tank if he was going to vacuum it out. Vacuums can cause static, and any spark mixed with gas vapors is just a bad idea. There's a reason we use compressors over vacuums to clean out computers. | |
RivGuy Member
| Subject: Tank ring Thu Apr 17, 2014 2:02 pm | |
| Ken when do you think you might have a ring for me, I do not drive the car till I can fix because gas has splashed out. You can contact mw @ mocarguy@aol.com Thank You, Bob | |
RivGuy Member
| Subject: Re: Rusty Fuel Tank Tab Repair Sun Apr 20, 2014 11:02 am | |
| Ken, can you help me out, I'm afraid to drive this old car. I see you sent out one how soon do you think you will one available for me? I sure would appreciate it. Could you e-mail me @ mocarguy@aol.com | |
| Subject: Re: Rusty Fuel Tank Tab Repair Tue Apr 22, 2014 6:47 pm | |
| Bob,
I need to make some more blanks and get them formed up. The blanks I have to go to a supplier to get, the forming I can do myself. I got an email from Peter that his installation went well!
I'll keep you informed. I need to figure out a price as I'm pulling the money out of my pocket. I'm not planning to make a living on these, but at least offset my costs.
Thanks. | |
RivGuy Member
| Subject: Re: Rusty Fuel Tank Tab Repair Tue Apr 22, 2014 8:52 pm | |
| Thanks for the reply, I was hoping I wasn,t dreaming. As you know replacing the tank is a nightmare even if I could find one. So as soon as you come up a price and a ring just let me know so I can get back on the road. Thanks Again, Bob | |
sedwards5390 Special
Name : Shannon Edwards Joined : 2014-04-23 Post Count : 2 Merit : 0
| Subject: Re: Rusty Fuel Tank Tab Repair Wed Apr 23, 2014 4:59 pm | |
| Hello. I am having the same problem but with an Aurora. The setup is the same so I would think this would fit and work the same. I am very interested when you have some made up this is genius. | |
| Subject: Re: Rusty Fuel Tank Tab Repair Sun Apr 27, 2014 7:19 pm | |
| Hi Guys,
Working on more now..... | |
| Subject: Re: Rusty Fuel Tank Tab Repair | |
