| Write-Up: Installing a Front Strut Tower Brace (STB) | |
+74Yardley joshuadalegrimes matt270avian Randy T. al_roethlisberger artlock llamalor2112 Mattwa drdivo nothincame2mind Riviera Randy ZEP rk0ehn gmann3001 charlieRobinson RivieraParadise flyingjunebugs bigdave RidzRiv BlownRiv crlombardi69 Derek J. Chris Davis VJD2 Abaddon 98inSFl duckstu 97 park ave DEMonte1997 LARRY70GS L67 nigelf Ash eagleblanks13 97rivsc ewolfe0050 EASHER Rickw 96RIVMANN SuperRiv07 Steve98 Chicken Karma lyonsperformance dreww 98riv 98RIV7777 rascal5478 ibmoses albertj robotennis61 Kustom Kreationz robertwolf86 rivparadise Joey98riv BillBoost37 oldsman105 deekster_caddy TonySmooth89 ender467 Buapo Jack the R 54_nailhead jimmyriv SpaceBar turtleman racinfan T Riley 99Rivman Mr.Riviera 1998 Riv AA jax95riv Jason 78 posters |
T Riley Guru
| Subject: Re: Write-Up: Installing a Front Strut Tower Brace (STB) Thu Mar 12, 2009 12:33 am | |
| - 97rivsc wrote:
- ya im probably gonna just get it from a salvage yard, screw gmpartsdirect
call a cadillac dealer... i did got mine for 33 bucks.. WOOT | |
Buapo Addict
Name : Ben Age : 39 Location : Eastlake, OH Joined : 2007-07-17 Post Count : 691 Merit : 2
| Subject: Re: Write-Up: Installing a Front Strut Tower Brace (STB) Thu Mar 12, 2009 3:25 am | |
| I had a hard time finding a salvage yard that had that exact Caddy to take the STB off. In fact, no salvage yard had one... and I called quite a few of them! I would just pay the $30 for a new one, it's easy, relatively cheap, and fast. Which is also how I like my women. | |
| Subject: Re: Write-Up: Installing a Front Strut Tower Brace (STB) Thu Mar 12, 2009 7:33 am | |
| That's not the issue guys. The problem is NO ONE in the frickin' country has one anymore!! GM may very well have decided not to produce any more of them. I'd start working the local yards asap. | |
| Subject: Re: Write-Up: Installing a Front Strut Tower Brace (STB) Thu Mar 12, 2009 7:34 am | |
| If I had an extra bar, I might have our shop take a look at making some, but I'm not so sure we use that size of steel pipe. | |
97rivsc Fanatic
Name : mike Age : 34 Location : appleton wisconsin Joined : 2008-09-28 Post Count : 437 Merit : 0
| Subject: Re: Write-Up: Installing a Front Strut Tower Brace (STB) Thu Mar 12, 2009 10:16 am | |
| well I just cancelled my order from gmpartsdirect, and they just told me that they cannot refund me the 73 dollars I gave them for two bars. They said that they received no money. I am so pissed right now | |
| Subject: Re: Write-Up: Installing a Front Strut Tower Brace (STB) Thu Mar 12, 2009 11:17 am | |
| Well, how did you pay them? Isn't a credit card required at time of ordering? Have you checked to see if your card was ever charged? I do not believe they've charged mine at time of order, for parts that were not in stock. | |
| Subject: Re: Write-Up: Installing a Front Strut Tower Brace (STB) Thu Mar 12, 2009 12:59 pm | |
| My experience has been that they don't charge your credit card until they ship the parts. | |
97rivsc Fanatic
| Subject: Re: Write-Up: Installing a Front Strut Tower Brace (STB) Thu Mar 12, 2009 3:46 pm | |
| they charged mine immediately, and claim that they didn't, I checked online right after I ordered them. | |
| Subject: Re: Write-Up: Installing a Front Strut Tower Brace (STB) Thu Mar 12, 2009 4:16 pm | |
| I believe you have 60 days to file a dispute with your credit card company. I'd get documentation asap of the charges on your card, call them with the info, and give them a chance to get this right. If they give you a hard time right away, just tell them you'll be filing a dispute with your CC company. They KNOW they will lose. Gotta be patient though, the dispute process can take some time, I've been thru it. | |
| Subject: Re: Write-Up: Installing a Front Strut Tower Brace (STB) Thu Mar 12, 2009 4:17 pm | |
| Are you sure it was an actual charge, rather than an authorization for the amount of the order? Tons of companies run an authorization on your card at time of order, which ties up that dollar amount, then at ship time they run the actual charge with shipping. | |
| Subject: Re: Write-Up: Installing a Front Strut Tower Brace (STB) Thu Mar 12, 2009 9:10 pm | |
| I'd print off pics of Ewolfe's custom STB's and have them custom made locally. | |
| Subject: Re: Write-Up: Installing a Front Strut Tower Brace (STB) Thu Mar 12, 2009 9:29 pm | |
| It's really not all that hard to custom make. You need two flat plates of steel, cut a few arcs, drill a few holes, then have a piece of pipe cut to length, flattened on the ends and welded to the plates. Not such a big deal. If you made your own, you can even make sure there are no clearance issues to the brake reservoir. | |
97rivsc Fanatic
| Subject: Re: Write-Up: Installing a Front Strut Tower Brace (STB) Fri Mar 13, 2009 1:22 am | |
| ya im probably gonna go with jack's suggestion, derek I would do what you said except I have no tools what so ever not to mention a welder lying around somewhere | |
| Subject: Re: Write-Up: Installing a Front Strut Tower Brace (STB) Fri Mar 13, 2009 1:58 am | |
| You can have the welding done for you for cheap. I usually only pay a few bucks or get it for free.
Someone ought to make a pattern for the mount portions, then you could print it of and take it to a machine shop to have that part made. | |
| Subject: Re: Write-Up: Installing a Front Strut Tower Brace (STB) Fri Mar 13, 2009 12:57 pm | |
| I'm pretty sure the tops of the strut towers have the same dimensions as a GTP (just by looks, never really measured it), so we might be able to just "extend" one of the GTP bars... Don't quote me on the strut tower bolt pattern idea though. | |
| Subject: Re: Write-Up: Installing a Front Strut Tower Brace (STB) Fri Mar 13, 2009 11:47 pm | |
| I dunno, why replace one STB hack with another? It isn't that much work to do it right. | |
| Subject: Re: Write-Up: Installing a Front Strut Tower Brace (STB) Sat Mar 14, 2009 7:51 am | |
| I did see a W-body STB that had ends like these: http://www.mcmaster.com/#tie-rod-ends/=zwqgg with ball joint tie rod ends, and the bar in the middle had left- and right- handed threads, so it could adjust like a turnbuckle. I always thought we could use one of them because we might be able to get longer tie rod ends if they weren't long enough already. | |
| Subject: Re: Write-Up: Installing a Front Strut Tower Brace (STB) Sat Mar 14, 2009 9:24 pm | |
| I've heard about adjustable STB's. Perhaps for no justifiable reason they scare me. | |
eagleblanks13 Special
Name : mike 95 riv stock but lookin for more Location : Grover beach CA Joined : 2009-03-31 Post Count : 5 Merit : 0
| Subject: Re: Write-Up: Installing a Front Strut Tower Brace (STB) Sat Apr 11, 2009 12:08 am | |
| does it just bolt up to a 95 or what | |
T Riley Guru
| Subject: Re: Write-Up: Installing a Front Strut Tower Brace (STB) Sat Apr 11, 2009 12:11 am | |
| - eagleblanks13 wrote:
- does it just bolt up to a 95 or what
NO. | |
| Subject: Re: Write-Up: Installing a Front Strut Tower Brace (STB) Sat Apr 11, 2009 2:57 am | |
| is there anyway to make it work or any other options | |
T Riley Guru
| Subject: Re: Write-Up: Installing a Front Strut Tower Brace (STB) Sat Apr 11, 2009 3:46 am | |
- is there anyway to make it work or any other options
custom | |
| Subject: Re: Write-Up: Installing a Front Strut Tower Brace (STB) Sat Apr 11, 2009 12:14 pm | |
Read from page 1 of this write up for info on fitting the STS bar to your car. | |
Ash Enthusiast
Name : Marty Age : 46 Location : S. Central Indiana Joined : 2008-05-21 Post Count : 115 Merit : 4
| Subject: Re: Write-Up: Installing a Front Strut Tower Brace (STB) Tue Jun 09, 2009 10:10 am | |
| Well, I recieved another E-mail from GM Part Direct today. It looks like my STS front STB is finally being removed from backorder status and will ship out very soon.
Just a heads up for anybody else wondering if/when they will have more available.
Cheers | |
| Subject: Re: Write-Up: Installing a Front Strut Tower Brace (STB) Tue Jun 09, 2009 11:32 am | |
| Good news, thanks for the update. | |
| Subject: Re: Write-Up: Installing a Front Strut Tower Brace (STB) | |
