 Fuel tank issues
2 posters
Trevorusn
Trevorusn
Fuel tank issues Empty
PostSubject: Fuel tank issues   Fuel tank issues EmptySat Sep 05, 2020 9:07 pm
Being I live in New England, rust is sadly a fact of life here. One crummy aspect is how badly it can affect older cars, like my 96 Riv. On my fuel tank, the metal tabs that lock the fuel sender in place have totally rusted away, leaving me in a dilemma. Finding Riv fuel tanks is not easy, so does a tank from the same gen Aurora fit? Is there any other model who has a matching tank? If not, are there any permanent repairs I can do outside of needing a new tank?
Merit : 180
PostSubject: Re: Fuel tank issues   Fuel tank issues EmptySat Sep 05, 2020 10:31 pm
thats an easy one... sort of...
https://www.ebay.com/i/273130587438
Search around, you may find some cheaper.  Some years ago IIRC another rivperformance member posted DIY instructions on this repair, too, that retains the lockring capability.
Trevorusn likes this post
Trevorusn
Trevorusn
PostSubject: Re: Fuel tank issues   Fuel tank issues EmptySun Sep 06, 2020 9:15 pm
Thanks, I'll def look into this.
Merit : 180
PostSubject: Re: Fuel tank issues   Fuel tank issues EmptySun Sep 06, 2020 10:11 pm
Sure - see this - https://rivperformance.editboard.com/t10875-rusty-fuel-tank-tab-repair?highlight=rusted+gas+tank
IDK if these are still available. BUT the  point is that a mating ring for the lock ring isn't exactly exotic. In fact, if you read the link to the end (3 screens) you'll see where another list member came up with a solution using common off-the-shelf stainless hardware - depending on the condition of your tank etc. it might work for you too.
Fuel tank issues
» Write-Up: Fuel Pump/Tank Sending Unit Replacement
» Having Fuel Issues
» Fuel/Gas Gauge Problems & Questions
» Draining Fuel Tank
» Rusty Fuel Tank Tab Repair
